Question about Siemens 200 Amp Main Breaker 30 Spaces 40 Circuits
Hi, the main breaker connection on my siemens bos becomes loose. I,ve changed it about 2 years ago because of that problem and when I removed the front panel today, It came loose again cutting down on the power(light bulb at half intensenty). I played a bit with it and it came back one ok but When I try to put back the front panel, it does it again. Tx!
  • Thomas F. Schneider May 11, 2010
    Tuenoff the main break.Dissconnect the power leading to the box by either a outside disconnect or by removign the meter.  Tighten the main box disconnect and the reinstall the pannel front. Reinstall the meter or turn back on the outside disconnect.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Have you tried to clean the contacts and pry them so that they have a nice grip with the connection
Posted on Apr 22, 2009
Hi. I have a paragon 4001-00 timer hooked up to my pool filter. It's worked great for the last 25 years but recently it has become finicky. It will always turn off, but sometimes it won't turn...
If new X2772 tripper hasn't solve problem, it might be time for new timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4001-00 is 120Volt single pole single throw timer in Nema1 indoor enclosure
Wiring terminals 1 2 3
Black Hot wire from breaker connects to terminal 1
Black wire going to load connects to terminal 2
White neutral wires connect to terminal 3
Crossover Intermatic timer is T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Wiring terminals A 1 2
White neutral wires connect to terminal A
Jul 06, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Lights get bright then dim over and over can hear buzz noise from box where the main is
Sounds like a loose connection or overloaded breaker, Please call a Electrician due to high voltage in box
Dec 20, 2010 | Siemens 200 Amp Main Breaker 30 Spaces 40...
Low voltage in 110 recepts. and 110 in 220 outlet, could 100 feed breaker be problem. breaked is 25+ years old
The breaker could be the problem. I take it that you have a meter, you can pull off the panel cover and check the line side of the main breaker ( the side from the power company) be VERY carefull as you cannot turn of the power to this side of the breaker!!! Form one wire to the other on the breaker you should have roughly 220 volts. From one on the breaker to the ground/nuetral bar you should have roughly 110 volts. I f you do not have 220 across the two wires on the breaker its the power company you need to call if the 110 voltage is not right you may have a loose ground/nuetral... Just be VERY CAREFULL!!!! Hope this helps you
Dec 05, 2010 | Siemens 100 Amp Main Breaker Renovation...
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
I have a Casio fx4500 calculator and have replaced both batteirs with the new ones but it still says low battery everytime i turn it on.what seems to be the problem? Thanks
Seems to be a common problem on this otherwise great calculator that helped me through both high school and university. I've had mine for nearly 20 years and this problem showed up a few years ago. But I remember classmates reported the same problem when it was almost new.
If replacing batteries isn't helping, the problem is most likely caused by oxidation on the springs connecting the battery holder to the main PCB. The solution is as follows:
1. Remove the metal back cover (2 screws)
2. Remove the plastic back lid by removing the black screws (leave the batteries mounted) and CAREFULLY slide the back lid to the lower end (where the EXE button is located). Do not lift while sliding until the lid easily comes off.
3. On the back side of the plastic lid, very carefully bend the the two metal connectors ~1 mm on both batteryholders to increase their tension.
4. Clean the connecting pads on the PCB and the metal springs with de-oxidizer solvent.
5. Re-assemble and your 4500P calculator should be good as new.
Sep 04, 2009 | Casio Office Equipment & Supplies
Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Jul 14, 2009 | Siemens /ITE 100Amp 2-pole molded circuit...
Having problems with siemens arc fault breakers tripping
check to see if ground is connected or netural is loose
Mar 19, 2009 | Siemens Seimens Arc Fault Breaker
No electricity in all bathroom outlets
you may have agfi outlet in the circuit. the outlet has 2 push buttons in the middle. it maybe an outside outlet that is tripped some contractors hook up the circiut like that
Mar 09, 2009 | Siemens Electrical Supplies
Main breaker tripping
get acceess or rent an amp clamp meter with a "max hold" and clamp it on each line wire coming into the box (if you're not experienced in this hire an electrician being tht it can kill you if not done correctly and safely) when it blows check amps to each "leg" and see if it is over 200 amps. if it is under, the main breaker should be replaced . If it is over, clamp it on the "hot" side of each
circuit that you suspect may be pulling too much. If this all comes out ok, have the main service connections to the main breaker checked for being tight. This is a last resort, but I'
ve seen them heat up from being loose and then throw the main. The over all amps could be pulling too much, but it takes alot of things running at the same time to throw a 200 amp main.
Goodd luck!
Jan 15, 2009 | Electrical Supplies
Not all Breakers in Breaker Box working,
POSSIBLE THE BREAKERS ARE WORKING AND THE NEUTRAL IS OPEN , MOVE ONE OF THE WIRES FROM A BREAKER YOU KNOW TO BE WORKING ,THEN REPLACE IT WITH ONE THAT IS NOT IF CIRCUIT COMES UP THE BREAKER IS NOT WORKING IF IT DOES NOT THE PROBLEM IS THE NEUTRAL WIRE FOR THAT CIRCUIT MOST WILL BE WHITE WIRES ENTERING PANEL , IF THE BREAKER ALTERNATE WORKING MOVING DOWN THE BUSS SAY #1 WORKS #2DOESNT #3WORKS #4 DOESNT ECT ON THE SAME SIDE OF PANEL YOU HAVE A DEAD BUSS ,CAUSED BY BAD MAIN OR THE FEED FROM METER BASE ,THEN YOU SHOULD CALL ELECTRICIAN
Nov 15, 2008 | Siemens 200 Amp Main Breaker 30 Spaces 40...
Siemens 200 Amp Main Breaker 30 Spaces 40 Circuits Logo
288 people viewed this question
Top Siemens Electrical Supplies Experts
Steve
john h
Mike
Are you a Siemens Electrical Supply Expert? Answer questions, earn points and help others
