Question about Acer AL2223W 22" LCD Monitor
Plug it in with no input connected,press the
Plug it in with no inputs connected,press the power button and nothing happens.no power led. how do you remove the back cover to test for power?
  • Acer Master
  • 5,660 Answers
I suggest you don't.
There are no user friendly replaceable parts in there.
There May be an inline fuse in the AC circuit, but it's probably a circuit breaker. (Closest thing to a user friendly part, that you'll find)
I suggest you take it to a 'Mom & Pop' computer shop, and see if they will check for a blown fuse inside. The small qualified shops like these, have real computer techs, and not 'Geeks are Us'.
Plus they're cheaper.
If it isn't something simple like a blown fuse, or bad circuit breaker, it's probably the power board.
(Usually the front cover comes off, from loosening it on the backside)
The reasoning for dissuading you from opening the monitor, is that there are Electrolytic Capacitors inside.
They are designed to hold a charge for weeks, sometimes months.
Should you touch the terminals making a circuit, or touch the circuit they're in, and complete a circuit, they could release their charge to you!
This can easily result in a bad shock, or 'Put X's in your eyes'.
(The Electrocution warning on the outside is For Real!)
Posted on Apr 22, 2009
Magnavox 37MF23ID, would not turn on. Power button only blinks (green light). We have switched power cords and nothing happens. No picture, no sound.
if the power light comes on but the screen stays black, then your TV might be on the wrong input Channel. for example: you switch inputs when you play games or watch dvds vs. watching regular tv. Try to change the input
Dec 27, 2014 | Magnavox Televison & Video
My laptop was plugged in and lit up showing it was charging but when I pressed power button nothing happened. I unplugged from charger and no lights at all and pressed button and nothing happened. Is
plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
Feb 08, 2013 | Toshiba Satelite 4000CDS Laptop AC Power...
I have a RCA model 24V511T can I hook up a roku receiver to view Netfliks etc from the internet. I have hooked up the red white yellow connectors to the input ports on the tv set and nothing happens?
First of all, make sure all components are powered up and plugged in. Next, check that your tv is set to the correct input by pressing tv/video or input button on either the front of your tv or at your remote. Scroll through the inputs by continuously pressing the input button until the see the roku video displayed on your tv.
Good Luck
Jan 07, 2011 | RCA 24V511T 24" TV
My LG e2350 monitor won't turn on. When I push on the power button, nothing happens except that one of the light on the left lights up.
there's a button on the far left, that which when you press should light up the power LED. i know it's weird, but it does that.
just hold that for a period of i don't know how long, maybe 10 seconds til the power LED goes off. wait a while, then press the power button again. that worked for my friend's monitor that had teh exact same problem as yours.
you probably fiddled with the menu buttons before this. and pressed the "input" setting.
Dec 19, 2010 | LG Flatron L1515S 15" LCD Monitor
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
Panasonic TX-28PM1 TV shuts down after 2 seconds and then Standby LED flashes
Have you tried pressing the input selection button right after powering on the t.v.? Some t.v.'s go into standby mode when they are on a input selection that has nothing connected to them. Hope this helps some! Best of luck to ya!
Feb 15, 2010 | Panasonic Televison & Video
Toshiba A105 keeps Restarting ---
maybe the power input is error
the uncorrect power input will result bad
or, it's your mobo broken
Jan 25, 2009 | Toshiba Satellite A105 Notebook
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
My toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Dana
Jan 24, 2008 | Toshiba Satellite A135-S2276 Notebook
Acer AL2223W 22" LCD Monitor Logo
223 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
