Gateway 831 GM
Same situation. I came in the other day to use the computer, said windows was shutting down but was frozen. I turned of the power and tried to restart but it would rev up and then off for several times and now dead. Replaced power supply and still nothing. I guess mother board is the next step. Let me know if anyone has found a solution.
Thanks,
Dan
danmercer214@hotmail.com
  • 3,866 Answers
If the power supply was not the issue try memory,cpu and the motherboard..
Posted on Apr 22, 2009
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
I had a fan making a clicking sound & a Friend cleaned it & now it turns on but nothing on the screen, what is messed up? where can I find parts to fix it? This is on my Gateway 831 Gm it has a...
Hi jdr_dlr519!
Pardon me.... but did your friend connected the monitor cable correctly on the system unit? Cleaning the fan will not break your computer... however, if he forgot to disconnect the power cables before opening the unit, it may do a damage.
Jul 20, 2011 | Gateway 831GM PC Desktop
Old power supply no good. bought this dynex 400 watt atx cpu power supply and need to know how to connect wires as there are some plugs that can go in multiple spots.
as long as you have the 20 or 24 plug in and the 4pin square plug in plus the hard drive dvd floppy fans i donot no your motherboard or graphic card so i cannot say anymore only next time write down your conections before removing power supply or get manual for your pc
Jul 30, 2009 | Dynex 400-Watt ATX CPU Power Supply
At about 3:00 am on thursdays, Windows XP closes and C drive shuts down. It is not a re-boot because the motherboard power stays on. When I turn the computer off and turn it back on (the 1st time)it...
Sounds like the computer is coming from sleep, standby or hibernation mode. Go to the power settings in the control panel, and disable all of these options. Disable your screen saver as well. Leave the machine on for a day and see if it happens again after this. Post your findings, please...
Mar 12, 2009 | Gateway GT5056 PC Desktop
Gateway 831GM Video card
The 831 only supports 2 gigs of ram any more and it wont start. You can probably fit a 9800 in it but would be a very tight fit.
Nov 30, 2008 | Gateway 831GM PC Desktop
Frozen laptop
According to the manual
Using Emergency Shutdown Procedures
If the notebook does not respond to the Windows shutdown
procedure (Start > Turn Off Computer > Turn Off), try the
following emergency shutdown procedures in the sequence
provided:
■ If the notebook is running Windows XP Professional: Press
ctrl+alt+delete. Select the Shut Down button, then select Shut
down from the drop down list.
■ Press and hold down the power button for at least 4 seconds.
■ Unplug the notebook from external power and remove the battery pack.
Apr 14, 2008 | Compaq Presario X1000 Notebook
Gateway 831 GM won't boot up no signal is showing in the begining
ram,
It sounds like the problem is either your power supply OR the motherboard. A power supply swap doesn't take long or cost much.
On the other hand, replacing a motherboard takes 30 minutes or longer and can cost upwards of $100!
Please let me know if this helps. Good luck!
Mar 01, 2008 | Computers & Internet
Gateway 831 GM
Make sure that there is not a power switch on the back of your computer. Alot of computers have a power switch on back of the power supply as a master shutoff.
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
