No Internet My mom's laptop was connected to the internet for the last 4 months but while she was online yesterday the connection just stopped and everything i tried didn't work. It tells me that it can't find the adapter for the wireless network. also it says that it can't find any network available when its right in the next work.
  • dleeann Apr 22, 2009
    tried both of those and didn't work however i did unplug my comp from internet and pluged my moms in and she was online and i was off so i think its the router
  • Leng Yang May 11, 2010
    What kind of internet do you have (dsl, cable, 56k/phone)?
    If it is cable or dsl, try unplugging the modem and replugging it back in. Also if you are using a router, do the same to that as well. See if that helps.
  • 3,866 Answers
Try reloading the drivers to the radio sometimes they get hosed in the registery. then reboot and see if you can find the network again.
Posted on Apr 22, 2009
  • 2 more comments
  • Grand Canyon Tech
    Grand Canyon Tech Apr 22, 2009
    Can you explain how that get a bad rating please update your rating..
  • Grand Canyon Tech
    You should refrain from giving us a bad rating just because it did not resolve your issue Reloading the drivers could allivate most of your problems I do not understand why you would put that type of rating please help me help you. Thanks
  • Grand Canyon Tech
    Grand Canyon Tech Apr 23, 2009
    Ok if its the route try opening up 192.168.0.1 go to the wireless setup and make sure that you have your web keys correctly, also one other thing if you would change your rateing on me as I am trying to make effort to help you with the little information that was given the first time thanks
  • Grand Canyon Tech
    In the setup of the router you want to open it up for more computers by adding more WEB keys please try to make sure that you are going to 192.168.0.1 type in the password is admin change those settings will shore up the problem and please adjust your rating.
Lenovo G550 running Windows 7 won't connect to internet. "Default gateway is not available" message displays. I have 4 Vista computers using wireless connections all functioning fine, but this...
Hello
Wow youve done almost everything here.How about the firewall? is it blocking any connections?
Next,Go to control panel,network and sharing center.Look and see if the pc or laptop in question is on the same network,meaning home or public.
Set all your machines to the same network.Either home or public.I do know this has been a win 7 problem.
Mar 11, 2011 | Lenovo G550-29583AU Notebook
My laptop is 2 months old and suddenly cannot connect to the internet. i have mobile and wireless internet and neither works for my laptop. Connectivity is fine for other PC's in my house hold.
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps don
Feb 27, 2011 | Acer Aspire 4520-5582 Notebook
Cant connect ,no light on wireless connection. was
you need to setup the wireless connection if you havent already and your router needs to be a "wireless" router in order to create that type of internet connection. Have you laptop then scan for one which would be the one you just made and input the correct information to connect. If that doesn't work I'd suggest getting a new wireless router
May 06, 2010 | Belkin F5D8236-4 Router
My laptop is connected but can't get on the internet. The modem light on the router is blinking orange. The globe is not lit at all. It worked fine for about 4 months until yesterday. I have unplugged both...
go to my connection and check if the wireless was available or connected, if not availale, that means some files of the driver are corrupted. Run your recovery disk.
Nov 22, 2009 | Belkin F5D8236-4 Router
Internet connection lost..
Firstly try the Off Line option, sometimes this can be ticked. Or go into the Netword Card settings and try to force the speed to auto config, this will enable different speed connections
Jun 02, 2008 | D-Link DFE-528TX Network Adapter
Internet issues with Cable Modem
yes..it's most likely in your network connections settings. open up control panel, go to network settings, and add a new internet connection. follow instructions, and see if that helps
Mar 07, 2008 | Acer Aspire 5100 Notebook
Sierra aircard 875u connect to Playstation 3
ok guys ive found the solution. i have a sprint usb aircard and had the same problem for like 6 months and just yesterday i found out how to make it work.
1) connect laptop/ CPU to internet as usual*
2)go to control panel
3) go to network and internet connections
4)go to network connections
5) next tight click on you internet provider thing. and go to properties.
6) click on advanced tab
7) then just follow the instruction to make it a shared connection and thats all to it.
fyi: its probably going to lag alot if your not in a good reception area. other than that the lag is bearable.
ps: if you need more help, or if you just want to say thank you email me at : Carlosl70n@yahoo.com
Dec 27, 2007 | GoAmerica Sierra AirCard 300
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
