Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher Model SHU43C02UC/17 consistently leaves film on glassware, leaves residue in the bottom of glasses in the back position of the top rack, and sometimes leaves gritty residue on dishes throughout the dishwasher. The stainless steel interior is also stained. I regularly clean the filter, use Jet Dry (the product that was included with the machine when I purchased it), and rinse the dishes before filling. The dishwasher has never cleaned dishes like the 17-year-old Kitchen Aid dishwasher that was in the house we lived in previously. We bought the Bosch to replace the cheap contractor's model that was in our condo when we bought. The Bosch was no improvement. Would I buy or recommend a Bosch? Never!!
  • 4 more comments
  • CVEG Feb 19, 2008
    ACTUALLY WE HAD THE SAME PROBLEM DIFFERANT TIMES,WE FOUND THAT THE ROTATING ARM WAS PREVENTED FROM GOING AROUND BY AN OBSTICLE IN THE DISHWASHER SUCH AS A PLASTIC SERVING SPOON STANDING UP IN THE SILVERWARE TRAY, TRY LAYING IT DOWN IN THE UPPER RACK
  • Anonymous Mar 20, 2008
    Everything has film on it...glassware, dishes, etc and stainless steel. Can't tell if soap door is opening or not. Rinse dry is full. Is running white vinegar through machine a good way to clean it and remove the film on stainless inside?
  • Anonymous Oct 08, 2008
    It doesn't clean anything. I run an infant daycare and I need the bottles, nipples, pacifiers etc., to be VERY clean and sterilized. Heck, I can't even get regular drinking glasses clean. Part of that problem comes from the fact that you cannot lower the top rack. But the silverware is NEVER clean, so you wonder if the damn thing is getting anything else clean, nevermind the water spots on every single glass whether I use Jet-Dry or not. I have tried powdered detergents, I've also tried gels (which I read were not a good idea because it causes problems with build-up of gunk in the pipes) but I've tried everything I can think of. NOTHING GETS CLEAN. It worked fine for about the first month I had it and for the past year and a half, I've had to wash the dishes by hand before I wash them in the Bosch dishwasher. It's a piece of junk compared to the old Maytag I had before. And we paid a lot of money for this hunk of junk, too, I might add.
    Next DW I get is going to be a double drawer Fischer. Yessirrreee.
    If someone from the Bosch company wants to help me out here, I'd be glad of it because I've tried everything I can think of ... and then some.
  • cactusue Jan 26, 2009
    My new Bosch, purchased in 2008, consistently leaves residue on the glasses. If I fill a glass with water after it has been cleaned by the DW, there are soapy bubbles in the water. If I rinse it out first with tap water, there are no bubbles when I fill my glass.
  • Anonymous Jan 27, 2009
    I have the same dishwasher and the same problem. It did work well for about two years, then started leaving film on everything. BTW, I use the Cascade recommended by the manufacturer as well as Jet Dry. I cleaned the filter and nothing improved. Now, I wash the dishes by hand and let them dry in the dishwasher. There is something wrong with this machine. Also occasionally, the d/w does not drain at the end of the cycle. We checked the lines, etc. and they were not kinked and the filter/drain was not plugged. Go figure.
  • candee33 Feb 01, 2009
    I have a 4 year old Bosch dishwasher just spent $250 on replacing soap holder and bottom rack slats the door and inside all have this scum on it the repai man said it was hard water I have never had this problem with any other dishwashetr I have owned. I have tried stainless steel polish the sum transfers to the glassess and flatware and I have to rewahs everything after using the dishwasher I want to contact Bosch my dishwasher is 4 years old. Its really frustrating me any one who knows how to solve this would be a life saver thanx CindY,Burbank, California.I think my Brand number is a different one.
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Posted on Feb 20, 2009
I have the same dishwasher and had the same problem. Add a cup full of vineger overnight in the dishwashe and let it sit. The next wash wil have your dishes sparkling clean.!!!!
Posted on Feb 25, 2009
  • 67 Answers
We were told by Bosch to not use lemon scent. Use the original generic soap with NO sprakle or smell because the jet dry does the rest. Just let the soap be soap. Hopes this helps.
Posted on Jan 07, 2009
Posted on Feb 20, 2008
    Problem Solver:
  • 19 Answers
Put the jet dry on#2
Posted on Oct 31, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Go to www.dishwasherfilter.com and buy there dishwasher filter. it works fantastic. it filters the water going into your dishwasher and solves the "cloudy, dirty, dishes look". it fits right under your sink and is very affordable. you will be happy you bought this product. i love it!!!!!
www.dishwasherfitler.com
Posted on Jun 05, 2008
  • Mike Jan 06, 2009
    There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at www.dishwasherfilter.com. Hope this helps some people.
SOURCE:
How did I get the film off my glassware? My glassware has a thick film that is very unappealing. I have to hand wash them. I use cascade detergent.
If you are not using a water softener use a rinse aid such as Jet Dry. This will help to eliminate scum on glassware. Use the solid form of Jet Dry. If you use a water softener you need to decrease the amount of detergent.
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is a hard water deposit and more detergent is likely needed. If the cloudiness is not removed it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. In actuality, dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Mar 12, 2011 | Whirlpool Dishwashers
My Bosch dishwasher is streaking the glassware, inside of the dishwasher and plastic utensils for the past couple of months. What is wrong?
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 14, 2011 | Bosch Dishwashers
Bosch Dishwasher leaves a sandy filmy residue on our glasses. Cascade Dishwasher soap is always used and dishwasher cleaner used about every 5 weeks. Dishwasher is run thru a complete cycle every 2 days. ...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 06, 2011 | Bosch SHX55M02UC Built-in Dishwasher
Glassware and utensils have cloudy residue after load completes
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 17, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
About a month ago, our dishwasher started leaving a residue on the glasses on the top rack. The problem has become much worse over time. The dishwasher is also making an unusual sound during one of its...
heatman101
Jan 03, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
#1 Dishes and glasses are not clean. Glasses come out with *** film. #2 Cascade gel soap residue in cup dispenser and on dishes close to it. #3 Not drying glassware in upper rack. #4 Black ***...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
DishwasherResidue and Film on Dishes
heatman101
Jul 14, 2010 | Kenmore 24 in. 17602 / 17604 / 17609...
Hello, Recently my dishwasher has been leaving particles of food residue in glasses or other glass items. This is a particular problem when using the top rack, but the problem sometimes is also on the...
heatman101
Jul 05, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My electrolux icon dishwasher leaves food residue in the interior of glassware and mugs. It has etched and left milky scratching permanent texture to all glassware. I have replaced glassware change...
heatman101
Mar 10, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Says model # shu9915 not cleaning well .leaving residue on glasses almost easier to wash by hand and some food stuck on plates etc. and soap tablets not dissolving completely
heatman101
Feb 14, 2010 | Bosch SHU9950 Dishwasher
Bosch dishwasher she58c leaves all my glasses cloudy
using to much soap will cause this problem.
If the unit can not get all the soap out on the rinse cycle, it will leave residue on the glasses.
ALSO:
1)Make sure you are using rinse-aid!!!!!
2) turn your sink water on before you turn the d/w on. That way the water is already hot when it goes in.
Sep 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
5,958 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
