Question about Haier HTE21WAAWW Top Freezer Refrigerator
My hte21waaww door gasket is causing my freezer to form icicles. does any one have answers
  • t_jammer Apr 22, 2009
    thank you for your help. I will try it.
  • 358 Answers
Check all around the gasket to make sure is not broken , if it is you need to replace it,but if not and is dry and won't stick to the refrigerator,first clean with degreaser around the magnet and also where this make contact with the fridge .After this put very hot water all around the rubber gasket it will make it softer and it'll expanded after this you also can put vaseline on the gasket (is not toxic and doesn'tsmell)specially on the side by the hinges.
Posted on Apr 22, 2009
Icicles in the freezer and frost inside door of freezer. Normal for brand new refrigerator?
It sounds like the seal isn't closing completely. If there is any gap around the seal air is probably entering and the moisture is freezing. This sometimes happens when the doors are reversed. Try heating the gasket with a hair dryer if there are gaps in the gasket.
Sep 24, 2014 | Refrigerators
Why Is my LFFH2067DW2 frosting up and icicles are forming inside
Sounds like the door gasket needs replacing.
Aug 24, 2014 | Freezers
Icicles in freezer compartment
you can do the dollar check to see if indeed the gasket is the problem,thats what it sounds like. close dollar in door and pull out slowly,you should feel some resistance.also at the top corner of door you will find 3 screws at the hinge, loosen the screws a couple of turns and you will be able to adjust the fit of the door ,move it alittle to make sure it is square with the fridge,this may help then re-tighten screws.
Aug 14, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Icicles forming in frost free - whirlpool afg8272 NF - just over 2 yr old
If you have ice forming the first thing that you need to do is check the seal around the door. If there are any gaps this can cause warm air to seep in and create condensation. This will cause an ice issue. If there are gaps you need to make sure the door is sitting square and if so you may need a new seal gasket.
May 07, 2011 | Refrigerators
Icicles in Freezer
yes.because if you not go down the temperature there will be icicles formed so keep your freezer in the right temperature
Jul 22, 2010 | Kenmore 50522 / 50524 Side by Side...
Icicles forming from melting ice from ice maker
hi this might help you:
*make sure that the seal indeed still seal well enough...
*the older the fridge the more common this is
i don't really know much about this, but just check that it's cold enough inside like check if it changes when you change it from eg 4 to 7, and that the sealing is fine, and that your door is lined out good, also important that last thing offcourse, cause if it seems to shut good, but the seals arent in the right position compared to the other side (the 'fridge-walls' :p) they won't seal ofcourse...
I hope this is useful, and greets.
Oct 20, 2009 | Refrigerators
I always have icicles in the freezer and anytime we close one of the doors the other comes open and then closes again
Door gasket defective, check for proper seal around door (gasket should be flush against frame when door closed). Also other possible cause is that when you close the door to the ref, the freezer pops open just enough to cause ice to build up around door. Check drain plug inside evap area of freezer, and repalce door gaskets.
Oct 01, 2009 | GE GTS22WCP Top Freezer Refrigerator
Ice Melting
ok check the door gaskets they must be toushing forming a compleate seal nothing else is acceptible also there is a possibilty that your ice maker heater is stuck in the on position.also these units are known for a having a bad control boared in the back
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Why icicles are formed at the outlet of the icemaker?
  1. this is normally caused by warm air getting into freezer
  2. check door gasket
  3. check dispenser door is shutting completely
Nov 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer Door
Defrost to get rid of icicles (temporarily). shut the door on a piece of paper , and try to pull it out . The gasket should be tight enough with the door closed that the paper will resist being pulled out, or not come out at all. Check all around the door, it might be bad in just a small area. A bad gasket means warm air enters, cold are exits, and where the two meet, condensation forms, which inside become stalagtites (I mean icicles). The service guy should have checked it, but hey, who would expect a new appliance not to work properly? If the gasket checks out ok, maybe insulation was not installed properly in the door, which would cause temp variation. countrycurt0
Aug 06, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Haier HTE21WAAWW Top Freezer Refrigerator Logo
145 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
