Question about Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook 8.9? will not turn off
My acer will not turn off through the start menu,
Manual turn off is ok
I have Acer Aspire one D255-1549, came with Win7 starter. I also have a second boot partion that I deleted and merged the HDD space in starter. dual boot menu still starts on boot up. how to turn it off?
Hello Bob A,
1. Click Start
2. Type msconfig
3. Click boot tab at top
4. Delete boot option you would like to remove
5. Click OK, now you are done
Aug 21, 2013 | Acer Aspire One Netbook
Restore to factory settings
The Acer Aspire One is a netbook, not a laptop.
A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop.
It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature.
You can reset the Acer Aspire One to factory settings just using your keyboard.
Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive.
Go to "Start" > "Restart" to reboot your netbook.
Hold down "Alt" and "F10" when you see the Acer logo on the screen.
The recovery menu will load.
Hit "Enter" and then "Next" to see your recovery options.
Choose "Factory Restore" to set your netbook back to factory settings.
Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears.
Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
Jun 13, 2013 | Acer Aspire One Netbook 8.9" Notebook
Aspire one needs rebooting no disk
The Acer Aspire One is a netbook, not a laptop. A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop. It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature. You can reset the Acer Aspire One to factory settings just using your keyboard. Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive.
Feb 14, 2013 | Acer Aspire One PC Notebook
I dont know how to restore my acer with linux back to factory settings
Jan 20, 2013 | Acer Aspire One Netbook 8.9" Notebook
I DONT KNOW HOW TO RESTORE MY ACER BACK TO FACTORY SETTINGS
Jan 20, 2013 | Acer Aspire One PC Notebook
Restore Acer Aspire ONE D150-1165 Netbook
On help and support menu, type restore system. You will get an option to what date your OS will restored. Make sure you decide the correct date ( when the OS is still working fine). Key in the date ( or choose the preset date) the enter. Wait for process done completely. Your OS should be restored now.
Jun 28, 2011 | Acer Aspire One D150-1587 Netbook
My netbook won't turn on, it will get to the black acer start up screen, then the screen will go black for a while and then it will go back to the acer start up screen again... I tried pressing f2 to see...
when you turn on the Acer Netbook... Continuously press F8 until you see a Menu... from there you can do Start Up repair, or what i suggest is boot to last known Good Configuration (this Menu is known as the Recovery Console)
Mar 02, 2011 | Acer Aspire One Netbook 8.9" Notebook
How to reset myacer to manufact setting
  1. Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
  2. Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
  3. Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
  4. Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
  5. Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
  6. Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
Nov 12, 2010 | Acer Aspire One Netbook 8.9" Notebook
Turns on (fans spinning, HD clicking), blank screen, no sounds
hi this issue is with ribbon cable it is connect between the mother board and your LCD screen. the cable required change. if you can change it OK other wise take it to nearest service center.
Jun 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
715 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
