Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony 34 inch Trinitron TV
Hi I have a problem getting my tv to power on sometimes. I push power.. it tries to turn on...Then The standby light starts to blink fast and NOTHING...this same question was asked by another user on Sept. 14, 2007 but I did not understand the solution.
  • tvfan62 Feb 04, 2008
    I have a KV-34HS510. I turned it off with my control and then try to turn it on. I got stand by light and no video no sound.
    Thanks for any suggestion
Uplug and open the cover and look for the red cable coming out of the picture tube. follow this red cable to a small board where you should see 2 black screws labled focus and screen. try turning these a notch and power on. it worked for some people but not for me...:(
Posted on Oct 09, 2007
SOURCE:
Flashing green power light
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link.
Dec 07, 2013 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
TV won't turn on. Red standby light blinks
Samsung told me this was a common problem and I would have to have it serviced by an authorized repair facility.
My problem ended up being the internal power supply, but they also told me the main boards burn up.
Nov 06, 2013 | Samsung BN94-05038F Main Board for...
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
4 fast blinking lights
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Oct 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trinitron tube tv Standby is flashing and the tv wont turn on
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 06, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron won't turn on
this is the (OVP) over voltage protection,the unit goes into standby mode,there is a problem in power supply circuit,you need a ohm meter ,check T603 & R672.......you can get parts at Encompass Disturbution #1-800-638-3328 hope this helps.good luck
Feb 15, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
120 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
