Question about GE WBVH6240F Front Load Washer
Replace rubber gasket
Ge washer wbvh6240 fww
  • Anonymous Mar 20, 2014
    How do I find a repair manual for my he washer model number whdvh62
    6 Fww
  • 240 Answers
Gaskets are generally not replaced alot but do need maintenance occasionally. to replace is a little work. remove top cover, screws in rear and remove plastic rear control cover 3 screws. lift cover and pull out. remove screws holding control console and lift up to remove. remove lower panel, gasket spring clip, and door lock screws (in door opening). remove front panel screws lower then upper. door stays attached. there is another wire clip around boot at tub.
Being an active repairman, I have this machine at home and love it.
Posted on Apr 27, 2009
Replace the machine with a top loader and you'll never have a leaking gasket again! Worked at National Linen for a while and the floors had drains in them and were always wet! Needless to say the pros have the same problem you do! ;)
Posted on Apr 22, 2009
What is the part number for the rubber gasket or bellow for the GE front load washer Model #WBVH5200?
The door rubber gasket/bellow for GE WBVH5200J0WW/J1WW/J2WW/J3WW/K0WW is part number WH08X10036. The said part may look a bit different from the original one installed on your machine but it is an original equipment manufacturer replacement part and is equivalently functional.
Jul 18, 2011 | General Electric WBVH5200J Front Load...
My question is; the washer,model,wbvh6240 has any filter
No , all new front loads have a self cleaning filter. Therefore nothing needs to be emptied or clean. The little trap door in front of the washer is to drain it in case of a power failure when the washer is full of water. .
Mar 15, 2011 | GE WBVH6240F Front Load Washer
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
The rubber door gasket is torn, how to replace,
Get the model number off the washer
and go to appliance store who service or Sears
Jun 10, 2009 | GE WSXH208A Front Load Washer
Rubber seal, drainage seal on washer ruptured its about 3" thick.
being 3 years old you will not be under any warranty. as far as the parts go any appliance shop with your model # will be able to get you the correct part. none of the appliance parts stores go by part number as these are constantly changing for better parts from the aftermarket then what the manufacturer used. so again just take your model # and call a few appliance parts company or even repair shops will sell parts as well.
May 19, 2009 | GE WCVH6260FWW
Washer
I have notice this problem with a lot of front loaders. I would check the manufacture warranty to see with is covered and if you bought an extended warranty, use it, keep your receipts for your previous purchases.
Dec 11, 2017 | GE WBVH6240F Front Load Washer
GE WBVH6240F Front Load Washer Logo
460 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
