SOURCE: amp error
The only solution I, personally, can help any of you with is to buy a good working model. i.e. Mine! I am upgrading to a 7.1 Onkyo and do not need mine any longer. Send me an email and I will gladly sell it to you! $75 (no remote) But you already have one so... ([email protected])
SOURCE: Pioneer VSX-35TX , "Power Off Message" , will not stay on.
It's probably going to need output transistors and some resistors, it's a job for a technician. A rough estimate on price is $100 to $130 (that's parts and labor). Before the smoke it may have only needed repair of bad connections.
SOURCE: i turn on my Pioneer VSX-D509S 5.1 surround amp
Disconnect all your speaker wires from the back of the receiver and turn it back on. If it shuts off, you need to have it serviced. If not post a comment and I can walk you thru troubleshooting. Hope this helps
SOURCE: when i turn on the
This could be a short on one or more of the speaker cables. I suggest you remove all speaker cables and try the amp again. If it does not switch off this would indicate a short on a speaker cable, so turn it off again and reconnect one speaker cable and try again. Do this with each cable in turn until the problem re-occurs, and you have now found the offending speaker cable. Check it for shorts at both ends.
This may not be the problem, of course, but should be your first investigation.
SOURCE: Pioneer VSX-D712 Standby light just flashes.
Hi morowk, did you find out how to solve this? I have the same problem
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
