Question about Acer Aspire M1641-U1521A PC Desktop
Cant connect to internet my isp says ipconfig
Cant connect to internet my isp says ipconfig isnt right model aspirem1610 problem started a while after i hooked up a wireless modem now i disconnected my router and go directly from the modem and it still doesnt work
    Scholar:
  • 39 Answers
Well, first thing I would do is wire everything up and not go wireless just yet.
So from the wall, to the modem, to the router, then to the computer.
If you don't have internet then AND (if you haven't already done so) unplug and replug the modem and router. And see if you have internet again.
What it seems that you were trying to do was do an ip reset within your system. (using ipconfig)
Basically, how you do an ip reset is as follows:
1. Hit Start button and go to Run..
2. In the space, type in the letters (no quotes) "cmd", and hit OK.
3. That will bring up a black screen (command prompt).
4. Type in "ipconfig" and hit Enter (make a mental note of what the IP Address and Default Gateway is)
5. Now type in "ipconfig /release" (letting go of that information)
*side note: if you were to do an ipconfig again, you would see all Zeros*
6. Now type in "ipconfig /renew" (acquiring new IP information from the router)
Try now to get up on the internet and hopefully all is well. As far as going wireless with this computer, you'll also need a wireless receiver as well to plug into the computer (via PCI slot or preferably USB) because you'll need more than just a wireless router for a computer (not counting "most" laptops).
Just make sure everything is wired up first.
Posted on Apr 22, 2009
  • 385 Answers
Let's setup DHCP then for you.
go to please...
start, control panel, network and sharing centre,
manage network connections, right click the LAN connection and choose properties, double click internet protocol ver 4, when the dialog box appears, check that you are configured here for
" obtain an I.P address automatically "
click this circle if not,
you are now setup for DHCP
auto I.P. address assignment.
reboot now.
try the internet now
Hope this helps
Regards
I have a compaq presario SR1303 Wm Desktop I wont connect to internet, stating that local area cable is unplugged, however this isn't true because I have another desktop same model that works fine...
If all looks good try right clicking on network status icon in sys tray and use repair. A more advance option would be to use ipconfig from the command prompt.
Start > Run (search in Win 7) > type ipconfig /release. Then ipconfig /renew. ipconfig ? will show you all the options. Good luck.
Aug 31, 2012 | HP Compaq Presario SR1303WM (PP150AAR) PC...
I have a Zhone ADSL2+ 4 Port Wireless Bridge/Router, model number 1518-A1-UK-0MA. it as working perfectly until one day when i turned it ON, only the ADSL LED is lit, no other LEDs are on, nor the power...
Please use the following steps:
1. Remove the router and connect it directly from the pc to the modem.
2. Power cycle: turn the modem off and then the computer for 30 seconds, then turn them both back on, modem first.
3. Check you internet connection to see if it working.
4. If it working, connect the router back up. If it not working contact your ISP for dsl support.
5. Once the router is connected, release/renew the ip address. Go to the dos command type ipconfig/release press enter. Then type ipconfig/renew. Check your ip address, you shouldn't get an ip address starting with 169. If you do, this mean you have a problem with the router getting an ip address.
6. Check you internet connection after the release/renew
Jun 10, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
Cant connect to the internet. shows being connected but cant go online still.
This sounds like a problem with your modem/router. To fix this easily i would recommend contacting your ISP (internet service provider) for direct help.
For another method, go to, Start button---> Run----> CMD---> ipconfig
when you type in ipconfig a bunch of numbers should appear.
Type in the Numbers into the address bar. If i am correct you should see your router settings. Proceed to check if you have a connection
if it does not say this proceed to calling your ISP.
Sincerely, Warlock
Dec 28, 2010 | Computers & Internet
Can't connect to the internet. get this error when IE diagnosis connection problem: "the DNS server isn't responding". My internet was working fine earlier today, and just quit working. Did an...
Try 'IPCONFIG /RELEASE', then 'IPCONFIG /RENEW', to see if your computer can obtain a new "lease" from your ISP's DHCP-server. If not, telephone your ISP, and get them to trouble-shoot from their end (peeking into your cable-modem).
Try power-cycling the cable-modem, and any wired/wireless router that is in the mix.
