Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony rear projection tv
Tv just switched itself off and refuses to restart. On reading the manual it asks to count how many times the red light flashes...answer 6. What does this mean? Has the lamp blown?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Most likely the lamp has failed. The problem with 6 blinks is that when the lamp failed most likely the thermal sensor for the lamp also failed. Most likely you will need a qualified sony tech. to repair.
Posted on Feb 07, 2008
SOURCE:
HDTV, projection tv, tv shuts off by itself, green light blinks, tv restarts, red light doesn't light up, any thoughts?
good day. your tv has a defect . you need a qualified technician to fix your problem. but for the best is to consult your problem to sony servive center.
Jun 24, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv will not stay on
If tv shuts off and turns back On itself than lamp is weak and need to be replaced.
If tv shuts off but does not turns On itself than you will see red light blinking on tv front, let me know how many times it blinks, there would be pause of 3 seconds in blinks so count pause to pause and post here to provide you helpful info about problem.
Thanks.
May 24, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
I have Sony TV model KDF-42WE655 which stopped working. No display and when powered on, the green light comes on and blinks approx 50 times and turn red (blinking red). How and what do I need to buy to fix...
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
Dec 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture, green light keeps blinking, hear fan go on then off, blinking light changes to red
Count the blinks between the pause, Let me know or call a sony service center if your a novice at tv repair
Apr 24, 2009 | Sony KP-57WS500 57" Rear Projection...
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
132 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
