Question about Bronica 50mm f/3.5 Zenzanon PS Lens
I have a Zenzanon-S 50mm 3.5 lens for my SQ-A. The speed are sporadically off. When I set it to 125th of a second it will fire properly 75% of the time. The other 25% it will stay open way longer than it should. Sometimes it seems like an 8th of a second sometimes it stays open for a second or two.
2 Suggested Answers
  • 3 Answers
SOURCE: zenzanon 80
Steve, it seems you don't much about the Bronica SQ series. The lens includes the leaf shutter. There is no shutter in the camera. (http://en.wikipedia.org/wiki/Bronica)
It's possible the shutter or aperture blades are being stuck open. a CLA for that lens might be necessary.
Posted on Jan 12, 2012
Zenzanon 80
The lens does not have a shutter - that's in the camera body. The lens contains the aperture or f stop adjustment. It is done by injecting or retracting blades in the light stream of the lens barrel between the front and rear optics. Check the aperture blades to see if they move easily and open equally by varying the f-stop ring on the lens while looking through it. If not moving all the blades the same amount or it does not continue to restrict the opening as you increase the f-stop value, there's something wrong with the lens.
Are you sure you haven't accidentally activated any exposure compensation adjustment on the camera body?
Jan 10, 2012 | Bronica 80mm f/2.8 Zenzanon-PS Lens
When I take a picture with my 18-55 on a d3100 I hear and see through my visor that the image moves and a sound like a click, many seconds after taking the picture. It seems like it's still open and closes...
Giving the lens your using and depending on the shooting mode your in. I assume your shooting in a low light situation. The lens you have is not good for low light shooting because the F-stop is only 3.5 at widest, so minimal light gets in so the camera decides what speed to set it at to close the shutter. for example shooting in the school gym or church, the camera speed will be 1/20 second or even up to 1/2 second to get enough lighting into the sensor so the image is properly expose but for you to have a sharp image you will need to shoot on a tripod.
Without tripod and just handheld will create blurry images. I would suggest you bump up the ISO setting to minimum to 3200 or higher that way the camera speed will be higher and reduce handheld shakes that will create blurry images. But remember, increase ISO will increase in image grain.
That is why I suggest you invest into a 17-50mm F2.8 lens for low-lighting or 50mm f1.8 lens.
I hope this helps
Jet
Feb 23, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Can u tell me how i fix error 99 of canon zoom lens 75-300mm
This article will lead you through the steps to identify the cause and a possible fix for this error.
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 12, 2010 | Canon 75-300mm f/4-5.6 III USM EF Lens
I have a D90 Nikon, I mounted my Nikkor 50mm 1.8d
Make sure you set the aperture ring on the lens to its smallest setting (largest f/number) and lock it. Without doing so, the lens will not communicate properly with the camera and thus you will not get the autofocusing.
May 30, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
I have a canon rebel xsi, with a 75-300mm zoom lens. And I'm taking lousy sports pics, indoors and out. Help!!!
For sports (or any fast moving occasion) you must be very particular about your settings. The Rebel Xsi takes great shots, but some tweaking needs to be done on your end, to make sure you don't get the "blur" and low quality that you may be experiencing.
On the settings dial, turn the mode wheel to "Tv". This is shutter priority, meaning you are controlling how fast the "shutter" closes. You need to have it set higher because you are trying to "freeze" a fast moving object.
After setting the selector to "Tv", you can change the speed by moving the "control wheel" left and right. (It's located above the ISO button, below the shutter button". If you look at your LCD screen while turning the wheel to the right (it makes a clicky sound), you will see the speed increase.
By default, it is set at 1/125th of a second. Increase it (1/200th of a second for example) and try that setting. You should freeze your target without blur.
If you are indoors and need a flash, the speed will max out at 1/200th of a second. Of course, if you need the flash, you will manually have to pop it up yourself by pressing the flash button when in "Tv" mode. It has a "lightning bolt" and is located near the "EOS" sticker on the front.
Hopefully this helps you. Let me know!
Jan 24, 2009 | Canon EOS Rebel XSi Digital Camera
Minolta StSi Maxxum
It's the shutter speed. I copied this out of the manual :
The number 60, or 125, displayed in the
data panel stands for 1/60th or 1/125th of a
second.
• Usable apertures will depend on the aperture range of the lens you are using. • The seconds indicator appears in the
viewfinder and data panel if the shutter
speed is one second or longer.
Albeit copy and paste made it fit weird into here.
May 27, 2008 | Minolta Maxxum STsi QD 35mm SLR Camera
50mm C lens issue
From your description, Yes. All RB67 lenses have common problems, usually sticky blades. Since there are 2 sets of blades, (shutter and aperture), the shutter blades may be contaminated with oil/debris
Apr 19, 2008 | Mamiya RB67 Pro SD Medium Format Camera
Bronica SQ-Ai shutter problem
There could be a number of issues with this problem. Make sure the contacts at the rear of the lens and those on the body that connect with those on the lens are clean and straight. If so, the problem may be in the shutter within the lens. There is a magnet inside the shutter that sometimes becomes contaminated and fails to hold the shutter blades open for the selected shutter speed. The face of the magnet may need to be cleaned. There are also timing switches that sometimes go bad or need adjusting. These internal problems need to be taken care of by a competent technician since the lens needs to be completely disassembled. I have also seen these shutters go bad and need to be replaced. Let's hope that's not the problem because it will be difficult to get a new shutter for the lens--but not imposible. God luck.
Apr 30, 2007 | Bronica SQ-Ai Medium Format Camera
Black Image
Are you taking these images with a flash? If so it is possible that you are shooting with a shutter speed which is too fast for flash photography. Anything faster then 1/125th (i think) on that camera with flash will produce the result you are describing. If this is without flash then the problem lies elsewhere. New flashes from canon have the capability to work with any shutter speed, but classic flashes only work properly at lower speeds. David Millier Advance Camera Repair
Feb 21, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Open Questions:
See all Bronica 50mm f/3.5 Zenzanon PS Lens Questions
Bronica 50mm f/3.5 Zenzanon PS Lens Logo
95 people viewed this question
Top Bronica Cameras Experts
Steve
Are you a Bronica Camera Expert? Answer questions, earn points and help others
