Question about Sewing Machines
Price and avaiability of cam stack and where from??
The top cam in the cam stack has two small cracks.Where can I get a new stack and at what price NECCHI LYDIA mk 2
    Problem Solver:
  • 16 Answers
The camstack stack gear for your sewing machine runs about $110 you can find it at www.parts4sew.com
Posted on Feb 28, 2010
  • 632 Answers
A good place to start for parts is in ebay under sewing machines specifically your brand and model.
Posted on Sep 24, 2009
Hello i'm french and my english is very bad sorry... how to change cam gear in bernina 730 please. Rick says he knows that . have a good day jp
This series are prone to cracking the cam gear. Search Bernina cam gear at www.ashleyandthenoisemakers.com and there is a full example with pictures on how to do it. Try ebay for the gear. Check prices.
Nov 06, 2015 | Bernina Sewing Machines
Supply of new stitch cog for Bernina 830 Record
I don't know what a stitch cog is by your definition but I suspect that you may be referring to the cam stack worm gear, part # 310 007 03. These gears are available, however those produced and sold as after market parts online have ranged from bad to very bad. I would suggest that you find an OEM part (not a reproduction) that are still available from time to time on EBAY etc.
Changing the gear is not as straight forward as it may look. The proper replacement requires: 1. removal of the cam stack without damaging the machine parts, 2. removal and installation of the new gear with the correct alignment of the individual cams, 3. installation of the cam stack and pattern indicator without axial play, 4. correct parabola timing of the main-shaft worm wheel and cam stack gear, 5. synchronization of the zigzag and automatic cam parabolas, 6. pattern indicator timing, 7. checking and adjusting the automatic needle position. SewTechnical Home
Jun 14, 2014 | Bernina Sewing Machines
I have a Viking 6370 sewing machine. I can not get the stitch selector to turn to select a new stitch. Actually the knob will turn but the outer dial doesnot turn and the stitch does not change. It sews...
Hello
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
Jul 12, 2011 | Husqvarna Viking 1
Viking Husqvarna Model 6020 stitch selector will not turn.
Apr 23, 2010 | Husqvarna Viking 1
Replacing the cam-stack in my Viking 6440
The cam stack can come out quite easily but putting it back in has some danger to it. The screw that holds the mechanism guide pin is somewhat tricky to get back in and if you cross the threads you've ruined your machine because the part is no longer available that the srew goes through. If you cross the threads it pitches the guide and your dial on the front of the machine that selects the different stitches won't work. If you shine a light in the back of the machine you can see it the camstack is cracked.
May 30, 2009 | Husqvarna Sewing Machines
Replace Gear Stack Cam on Bernina 730
This is a very common problem with these machines. First of all you have to have a new camstack gear. Then you may need a tech to do it. The gears can be found for purchase on the internet with a search. If you feel you want to do it yourself contact me and I'll tell you how but its very involved and many things have to be done just right for it to work.
Rick
Apr 11, 2009 | Bernina Bernette 75
Singer 600 stitch selector will not work properly
Get a copy of your manual at singerco.com for free to download
Dec 03, 2008 | Singer 3116 Simple
Sewing Machine Problem
Check to see if the cam stack gear does not have a crack in it. The other problem is the cam engager lever is does not engage the cam stitches because it is gummy. To solve this, lift the lid and follow the lever to where it make contact, add a penetrant oil. More the lever back and forth as fast as you can and work the penetrating oil into the area. It should click back and forth and snap between the back and front V's. One is for the zig zag and straight stitches and the other is for all cam patterns. Once it is clicking and snapping back add regular oil. Thensew out your pattern stitches. If the machine binds then you could have a cracked cam stack gear and has to be change by a Bernina service center.
SewTechnologist
Apr 18, 2008 | Bernina Activa 130
Broken Cam in a Husqvarna 2000
You can find a video on how to do this at Sewingnz Youtube channel playlist
Jan 28, 2008 | Husqvarna Viking 1
Sewing Machines Logo
205 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
