Question about Dwin TransVision 3 Plus Multimedia Projector
My DWIN Transvision 3 Enhanced is 5 years old. Projector starts but lamp doesn't fire. Bulb looks good. Unit starts, whines, then shuts off in a minute or so.
  • 3,267 Answers
Please check the power supply to the lamp. Also the lamp after prolonged use, tends to get dimmer till it finally does not light up. This is due to infinite simile of gas released by the lamp which is generally un-noticed since the day-to-day difference is very marginal. But over long usage it becomes evident. I think if you change the lamp(first try it) with a new one should solve the problem.............sodeep
Posted on Apr 22, 2009
I have a Dwin TransVision 4 that is not working. It started out with us being able to watch a movie for about an hour and the bulb shutting down. I finally ordered a bulb from Dwin (at 458.00!!) and...
honestly it sounds as if a capasitor is overheating and once it overheats the machine is shutting off.... I myself would be able to look at it and see if this was correct or not. i am not sure how familliar you are with these types of things, probably best to take it in and tell them exactly what is wrong...
Feb 26, 2011 | Dwin TransVision 3 Plus Multimedia...
Plays for couple minutes or hours, then goes
Have you considered checking the lamp? It could be going bad.
Nov 15, 2009 | Dwin TransVision 3 Plus Multimedia...
Dwin transvision 4 projector lamp will not light even after changing the bulb. It also looks like Dwin went out of business. Any options to fix?
Call Interlight @ 219-989-0060 and read them what the part # is on the bulb inside the cage. They can probably supply you with the lamp and you simply reuse your cage.
They were able to do this for me
Mar 22, 2009 | Audio Players & Recorders
Replacment of bulb on dwin transvision 3 plus ceiling mounted
It is fairly simple. Take the unit down as you need to get to the underside. There you will see the retaining screws that hold the cover on. Remove these and open the unit. Inside you will see the bulb and mounting bracket. Off hand I don't remember exactly how it is held in place but there are a number of screws and a lead to disconnect to remove it.
Mar 09, 2009 | Dwin TransVision 3 Plus Multimedia...
Projector turns on but no light or image from lens.
The bulbs do not always look broken when dead. You say it is used often. The life of a bulb is around 1400 hours I believe. This normally equates to a year or two depending on your usage levels. Did you notice your image getting dimmer in the months before it stopped working? This would be a good sign it was in need of replacement. Are the lights flashing very rapidly or blinking slowly? If they are flashing very rapidly this indicated the bulb will not fire and needs replacing.
Jan 16, 2009 | Dwin TransVision 3 Plus Multimedia...
Dwin Trans 3 Shadowing at Edge
you'd need to remove the top from the projector. the light tunnel is between the colorwheel and the lens assembly. remove the metal frame from it. chances are it's falling apart. since the company's out of business, finding a part is an exercise in futility. time to trade up.
Jan 07, 2009 | Dwin TransVision 3 Plus Multimedia...
I HAVE DWIN TRANS3 PROJECTOR 3 YEARS OLD PROJECTOR STOPS WORKING IN 5 MINS, FIRST PICTURE GETS FUZZY AND NO PICTURE BUT SOUND STAYS ON, I ALREADY PUT NEW BULB BUT SAME THING
it's time to clean it out. the colorwheel might be going and if it doesn't spin to keep in sync with the dmd chip, the lamp goes out.
Nov 21, 2008 | Dwin TransVision 3 Plus Multimedia...
Bulb or power problem?
You have to order it on the website and they are terrible about getting back to you. Worste customer service in the world. Terrible
Jan 03, 2008 | Dwin TransVision 3 Plus Multimedia...
Dwin lamp turns off
I design and implement switching power supplies for the commercial lighting industry. I also own a DWiN Transvision and have opened it and worked on it several times. I believe I can answer this question.
The DWIN projectors use a proprietary switching power supply to strike the lamp and keep it burning. The power supply is extremely sophisticated and maintains tight voltage and current tolerances. This is important because the halides in the lamp are damaged by power supply fluctuations. The halides can often be seen in an unfired lamp, they appear as small specks of dirt or tiny beads inside the lamp envelope. When a metal halide lamp is struck, the halides (which are rare earth elements) vaporize and cling to the inner wall of the lamp envelope. The mixture of halide gas in the lamp is what determines the color temperature of the lamp, as well as the accuracy of the lamp across the entire color spectrum.
One of the ways that DWIN is able to deliver such great color is because they use a lamp which delivers this great color across the spectrum, but, as I pointed out earlier, can be damaged by fluctuations.
The power supply contains three switching sections and five references for such things as input and output voltage for each psu section, as well as overcurrent demands from the lamp.
From my experience, your lamp(s) are all exhibiting issues that require replacement.
Sep 25, 2007 | Dwin TransVision 3 Plus Multimedia...
Video then Black
the colorwheel is going bad and needs replacing.
Jul 27, 2007 | Dwin TransVision 3 Plus Multimedia...
Dwin TransVision 3 Plus Multimedia Projector Logo
89 people viewed this question
Top Dwin Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Dwin Office Equipment and Supply Expert? Answer questions, earn points and help others
