Question about Gateway 503GR PC Desktop
I have a Gateway 503gr desktop. When I press the on button, the computer shutters but does not turn on.
  • chrismulls12 May 03, 2009
    I have the same problem. Replaced the motherboard and powersupply and the same thing happens. Wont boot up. fan comes on briefly and nothing. do you think that I should replace cpu?
  • Gateway Master
  • 5,660 Answers
I suggest the power supply is bad. Your Gateway 503GR uses an ATX style power supply. The style found in about 90 percent of desktop computers.
http://support.gateway.com/s/PC/R/3724/4172nv.shtml
(Click on Components. Then click on Power Supply in the list)
http://support.gateway.com/s/POWER/102015/102015nv.shtml
Uses a 300 watt power supply. I suggest Tigerdirect or Newegg, for a replacement. If your computer is dirty inside, I also suggest cleaning it out.
Use a can of compressed air for computers, WITH the computer unplugged from the surge protector.
Posted on Apr 22, 2009
My gateway 503gr will not power on when you press the power button has power to mother board every thing is plugged in there is a green light on the power supply and the mother board and the power switch...
This could have a bad power supply (in this case I would try a new one just in case).
All other things being normal, I would guess a bad motherboard.
The best thing to do is disconnect everything but the CPU and memory and try to start it.
If it starts, then start connecting stuff until it doesn't start--this will tell you what is bad.
Apr 13, 2011 | Gateway 503GR PC Desktop
It wont burn a dvd
your drive lence is complaint please change your drive lence
Feb 03, 2011 | Gateway 503GR PC Desktop
Missing NTLDR message, cd does not start ,have no floppy, this is a 503gr. F8 does display but does not continue to selected item, get black screen. Does a processor cause this failure?? Have original...
Your CD is not starting as it is not configured for first boot device. I am not sure on which function should be used to get to Boot Menu however you may want to try using either F2 or F12. Then its all about changing the Boot device fromHard Drive to CD. Once Changed follow the steps mentioned below,
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Once all these steps are completed make to change the boot device to hard drive from CD rom.
Jan 07, 2011 | Gateway 503GR PC Desktop
Gateway 503gr has no power, the standby light flashes green when I remove power. Tried new PS and the standby LED stays lit. I then tried both new and old PS disconnected from board and shorted...
Disconnect everything from the motherboard except the power supply connections and cpu fan. Install one stick of RAM and connect your monitor. Then try starting up. See if you get any BIOS boot messages. This will tell you that the board and processor are okay.
With what you say you've tried already, I'm thinking you might have a bad processor. Most every other problem would result in some kind of error like POST beep codes or messages on screen. If the system still doesn't boot with the bare minimum parts installed, replace the processor.
Mar 02, 2010 | Gateway 503GR PC Desktop
COMPUTER WILL NOT TURN ON AT ALL --last week the fan seem to be winding up w/ loud running sound
if the FAN is running and if you get a long beep sound then please chagne or replug the System RAM, after its not working then please chagne the power supply[SMPS] of your system.
Feb 17, 2010 | Gateway 503GR PC Desktop
503GR Gateway
i would say try swapping your motherboard for another one to test and see if your motherboard is bad if that doesnt work take it to a computer repair store
Oct 17, 2009 | Gateway 503GR PC Desktop
My Gateway 503 gr quit turning on. At first it chattered a little and then went dead. Now it won't even do that. The power supply has been replaced with a new one but no change. I need to see if the power...
Check the condensators. If there are not any blown condensators or leakage, keep the video card (or at least the one on board if any) and remove all the other cards, also the memory. Check the CPU with a known good motherboard. If the CPU is ok begin by adding the memory, one bar at a time (you may alternate the slot also). If the computer do not start the motherboard is defective . If the computer starts but no sound is heard motherboard could be defective. Try to install a previously checked memory. If you do not get any signal the board is dead. If you get video signal, add one card at a time until you identify the bad component.
Oct 04, 2009 | Gateway 503GR PC Desktop
I need to replace the motherboard on my Gateway 503GR. Will the following motherboard work? eVGA e-7050/610i GPU - motherboard - micro ATX - GeForce 7050
Check your wiring harness on your Gateway and see if it will match up to your new board. If the wiring harness will match up then you can install the board. However, you will now have a custom built computer in a Gateway case.
Aug 01, 2009 | Gateway 503GR PC Desktop
How do I insert a memory stick pro duo into the Gateway 503GR?
Unplug computer, touch something metal to discharge any static electricity, Remove cover, look for the other memory module, slide back the two tabs, make sure pin lines up with ram, make it click into place, may require some pressure, put cover on plug in power, turn it on...
Jul 16, 2009 | Gateway 503GR PC Desktop
Gateway 503GR PC Desktop Logo
370 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
