Question about GE GSL25JFR Brushed Steel Side by Side Refrigerator
Whining fan Where is the location of the fan in the freezer compartment for a GE side by side fridge freezer, model PSG22185 so that I can get rid of the annoying noise, (from the fan and the wife!!!) Thanks
    Scholar:
  • 126 Answers
In the rear of freezer upper panel must be removed to get to it,possible cause that something has been pushed against panel making fan rub or ice formed around it.Addres the cause of problem because fan is needed for unit to cool refrigerator.
Posted on Apr 22, 2009
Not cooling enough on frigerator side but it still works on freezer side.
Hello Mjorgy,
I understand that you are having a problem with you refrigerator. The freezer is cooling fine, however the fridge side is not cooling enough. This is a common problem with the evaporator coil stops working. When you open the fridge or freezer you should hear a fan running or fell are coming out of the vents to the fridge.
I would love to help you further if you can please post a model number for the unit I will look up where the fan is located and let you know how to get to it in step by step instructions. You should be able to locate the model number in side the compartments on the wall close to the front. It is also located on the rear of the unit. Please post back to this thread so that I may assist you further.
Thank you for choosing FixYa.com
Justin
Apr 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My 5 year old GE GSH22JSRSS Stainless Steel Side by Side Refrigerator recently stopped cooling. I noticed a build up of frost on the freezer, so unplugged the fridge and let the ice melt away. After this,...
The problem you describe is that your defrost circuit has failed. The fridge should stop the compressor periodically and turn on the defrost heater to melt the frost buildup. Since the frost in building up on your coils, the fan can't blow the cold air into the fridge compartment. It defrost is controlled by a module that turns on the heater. Most of these failures have to do with the defrost heating element burning out. It can be replaced by someone who has some mechanical ability.
The coil and heater is located in the back of the freezer compartment behind the panel in the back. You can obtain parts from appliance repair outlet or online like appliancepartspros.com or repairclinic.com.
Dec 07, 2010 | GE GSH22JSRSS Stainless Steel Side by Side...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Whining/howling on freezer side
Need to unplug the refrigerator and remove the cover inside freezer compartment. Sounds like the evaporator fan is hitting something and we need to resolve this as soon as possible. Thanks Sea Breeze
Mar 26, 2009 | GE Refrigerators
GE fridge runs continuousely
Simple! The replacement fan ran the wrong way forcing air circulation the wrong way. Fortunately it was possible to reverse the moter shaft.
Dec 11, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
Odor in GE side by side Fridge
Sounds like mold.  I'd try Lysol or one of the other products that claims to treat the odor cause in the air.  Spray a quantity into the empty fridge and freezer and turn it on.  Let the fans spread the stuff around. Try to find the internal vents which seem to pull air into the coils to spray into.
Nov 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge is whistling
Mine was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. I learned on this site that the motherboard was probably defective.
Rather than go thru GE, we found a new one online for 66 bucks. I replaced it in about ten minutes and it's all fixed. Poor materials on the original, but this site was very helpful.
Jan 08, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE GSL25JFR Freezer fan noise.
You are correct in believing the fan is going to be a problem. The evaporator fans inside the freezer compartment are common at going bad. I believe it is due to the extreme temperature and moisture conditions inside the application. The noise is the stator or bearing equivalent going out, the speed should remain constant. It may eventually make a screeching noise upon start up, or just lock up completely. The good news is replacements are relatively cheap and easy to find. If you do replace it yourself, make sure the fan blades are blowing in the right direction. If possible, remove the old one and bring it with you to the local appliance parts supplier and he should be able to help you get the right one, it will probably be a kit of some sort with multiple mounting brackets, screws, and maybe even a couple of blades. don't let this intimidate you. Most of this you will not use.
Dec 17, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Ge side by side - high low humming noise from freezer section
Sounds like its the evap fan motor to me. Not very easy to axcess. I have had one GE make the same noises you are describing to me. Let me know if you are going to attempt it and need more assistance
Nov 19, 2007 | Hotpoint HSS25GFP Side by Side...
GE GSL25JFR Brushed Steel Side by Side Refrigerator Logo
150 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
