Question about Vacuums
Does not **** water very well and soap mixer is not working.
Does not **** water very well, so it takes the carpets alot longer to dry. Someone told me that maybe the belt needs replaced, but I'm not sure.
Also the automatic soap mixer is not working.
  • 2,005 Answers
Clean the machine with vinegar or CLR
Posted on Apr 22, 2009
How do you remove cooking oil stains from carpet
I use a hot iron with an absorbent cloth between the iron and the carpet. i would also put carpet cleaning powder on it and let it sit for awhile. Ive spilled several candles on the floor and this works well because the oil is absorbed better when heated!
-Scott
Dec 26, 2017 | Vacuums
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
How do i clean a handmade wool rug that is stained and really dirty
These are usually quite durable. I use a fairly stiff brush with mild soap and water. If the carpet is good quality, you can rinse with a garden hose or even a pressure washer . Hang over a bathtub or outdoors to dry. Drying will take two or three days, but do not leave out in the sun longer than that. Professional cleaning is also available if you wish.
Sep 22, 2014 | Royal Palace 33"x53" Flowers & Butterflies...
My Bissell carpet shampooer will not dispense water or cleaning solution, nor is the "flow indicator" spinning
most of the Bissell carpet cleaners that have the water heating feature stop pumping water at one time or another. Make sure the belt is still on the pump and if it is then the problem is probably in the heater core in the handle. Hard water deposits plug the tiny little water ways inside the heater core. Pull the heater core and take it apart and clean it with a strong scrub brush and I think vinegar works for cleaning I was told. I just use soap and a brush. Then flush all your lines with hot water. The cause is from hard water deposits or leaving the soap in the cleaner after you use it. Both will stop it from pumping water
Apr 29, 2014 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
A friend loaned me her Bissell Proheat Turbo carpet cleaner and I don't know how to use it - any help?
I like these cleaners.
First vacuum your carpet very thoroughly.
Depress the lever to tilt back the handle.
Grab the tank from the base. Remove the lid.
Fill the bladder with hot tap water. Replace the lid, and place tank back into the base. Put the handle back upright until it locks into place.
Take the soap container on the side and fill it with the Bissel soap solution. Place your dial on floor cleaner, and select either soap or heavy traffic.
Turn on the machine and the heater. Take your machine to the far end of the room and depress the handle put the machine in the corner depress the trigger and you will see a little spinning thing on the machine starting to spin - this means that the solution is blending and the spray is wetting the carpet. Pull the machine slowly back towards you about three feet and then let go of the trigger and pull the machine a couple more inches. When you stop the trigger will release. Push the machine forward and repeat the pull pass this time without depressing the trigger. For the next pass - overlap each and every pass (I do each pass at the half way point). Do this along the back wall. When you depress the trigger and that spinning dial does not spin - you are either out of water or out of soap. Go over the entire room with this technique.
Now this next step is VERY important. You have to do the whole room process AGAIN - this time with NO SOAP. I have used these machines for years and trust me - if you don't go over it again - your carpet will be a magnet for dirt. This time empty out your soap cup and rinse it out and refill it with WHITE VINEGAR. Again fill your tank with hot water. Re-do the entire room as if you are shampooing the carpet.
Let the carpet dry overnight - the next morning I would recommend applying scotchguard carpet protector (you can get the cans at H.D. or Lowes. Yes the Bissell solution has scotchguard, BUT when I apply the scotchguard again - the carpet stays so much cleaner so much longer.
Do it right the first time and don't cut corners and you will have the cleanest carpet on the block. It's a long process to do it right, but the end result is worth it.
OR if you want to save money and use something more environmentally friendly - fill with white vinegar. This will work just as good and leave your carpet less sticky from the soap and your carpet will stay cleaner longer.
Mar 19, 2010 | Bissell 1699 ProHeat Clear View Upright...
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
My steam machine will not spray water on to carpet why
clean the heater out it may be clogged with dry soap and water
Dec 28, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Doesn't emit water in either tools or floor mode.
The mixer valve is most likely gummed up with old soap and stuck you will need to take the bottom of the machine apart to get at it. The problem with that is while it is easy to get apart it can be very difficult to get back together properly even for someone that does the job all the time. The only trick I can give you is to put a phone book under the base of the unit this will keep the wheels up and the base level to aid in reassembly. If you do get it apart remove the mixer valve which is directly under the grey mixer knob and rinse it in your sink very well. In the future take the time to empty the unused soap back into the bottle and fill the solution tank with water and rinse out the system before putting it away. For any parts or cleaning solution visit www.stevessewandvac.com
Jun 26, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