Dec 18, 2010 | Computers & Internet
Lap Top access - unable to access internet on lap top
1.Powercycle equipment (Unplug and plug back in)Wait 15 seconds then plug back in.
2.Check connections the Ethernet cord from modem should be plugged into back of router into internet port.
3.If modem runs off signal from a local tower and there is not sufficient signal on the modem you will need to contact your ISP ( Internet Service Provider) to check for outages if not skip to step 4.
4.Open your network connections window.
A.Windows XP:Start/Run/Type ncpa.cpl this will bring you to network connections.
B.Windows vista/7 Start/Search bar Type ncpa.cpl
5.Windows XP:Right click on Local Area Connection and click properties,
A.Click Internet Protocol and hit properties ensure Obtain ipaddress automatically and Obtain DNS service automatically is checked if not check both and close window.
B.Windows Vista/7 Right click Local Area Connection and click Properties, Uncheck Internet Protocol Version 6 and click on Internet Protocol Version 4 and hit Properties Ensure Obtain ipaddress automatically is checked as well as DNS server.
6.You will need to manually renew ipaddress if this does not work
A. Windows XP:Start/Run/Type CMD and hit enter,
B.Type ipconfig /release
Then type ipconfig /renew then restart computer
A.Windows Vista/7 Start/All Programs/Accessories/Right click Command Prompt and hit run as administrator.
Then type ipconfig /renew restart your computer
7. If this does not help run an Antivirus. Hope this helps Happy Thanksgiving
Nov 26, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I cant set up my linksys wireless-G ADSL, my laptop recognizes linksys but i still cant connect to the internet, when i clicked on troubleshoot to correct the problem, it says DNS isnt recognized
    Go to a cmd prompt. To go there, simply type cmd in the search. You can access it by going to your C hard drive, find Windows folder, in the folder locate System 32 - look for cmd.
When you are in cmd:
    Type IP config and see if you have an @ssigned IP in the range setup in the router. If not try C:\ipconfig\release then C:\ipconfig\renew Likely that this won't work.
    The steps I took were:
    1.) Go to Start/Control Panel/Network Connections. Right click on the wireless connection. Go to TCP/IP in the components section and click the properties button. Make sure Obtain IP and DNS address are both set to automatically.
    2.) I had WEP enabled, make sure your wireless card and the router are both set to the same encryption 64 or 128 and make sure they are both on the same channel.
    3.) Try C:\ipconfig\release then C:\ipconfig\renew again and hopefully you'll get an IP address.
Nov 10, 2010 | Cisco Computers & Internet
Cant connect to internet i keep getting connected with limited access
Check your modem. If it states Link or Internet active. Call your ISP and see if they see any issues.
Goto Start-> Run-> "CMD" -> enter.
Type "ipconfig /release" enter
Type "ipconfig /renew" enter.
If all else fails.
Unplug the Modem and Router.
Plug Modem in. Wait 2 mins. Plug Router in Wait 2mins. Restart PC.
Jan 12, 2010 | HP Pavilion dv6000z Notebook
1231 ping error using windows vista cant connect to the internet as a result
There are some suggestions here
http://forums.techarena.in/networking-security/1158484.htm
Try disabling ip version 6
and try an ipconfig /all to make sure all your settings are as you would expect.
Try pining the loop back adaptor 127.0.0.1
Then try pining your Default Gateway (value from ipconfig output)
Then try pining your DNS server.
Any other machines on your LAN you can ping.
This should help you narrow it down.
Oct 01, 2009 | Compaq Deskpro EN 6500+ Model 6400 CDS PC...
My acer is showing being connected but isnt cant pull up the internet wirless. using my husbands now. can you help?
Assuming this is XP, do the following:
Start > Run > and type this in ipconfig /release
Start > Run > and type this in ipconfig /flushdns
And then reboot and try connecting again.
Nov 30, 2008 | Computers & Internet
Edimax br-6104k
do you have apppoe connection or dhcp? release your ip address (ipconfig/release) set your modem to bridge mode then connect modem and router. try to connect.
marlon
Jan 16, 2008 | Edimax BR-6104K Router (br6104k)
Acer Aspire M1641-U1521A  PC Desktop Logo
168 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
