Question about Emerson EWF2703 27" TV
Help with my tv
When i turn on my tv after about 5 minutes the menue pops up and then the tv starts turning the volume down by its self and when u hit the menue button on the romote or tv it will still continue doing the problem and i have took out the batteries from the romote control and it still does it and i have unplug the tv and it still does it
Your ghosts dont like you
Posted on Dec 31, 2007
My COby tv wont turn on.
I unplugged my TV for 5 minutes after 5 minutes I pressed the Power button on the side of the TV not the power button on remote for a full minute. Plugged the TV back in, pressed the power button and it turned on. Doing this essentially does a reset.
Dec 26, 2016 | Coby Televison & Video
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
Menu pops on and off for about a minute when i first turn the tv on
the self diadnostic program in the tv is going bad.. may be time to replace the tv or dont shut it off completely
Jan 21, 2014 | Samsung LNT4665F 46inch 1080p LCD HDTV
Mitsubishi big screet HDTV after being on for a minute, the scree pops and goes black with some red lines, then the volume turns all the way up by itself.
Do the self check----if set has been unplugged plug it in and turn on for it to fail----when it shuts off ON THE FRONT OF THE SET press and hold both the menu and input (device) buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like, 1 blink, 2 blinks and pause and repeat it for a total of 5 times.
What if any error code do you find?
Jun 16, 2012 | Mitsubishi WS-55513 55" Rear Projection...
What causes the TV to go on and off when first turned on, until it warms up for 5 to 10 minutes
Try turning the volume all the way down then power the TV an see how
long it takes to bring a screen up if you still hear a popping sound then you have a bad part with a bad connection most likey a lamp and wiring.
Call to have it serviced a must if so.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
9 blinks,won't turn ON, but I can make it turn on with diagnostic
I'm suprised with nine blimks the set will turn on at all. You are in the service menu; be careful, you can render the set totally unusable if you change something. Try unplugging the set for a few minutes and plug back in.
Mar 30, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Picture Refresh Problem
Used Panasonic Concierge Chat and they had me do this:
press volume down on the TV (not the remote) and then press menu on the remote for 10-15 seconds to bring up a check screen. After that, unplugged TV for one minute. Plug TV back in and set up for Home. Can exit out of the rest of the set up. So far so good......this was happening only periodically for me, so we will have to see if it works. I was also having to go to TV Video and select Component 1 (cable for me) every time I turned on the TV, but the above action fixed that. Now it goes to the input that was on when the tv was last turned off. Concierge is free. Very cool.
Jun 09, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Emerson EWF2703 27" TV Logo
114 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
