Wont turn on. or call for water
My kitchen aid washer KAWE450V purchased 1990 will not turn on or call for water. i replaced a solenoid a couple of years back - but cant rememeber how to test for this.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
The float could be stuck and thinks it has water(throw a bunch of water into it and it might free itself up.
do you have power to the unit??????
is the filter at the base clean???
Posted on Apr 22, 2009
Switches on kitchen aid refrigerator dispensers not working.. ice maker is working, but will not dispense ice or water
Sounds like the water has been turned off, or the solenoid valve (located at water entrance to fridge) has failed. you should hear a solid snap from that solenoid when water is called for by pressing the dispensing switch. You can test the solenoid by unplugging the fridge and measure the resistance across the solenoid terminals. If it measures 200-500 ohms it is ok. if it measures open the solenoid has failed and needs to be replaced.
Sep 18, 2014 | KitchenAid Refrigerators
Upper spray arm on my Kitchen Aid dishwasher (8573025) doesn't work.
Arm operates(turns) by water pressure. If it does not turn no water is going to the top spray arm. make sure the setting washer is on does not preclude the top spray arm from operating(read manual). If not check arm by spinning by hand to make sure it is free. If arm is free and it still does not turn when DW is running than there is a restriction in the tubing to the upper spray arm or the check ball or solenoid are not operating correctly.
Mar 01, 2012 | Dishwashers
My Kitchen Aid clothes washer is leaking water from the bottom.
HI couple things to check, water hoses coming into washer, tip the washer back and look underneath and see if you can see where its coming from, most common leak on this one is the drain pump which is located right on the front of the motor, if you tip the washer back its a plastic pump with 2 big hoses going into it, they usually crack and leak water from there. They are only about $30.00 to buy.
Sean
Mar 29, 2011 | KitchenAid KAWS850L Top Load Washer
Kitchen Aid Model KUDT03FTSS2 -- no water getting into dishwasher. I have no idea what to check to see if there is a clog somewhere.
Make sure the water tap into the sink hot water plumbing has not been turned off. Check the routing of the water line which feeds the washer to look for kinks somewhere. The inlet water solenoid in the washer base may have failed--if no click when water should go in, suspect the solenoid. It is a fairly simple thing to replace. The last suspect would be a failure of part of the control system that signals the inlet solenoid. Hope this helps!
Nov 13, 2010 | KitchenAid Architect® KUDT03FT 24 in...
Kitchen Aid refrig. Won't put water into the ice m
Hi Dan,the plastic hoses are removed by pushing up on the "ring"around the hose at the inet and pulling it out.
Nov 15, 2009 | Refrigerators
My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Jun 20, 2009 | KitchenAid Dishwashers
Washing Machines Logo
Top Washing Machines Experts
