Question about Panasonic TC-32LX70 Television
Panasonic TC-32LX70 buzzing sound from speakers
I unplugged the cable coming into the house to do some rerouting. After I hooked the cable back up, I have a buzzing or a hum coming from the speakers. I've checked the connections and all are good. I put a DVD in and the noise goes away. Any thoughts? I assume it has to do with the cable. But how?
  • sn590 Apr 24, 2009
    Thanks, it ended up being the cable box.
    President:
  • 814 Answers
You may have rerouted your cable too close to a live connection. The magnetic field from the power line is causing interference on the television cable. You will need to either reroute the cable or shield it from the interference. This can be done with a metal covering separating The wires from the cable. It can also be caused by a bad ground connection in the house. The bad ground will allow noise to appear on the ground of the cable and interfering with it. Check to make sure you have a good ground connection on the cable and the power cables connections. I hope this information helps you with your problem.
Posted on Jun 06, 2009
    New Friend:
  • 58 Answers
Double check the coax cable, make sure you have a good cable.
Are you only getting the noise from watching Cable?
Posted on Apr 23, 2009
I have a Panasonic LCD tv, model# TC-32LX70, S/N MY71420839, manufactured May 2007. The tv wouldn't turn on unless the power cord was unplugged and plugged back in for about 2 years. Then it
Fault with the main power supply regulator section circuit board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 20, 2014 | Televison & Video
Tip
Panasonic TC-32LX70 Manual Download
Download Panasonic TC-32LX70 LCD HDTV Manual
Would you like to review the features of the Panasonic TC-32LX70 LCD HDTV?
Have you lost your Panasonic TC-32LX70 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic TC-32LX70 LCD HDTV Users Guide?
Follow this link
(& click FREE) to download a pdf version of the Panasonic TC-32LX70 LCD HDTV documentation.
I hope that helps.
on Jul 13, 2010 | Televison & Video
Tip
Follow this link
I hope that helps.
on Jul 13, 2010 | Panasonic TC-32LX700 Television
How do I get rid of green line?
your problem is a faulty T CON BOARD.
Part number TCON BOARD 6870C-0060F
hope 2 help
www.bostonrecycling.net
Jun 30, 2012 | Panasonic TC-32LX70 Television
Need to find user guide and owners manual
Hello;
I have lost the user manual to a Panasonic TX-32LXD700 32" TV. Does any one know of a link to download a copy?
Many thanks to any one who can help?
Feb 10, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Tip
Follow this link
I hope that helps.
on Jul 13, 2010 | Panasonic TC-32LX70 Television
My (Panasonic TC-32LX70) TV will not turn on with remote-with so many people with the same problem, with the same model, they should of been recalled because there is obviously a problem with this model....
Contact Panasonic with complaint. Otherwise check remote function by pressing power button while pointing it toward the camera in your cell phone. If you don't see the led on the front of the remote glow in the sgreen of the phone then the remote is the problem.
Dec 03, 2009 | Panasonic TC-32LX70 Television
Power issues with panasonic tc32lx70
You need to go to Panasonic dot com search for TC-32LX70, go to software updates. Use a blank SD card and format it save the firmware file SDDL.SEC to it. Carefully open the "service panel" you may need to remove the entire back case? since it seems the frame is holding the service panel down. 1)power on the TV
2)insert the SDcard with firmware update into the rear(lx70) or the sdcard slot on the side(lx700)
3)follow the on-screen instructions.
4)when it's finished, remove the SD card.
turn off or unplug for 30+ seconds
then plug it back in.
5)power on.
6) perform the first time setup.
Mar 12, 2009 | Panasonic TC-32LX70 Television
Audio interference
Is the sound comming from the speakers on the TV or the back of it? Plasma TV's can doing buzzing sounds when moved to higher elevations.
Jan 27, 2007 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Panasonic TC-32LX70 Television Logo
330 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
