Question about Dell E173FP 17" LCD Monitor
White screen on monitor
I have a Dell 17inch flat screen. It is about 4 years old. The system (tower) is fine but the monitor frequently turns to a white screen. Sometimes it will come back after being turned off for a few hours. Right now, it is white and has been for 3 days- despite being turned off most of the last 3 days.
  • k_ochoa Apr 22, 2009
    Windows XP. I have a Dell.
  • Dwayne May 11, 2010
    what is your operating system?
  • 89 Answers
O cant suggest anything appart from buying a new one sorry.
please rate my help to you.
thank you
Posted on Apr 22, 2009
I just bought a flat screen monitor 15 inches and have a acer tower. I have a dell monitor now but want a flat screen will they work together
it should work just fine ..... if not identify the connector DVI- VGA- Etc.but in most cases monitors and towers are pretty compatible
Aug 26, 2012 | HP Vs17 17" LCD Flat Panel Monitor
I have a Dell 15"
You need a new driver for the monitor. Are you now using a new Operating System? Perhaps Windows 7? Go to the http://dell.com websit and look up your monitor under downloads and drivers. Fidn the compatible driver for your operating system and download it.
Dec 31, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
May 28, 2010 | Dell Dimension 2400 PC Desktop
My dell S1709W flat panel monitor turned white
http://support.dell.com/support/edocs/monitors/S1709W/en/ug/operate.htm#Using the Front Panel
NOTE: You can also lock or unlock the OSD by pushing and holding themenu-logo2.gifbutton for 15 seconds. (Top of the buttons on right side)
Apr 07, 2010 | Dell Computers & Internet
Hp vs17 has white screen at boot. I have eliminated the chord from the tower and the tower works fine. I have audio, no video. Only a white blank screen. It does not blink or flicker. It just stays white....
There are three choices here...bad screen, bad connection, or bad video card, if the card is integrated onto the motherboard, then that part of the motherboard could be bad. If you have access to another monitor or a TV with a vga input, try the computer with another monitor. If you get a signal on that other monitor then you know you either had a bad connection with the other monitor or you lost the screen on the old one. Go back and reseat your video connections with the computer off. Don't ever remove or move cables to the monitor and video with the computer running...the screen can suffer permanent damage. If there is no signal on any monitor, then either you have a bad vga cord or your video graphics card had died.
Nov 11, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Dell 17inch flat screen monitor will not remain on, the screen go
If your Dell monitor still under into warranty, better to call Dell technical support and have them replace your monitor coz there is no way you can fix on it.
If the monitor is beyond with the warranty already, better to but a new one than taking it repair that will cost you much.
Thank you.
Oct 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
My 15 inch Dell LCD flat screen monitor has 4 blue (cyan) verticle pixel bands about half an inch wide on my screen. The monitor is about 3 or 4 years old. Can you help?
Sorry, but it's kaput. Broken. LCDs were pretty bad a few years ago. A new one will cost a lot less than that one did, and will work a lot longer.
Oct 01, 2009 | Dell 1505FP 15" LCD Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Oct 20, 2007 | Dell E173FP 17" LCD Monitor
Dell 17inch LCD Display - Blank
Hi, My name is Todd and I'm a customer advocate at Dell's corporate headquarters. My team helps customers via blogs, forums, and other tech sites online. You said the monitor is 2 years old. Do you have the original order number still? Depending on how you purchased the monitor it may have up to a 3 year manufacturer warranty and I may be able to replace it if it is within that warranty period. Please email me at Customer_Advocate@Dell.com if you can locate the order number and I'll be glad to see if its still under the manufacturer warranty. Include my first name (Todd) in the subject line of the email so it can quickly be routed through to me, and include the order or customer number if you have it. Thank you, Todd Customer Advocate Dell, Inc. http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Apr 25, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
400 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
