Question about Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher
Pump won't stop draining
We had a blockage in our kitchen sink plumbing. We had run the dishwasher, as it tried to drain the blocked pipe caused a back-up in the dishwsher. We had a plumber clear the block. However, the dishwasher keeps trying to drain water, (we think), so that it can not re-start. All we get is the pump draining. How do we get the machine to realize it is not now full of water? We have emptied all the visible standing water that had collected in the machine.
  • 1 more comment
  • Stelios Varias
    Stelios Varias Feb 07, 2008
    We have what appears to be the same problem, except with model SHU 3302. I also noticed that much of the door insulation is very wet.
  • carlsons640 Jan 15, 2009
    where is the limit switch?
  • Terence Fourie
    Terence Fourie Mar 10, 2014
    ok, typically what has happened, there is water in the bottom sump which normally comes from a faulty pump (wash motor /pump all in one.) It activates the sump safety limit switch which only allows the drain pump to run. No other action will take place. The only quich check is to tilt the machine backwards about 45 deg. and see if water runs out from the sump onto the floor. If so, that indicates where the problem is. Once the water has stopped flowing from underneath, replace the machine flat onto the floor and retry the program. It should run for a period. If so, you need to remove the side panel on the R.H.S to investigate exactly where the leak is coming from. Hope this helps.
  • 909 Answers
You will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
Posted on Oct 08, 2007
SOURCE:
Maytag dishwasher won't drain
Drainage problem of some sort is usually the cause. Could be blockage before your drain pump, in your drain pump, or in your drain hose. One possibility is that you just installed a garbage disposal and forgot to remove the "knock-out" plug for the dishwasher drain line. Another cause can be that you have not looped your dishwasher drainline under your sink and water from your sink is flowing back into you dishwasher. You must attach your dishwasher drain line under your sink so it is higher then your sink drain lines, creating a trap for your dishwasher. Your drain sump could be plugged, not letting the water get to your drain pump easily. This is caused by not getting loose or hard debris off your dishes before putting them in the unit. Also make sure your drain pump is getting the right voltage when it is supposed to.God bless youfa618d8b-d0fd-412a-b0d5-a88d44bf89d3.giffb1320dc-7bec-4cb0-98ed-c24cf54e5e3b.jpg
Apr 02, 2013 | Dishwashers
My kitchen sink blocked
You show the dishwasher yet you complain about the kitchen sink being blocked. If the dishwasher is also blocked then the blockage is below the trap on the sink. If both are blocked then the blockage is after their drain pipes meet under the floor....good luck!
Nov 08, 2012 | Dishwashers
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
if you have an air gap vent in the kitchen sink plumbing then make sure it is clear. Also looks like the kitchen drain end is blocked. Pour some caustic soda into the sink drain, wait 10 minutes and run water into the sink.
If you are using insinkerator (garbage disposer) in sink, make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
AEG Favorit 8081 displays error F0 - there is a build up of dirty water which has not drained way. I syphoned all the water away and after a while the dishwasher started to work again - but then the...
Hello. When the water does not completely drain away, it usually means that there is a partial blockage in one of these areas:
1. The small drain pump located under the tub, accessable by removing the lower front panel.
2. The drain line going from the DW pump to the plumbing under the kitchen sink.
3. The garbage disposal, or the trap under the sink.
Check these out and you will find a chunk of bone, or glass or some other debris which is partially blocking the draining action. J.
Sep 04, 2010 | AEG 24 in. Favorit 80800 Free-standing...
Bad smell coming from bottom - water doesn't completely drain out
Make sure the drain hose is not blocked or pinched.Also check where it drains into your sink pipeing to be sure food isnt blocking the drain way.
Its eather the drainage path is blocked or the pump stoped pumping.
Also, the drain hose must be installed so as to have a high spot higher than the sink drain or the water from your sink will be able to "run down hill" or drain into your dishwasher. Take a look and see!
also It sounds like your dishwasher does not have an air gap. Newer dishwashers come with an air gap installed, but they can be taken out. A quick fix for this is to:
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher, and garbage disposal.
Aug 17, 2010 | Bosch Dishwashers
Water remains in bottom, water pump out?
It sounds like one of two possibilities here.
The most likely is a blockage somewhere between the drain pump and the drain in the house (under the sink).
Places to look for this would be an air gap or the fitting where the drain hose connects to the house plumbing. Take the drain hose from the dishwasher off of the house pipe under the sink, run that hose into a bucket and see how it drains then. If it is poor then follow back toward the dishwasher until you find the next junction or fitting. If you are sure all these are clear and still not draining, you will most likely need a new drain solenoid.
Apr 25, 2010 | GE Dishwashers
Dishwasher is draining through the vent cap at the top back side of my sink ??????
Sounds like you have a blockage in your drain pipe. run a plumbing snake down the drain and see if you can clear it, otherwise, i'd be looking for a plumber
Apr 02, 2010 | Frigidaire 24 in. FDB1250RE Built-in...
Won't drain
hello. i can help you. remove the lower panel and in there you will see the drain hose going from a little pump near the floor upwards and ultimately connected to your plumbing under the sink. Disconnect it at both ends and examine it for a blockage. Also, remove the little pump and look in it for a chunk of glass or something else that partially blocks it. finally check out the sink trap and or the garbage disposal [if u use one] still looking for a blocked pipe.
Aug 31, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Drainage
This normally shows blockage in hose , assuming you have checked and cleaned filter.Glass sherd was the problem with mine , first time then second was block outlet hose cause by backup of garb.Glass was in system at least 4 months before it moved in outlet hose and stopped full drainage.
Mar 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Dishwasher will not drain water out
if plumbed in under the sink, check the spigot the drain hose goes to is not blocked - a common problem. if on drain you should be able to hear the drain pump working. if you hear a faint humming noise instead, then there is probably a foreign object stuck in pump. also check for blockage in the drain hose
May 06, 2007 | Hotpoint 24 in. HDA1000Z Built-in...
Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher Logo
1,076 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
