Question about Whirlpool Washing Machines
The upper agitator on Whirlpool Model LA9100XTW1 is not rotating
Just noticed the upper agitator section on my washer is not rotating and moving the clothes down into the water. I was hoping to get access to a Whirlpool repair manual for this model washer so I could disassemble the agitator and determine what parts need to be replaced. I found an ''Agitator Repair Kit'' (part # AP3138838) on AppliancePartsPro.com but am not sure it comes with installation instructions. I only want to do the disassembly process one time and have this item repaired correctly upon reassembly.
Thanks, Joe
    Scholar:
  • 126 Answers
To repair agitator remove the top of it < snaps on> then remove bolt from center and the agitator will split in middle. You'll find a center cogg with three arms remove this and replace with new one< the kit that you described is this part > and assemble it.The coggs are move freely to engage so you don't have to align them in any way.
Posted on Apr 22, 2009
My washer works fine just no agition goes though cylces just fine fills and drians fine but agitator does not move
80040 dog kit is all you need. The upper portion of the agitator has four dogs mounted inside. As the transmission moves the agitator back and forth these dogs catch the side of the upper agitator. This rotates the fins and makes the clothes tumble on top of each other forcing them into a downward motion. When the facing of the agitator dogs wear smooth the upper agitator will cease to function.
Video:
I have a service manual and more videos HERE
Feb 10, 2011 | Kenmore 24032\24036 Top Load Washer
Upper portion of Whirlpool agitator not turning
Your agitator dogs are worn out. Remove the agitator and seperate the upper section from the lower section. There are 4 small teardrop shaped pieces that are the agitator dogs. They have either come apart over time or at least the teeth have worn off them.
Post back with any questions. Please verify the model number. I couldn't pull up a parts list for it. I know the last digit should be a 0 (zero) instead of an o.
Thanks/Mike
Jan 07, 2008 | Washing Machines
Whirlpool washer (model LA9100XTW1)
Usually problems like this, you just have to take it apart and see. I can tell you a few things that will help though. It's not a deteriorating belt. In fact this machine doesn't have a belt at all, it's what is called "direct drive". The closest thing it has to a belt is a round piece of rubber in between a gear but that's near the motor and it's not possible for it to get inside the tub. In fact, it's hard for anything to get in there to stain clothes. Usually what causes this, is a build up of dirt, soap, mud, mold, etc that collects under the agitator and finally just gets enough to start releasing into the tub. It's pretty easy to take out the agitator and check under there, here's how.
To remove the agitator on a Whirlpool top-load washer, remove the solid cap or fabric softener dispense from the middle of the agitator. Then remove the white cap on the inside of the agitator. This might be stubborn, so just start off pulling gently and keep pulling until it comes out. Under that is a 7/16" bolt. Remove that and then the agitator will slide off the transmission shaft.
The only other option is removing the inner tub entirely, but that requires a special tool to get a nut off of the drive block, so that limits DIY repairs.
May 29, 2010 | Whirlpool Washing Machines
The center part that adgitates does not rotate as i think it should can i tighten it somehow
You need to remove the screw from the center of the agitator and pull up on the agitator from the bottom , to remove it . Seperate the 2 piece agitator , and replace the 4 agitator " dogs " . Reasemble . The " dogs " lets the top section of the agitator only move in 1 direction causing the clothes to " tumble " . OR , take the complete agitator to a parts house and they will install them for you .
May 27, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator spins in one direction
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you have a two piece agitator, the top section is only supposed to move one way.
See the section in the Sears site for the agitator dogs.
If the lower section only turns in one direction, the problem is likely in the transmission.
See the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Nov 07, 2009 | Kenmore 24902 Top Load Washer
Washer is not rotating fully during wash cycle
Some Kenmore washers have a two piece agitator. The lower section will rotate back and forth both ways.
The top section has "agitate Dogs" that allow it to rotate only one way (to keep the clothes moving downward.
If yours has a two piece agitator there shouldn't be a problem.
Oct 18, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Whirlpool Ultimate Care II washer that had developed a "wrap" sound coming from the agitator. The agitator had a loose fit at the top, and can be moved about a 1/4 inch from side to side. How do I...
Remove the fabric softner cup. Remove cover underneath it by pulling up on it. It just snaps in and has a seal on it. Remove the bolt and lift up the upper agitator. You will need to get an agitator repair kit from an appliance parts store. It has seals for bolt and cap,.thrust washer for the botttom of upper agitator , cam dogs and a new holder and plate. Be sure to take the model number with you.
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WHIRLPOOL TOP LOAD WASHER MAKING GRINDING NOISE FOR AGITATION
When you put the motor in did you replace the coupler between the motor and transmission? When fixing the agitator you need to get the agitator repair kit, It has seals, dogs,thrust plate, cam bearing and seals. The upper agitator is supposed to move only in one direction to get the clothes to move down towards the agitator. Do not overload machine. I have one of these and after 12 years I finally had to install this upper repair kit because the upper agitator quit moving. You may have an agitate cam that is going bad inside the transmission
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool GSQ9632LW0 problem
looks like the agitator dogs are broken. these are the pieces between the bearing and the top of the agitator. since this agitator is a 2 piece, you can just replace the dogs.
go to www.whirlpoolparts.ca and put in your model #. it will give you a parts breakdown.
hope this helps.
c
Sep 23, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
386 people viewed this question
Dan Webster
Dan Webster
Sal De
