Question about Kenmore HE2 Plus Front Load Washer
Does the front of the pump filter just unscrew counterclockwise?
  • judylagoon Apr 23, 2009
    Thanks so much! It worked great. It was very hard to unscrew, and I was afraid that there may have been some other step I was missing. With your advice, I felt comfortable taking it off, and cleaning the filter out. (Oh, and thanks for the tip on the amount of water that comes out of that thing! The "let it drip out a little at a time" method worked like a charm. )
  • 5,911 Answers
The pump reservoir cap turns counter-clockwise to remove. You may want to review this link to assist you as well:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
The advice in the link I gave you may make things a bit easier and help you avoid the big mess that is usually associated with cleaning these pumps. Sometimes the cap can stick and become difficult to turn. You have to be careful about using anything for leverage as the cap is plastic and can be damaged. If you have questions, please let me know. I hope you find this helpful.
Posted on Apr 22, 2009
Where is my pump filter whirlpool duet front load washer
When your Whirlpool washing machine won't drain, there's a possibility that the drain filter is clogged. The drain filter is designed to catch lint, change, credit cards and all the other things that find their way into the washer. Whirlpool washer models that have a drain pump filter are easy to disassemble so that you can access and check it. Before you go to the minimal amount of trouble it takes to check the filter, however, take a look at the drain hose behind the washer to ensure it isn't kinked.
1 - Unplug the washing machine. Lift the front end and place two-by-four blocks under each foot to keep the front elevated. 2 - Unscrew the three screws at the bottom of the panel, using a Phillips screwdriver. Remove the panel. The drain pump assembly is directly in front of you, in the middle of the machine. 3 - Unscrew the knob on the drain pump by turning it counterclockwise. Hold a bucket in front of the pump while you remove the knob to catch the water. There may be as much as 2 or 3 gallons. 4 - Turn the knob over. The filter is on the back. Check the filter and remove any debris or lint. Replace the drain filter onto the pump. Screw on the access cover. Take the machine off the blocks and plug it in.
Dec 21, 2016 | Whirlpool Washing Machines
E1 f9 code front load duet washer how do we fix it
When your Whirlpool washing machine won't drain, or is displaying the E1 F9 error, there's a possibility that the drain filter is clogged. The drain filter is designed to catch lint, change, credit cards and all the other things that find their way into the washer. Whirlpool washer models that have a drain pump filter are easy to disassemble so that you can access and check it. Before you go to the minimal amount of trouble it takes to check the filter, however, take a look at the drain hose behind the washer to ensure it isn't kinked.
Dec 21, 2016 | Washing Machines
E1 F9 code front load washer whirlpool duet
My GE front load washer WBVH5200J1WW washer pauses at the 13 minute point in a 59 minute cycle, It shows no error codes
I would inspect the pump. It could be draining to slow. There should be a small door at the bottom of the machine. Pop the door and you'll have access to the pump filter. The filter unscrews from the pump housing counterclockwise. There will be some water that will come out. Using a wet vac, slowly unscrew the filter until there is a small amount of water coming out. Have the vaccuum on and ready. Vaccuum till there is no more water. If you don't have a wet vac, then a couple towels will do the trick. Completely unscrew the filter and pull it out. Hopefully you will find, a nest of change/hair/bra wire/bobby pin ect. I've seen it all :-) Once you have cleaned the filter or failed to find anything, reach with your finger into the right side of the housing, there will be a hole. Reach until you feel the impeller. It should have 4 fins and shouldnt have a lot of play. The pump will need to be replaced if this is the case. If this doesn't help, then you should have a tech come out. Find a small time repair place with little overhead. This is where you will usually find the best prices AND service.
Apr 05, 2013 | Washing Machines
How do you clean out your water pump filter?
Remove 3 T-20 torx screws to get the kick plate out yer way. Have something ready to catch the water. Turn the pump filter cover slowly counterclockwise and unscrew it. Yank out the coin basket and dump out the accumulation. Put her all back and party on!.
Aug 04, 2012 | Kenmore 44932 Front Load Washer
My whirlpool front loader washering machine is not draining properly, could you give me a reason why it is not draining properly.
check the discharge hose in the rear make sure no kinks or there could be something in the pump. if it drains slowly i'd say check for kinks. a whining noise while it's draing cloged pump
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I do not seem to be able to undo the filter on my whirlpool washing machine, does it just unscrew, or unscrew and pull. I can unscrew it, but it does not pull out.
Hi, Unplug the machine. Take a cake pan and put it under the handle for the filter. Unscrew counterclockwise slowly. Water will start to come out. When pan is partially full, retighten filter and dump water. Repeat until no more water comes out. Then completely unscrew filter and pull out and clean. Hope this helps.
Jan 17, 2011 | Whirlpool AWZ412 Front Load Washer
How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin fast water doesn't drain
Remove your bottom front kick panel, usually two to three screws on the very bottom front of the washer. Unplug washer, have a lot of towels ready to mop up the water that comes out of the washer. In the very center front of the washer is the round plastic drain pump filter for the washer. Unscrew this a little,(turn the plastic screw counterclockwise) and let the water drain completely as you soak it up with your towels. When it is completely drained, unscrew the filter the rest of the way and clean out all the debris in the filter and inside its receptacle. Reinstall everything and test. I recommend you do this at least every 6 months. If this doesn't work then you may have a bad water pump. Good Luck, Appliance Specialists
Dec 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Filter cap
Remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter & clean out. Refit. If you have manual refer to it. Pl rate me if helped.
remember "left is loose, right is tight. So turn it counterclockwise. It will require some strength or a channel lock tool.
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
98 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
