Question about Haier Refrigerators
Our Haier HVW12ABB started making a loud humming noise. It started out doing it occasionally but now makes the noise consistently. I unplugged it and plugged it back in again and there is no change. What should I do?
daverh
  • 117 Answers
SOURCE: Makes a loud humming noise while operating
Almost certainly, the component called the "magnetron" has died. This is the valve (tube in the US) which actually generates the microwaves. The loud humming is the transformer that supplies the magnetron being overloaded and/or the magnetron itself. If the rest of the appliance is OK and not too old, the magnetron can be replaced. If you aren't familiar with these appliances, you *must* get this done by someone who understands the dangers of messing with them - if you get it wrong, they can bite! In some countries, only qualified engineers can buy the spare parts. In the UK, the part costs around £40 - £80, depending on the model. If the appliance is more than around three years old, it may be a false economy to repair it as other parts may fail soon after the repair.
Posted on Sep 24, 2007
SOURCE: Loud humming noise as fridge is running
Hey everyone-
I recently fixed a similar problem with my freezer. I searched first and found this and a few other sites which listed this and wanted to provide input for anyone in the future.
I have a GE GSH25JSRF SS. It is about 3 years old. Several months ago I noticed when the evaporator fan in the back of the freezer turned on it would make an awful howling or whistling sound. Basically sounded like what you would hear from the window of an older house if the wind outside was blowing real strong. It was loud enough to hear on the other end of the house.
I was convinced that it HAD to be the air blowing over the venting or a gap that created that sound. But I read different solutions on the internet and decided to take a chance on simply replacing the evaporator motor and attached fan blade. That solution worked and my house is quiet again, thank god.
I ordered the parts from a supplier on the internet. Keep in mind, though, if you're not real handy it may be more than you bargain for. Might be easier to have a service guy come out.
I'm still not sure exactly what aspect of these parts caused the howling sound. It could be a bearing within the motor or perhaps the fan blade slipping due to wear. Either way, it's fixed now. Just wanted to share. Thanks.
Posted on Jan 16, 2008
SOURCE: I have a Haier
J have the same model HVW12ABB, bought it a year ago, I don't believe keep the receipt still. The cooler suddently stopped cooling, tried troubleshooting and realized, the interior light was not workin either. Then I decided to check for any blown electronic part. I pulled off the back plate back, looked for any blown fuse, but nothing seemed like defective. A
Any idea?
Posted on Sep 08, 2008
  • 41 Answers
SOURCE: Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Posted on Nov 18, 2008
  • 4 Answers
SOURCE: 96 lincoln town car- loud humming noise
I had experienced the same problem with my 93 TC. I'll try to make it short. Replace the Idle Control Valve. Cost me $50 at AutoZone. It has a electronic plunger that has a rubber o ring on the end of it. It separates two air chambers inside the valve. When the rubber gets old and the plunger is suppose to cut off the air coming in from one chamber to the other, the air gets sucked between the chambers across the old rubber causing the humming noise. That is also why the engines revs up and down and wont idle right. It is located between the firewall and the back of the motor just to the left (drivers side) of the throttle control assembly. When you look up on the internet on how to replace it, it will tell you to remove all the housing surrounding the wiper blade control arms and assembly so that you can access it. If you take your time, just remove some of the hoses and wires connected around it and you can access it without removing all that ****. Only has two screws to it that point up and can be reached with a ratchet and extension. Car runs great now and finally got rid of that noise.
Posted on Dec 02, 2008
Why is my Haier washer making a loud high pitched noise?
No. The high pitched noise did not originate in the control panel but rather in a part of the machine that was chafing or rubbing against something. And now the mechanism is stuck. Check for that first before messing with a control panel.
Sep 16, 2016 | Haier Washing Machines
Fridge started to make a humming Unplugged it,let it sit for an hour,it was fine.water on the floor from the ice-and I unplugged it for the night.I got up shook it-worked for 2 weeks.
What sort of "humming" noise? Refrigeration systems rely upon vapor compression to operate -- meaning occasionally to maintain temp a compressor will kick in which can hum.
Sep 01, 2015 | Frigidaire Refrigerators
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
My haier dishwasher is not filling with water just making a loud humming noise
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Nov 11, 2010 | Haier Dishwashers
Is it normall for the motor to be loud?
compressor hums -working clanging not good
Oct 13, 2009 | Haier Refrigerators
Haier Wine Cooler motor died
Yes, those motors shoudl be pretty standard stock items at any local appliance parts supply house found in the yellow pages.
You might also try lookinmg under "motors and controls" in the yellow pages. If you get it locally like that then you can physically compatre the old one with the new one to make sure it is indeed the same part.
Thats better than an online link with just pictures.
Jan 27, 2009 | Haier BC112G Wine Cooler
Haier Model No. HSA04WNC WW/BPG fridgefreezer loud rumbling noise
Rumbling sound is not good. Check to see if it is making the noise with the door open. If so - it probably is a fan blade scraping. If it keeps making the noise - it is likely the compressor - either a faulty relay or capacitor. Or maybe the compressor is faulty. You'll need to be handy with a multimeter to check these out though.
May 30, 2017 | Haier HSA04WNC Compact Refrigerator
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Refrigerators Logo
135 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
