Question about Garden
Pullstring pulled back...HARD..to engine
The pull string is yanked back toward engine after pulling to start.
2 Suggested Answers
  • 86 Answers
SOURCE: Pullstring pulled back...HARD..to engine
You have a partly sheared flywheel key that is making engine out of time replace flywheel key
Posted on May 09, 2009
I have a stihl fs 80, the starter cord will not retract after the first pull. The spring is still intacted but doesn't spring back when re-attached to weed eater.
One of 2 things come 2 mind, if the spring is still in tact it could be that the retract line might be slightly to long and forces the spring to over travel and lock up against itself. A simple test would be to pull the pull start to only 80%. If at 80% it retracts normally then shorten the pull string by a few centimeters . alternatively the spring may be over tensioned by a turn or two. to release pull the string out with the pull starter off the machine to about halfway, hold down the recoil to release the tension off the string and pull the string out towards you through the slot provided on the face of the recoil into a loop. Gently let the recoil slip one full turn at a time until there is just enough tension to pull the handle all the way back. if its too loose just revers the process one turn at a time. its not complicated, to do but can be tricky,
if DIY is not your thing, refer to someone better qualified,
Sep 05, 2012 | Garden
My pull cord rips out of my hand
The string assembly should reach a point far enough out when you pull the cord that it lets it spin free of the engine. What you are probably experiencing is the engine kick-back, where the engine is compressing the air/gas in the cylinder, and the pressure pushes the engine back. The crankshaft is connected to the pull cord assembly, so it's pulling out of your hand. You may not be pulling hard enough, or the cord assembly needs replacing.
Aug 01, 2012 | 5.5 HP GX160 Engine
I have a honda gx390 13 horse engine I just put a new pull Rope on it and cleaned the carb its been sitting for 3k10 years when I pull the rope slowly it will turn the engine when I give it a good yank...
This is a common problem. The valves need adjusting in the motor. You may eventually get it started and running in this condition but you will probably end up breaking your pull rope a few times in the process. Take it to someone who works on small engines like a mower repair shop.
Apr 01, 2011 | Garden
How do I remove the agitator for my machine ? It is loose and spins fine, but makes a clanging noise when agitating counterclockwise during the wash cycle. It seems like I just need to tighten it down...
Anyone with loud scraping/clanging- we had that problem and saw that the large wheel the belt goes around is only an inch above the metal bottom.When we moved the washer with a 2wheeler it pushed the bottom up into the metal wheel. The racket it made was horrible. It left metal shavings ,too. You'll need to pull the bottom of the washer back out.Pull fromt panal off with putty knife.You'll need to lean or lay washer to one side.Put a pillow or cushion inside between the tub and housing side you'll be leaning towards. What I did was drill two little holes-one near the back center and one near the front center. I took a long piece of heavy string,put one end in one hole and the other end in the other hole-outside to inside.Tie the ends around each end of a 1x2,18inch board .Get the board to the back without damaging stuff inbetween-pulling on your back string for help. Make sure the board is against the bottom, get to where you can now pull your string 'handle' w/both hands,yanking and popping the bottom back out.Our washer now works beautifully and quietly.
Feb 12, 2011 | GE 3.2 cu. ft. Washer
When yanking on the pull cord to start engine
Im guessing that you have started it before, so I guess , check that its not flooding ,pull air filter out see If you can see heaps of fuel in the bottom hole ,if you do take spark plug out pull cord a few times without holding start cable or you will catch on fire replace spark plug try starting ,no start still flooding take it to a lawn mower place ,float may have a hole in it , if not flooding, on the bottom of the cardy one brass nut , four holes find them clear then, start also a brass pipe going into the center of the carby is probable blocked
Jun 18, 2010 | Mtd 22" Yard Machine Push Mower
My mower worked fine last week. went to start it and had no spark and feels like the self propel is still engaged. The pull string is hard to pull and the mower wants to go when pulling the...
hard to mow a lawn pulling the starter cord all the time,lol,,,ok, no spark...you have an engine control bar at top of handle, cable runs from it to engine brake, and this is also engine kill switch. sounds like this cable has stretched. this cable controls engine brake and also kills the spark. you have two problems, and this controls both.
Apr 29, 2010 | Garden
Where to get a new pull string for blower?
Any lawn & garden outdoor power equipment dealer
Lowes, Home Depot, Menards: get a recoil rope and handle for a Briggs push mower
Nov 13, 2009 | Homelite 'Yard Broom' Leaf Blower
May 06, 2009 | Mtd 22" Yard Machine Push Mower
Starter cord only pulls 1 foot
Most push mowers have 3 bolts on the side of recoil shroud. One in front, (where plug is) and two on side.
Apr 12, 2009 | Garden
Gas range, can't remove bottom oven panel - frigidaire FGFB55ASD
It pulls out toward the back or the oven. I usually lift it up as high as I can before yanking on it. If it is stuck, try sliding 2 small screwdrivers in the screw holes for more yanking leverage. As a lats resort, pry it out from the front; you may damage the finish this way. Hope this helps!
Feb 04, 2009 | Stoves Kitchen Ranges
Garden Logo
230 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
