Question about Pioneer PDP-5080HD 50 in. Plasma HDTV
Plasma Screena growing yellow-greenish discoloration
I have been experiencing a growing yellow-greenish distortion in the upper 1/4 of the screen. It is most noticeable on faces and objects of a lighter color. I have a 50CMX Plasma (Pioneer). It's about 5-6 years old now. The problem seemed to have gone away, but has not come back even more prevalent then before.
  • jonvdb Apr 22, 2009
    Interesting, never would have thought it was the power supply, though i find it curious that about two years ago Pioneer, for free, came out and replaced the power supply, proactively, as they were getting all sorts of calls with a specifc ps unit that my 50 CMX had.
  • 41 Answers
Depending on the severity of it, it can be just a couple of voltage adjustments on the power supply. If that does not clear it up if you replace the power supply it should take care of it.
Posted on Apr 22, 2009
I have a lg 50" plasma tv with a distorted, discoloration. The model number is 50ps11-ub. Not sure what circuit board/panel to purchase. Can you help me with this? Thanks
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 27, 2016 | LG Televison & Video
LG 60PZ550 has discoloration and distortion across screen worse with light colors
A strange fault you denotes here indeed. Haven't came across this type of fault with Plasma TV. I suggest you to contact the authorized service center for LG. Never do anything to it. Gopakumar Gopalan Google
Feb 19, 2014 | LG 60 60PZ550 3D Plasma TV
I have pink color horizontal lines on my LG LCD monitor screen,How do i solve it?
You can fix you have to follow this instruction
1-Reset the TV by unplugging its power cord for 30 seconds and plugging it back in. This is an essential troubleshooting tool as a simple reset often will resolve the great majority of technical issues experienced by any kind of TV. Power the TV on after plugging it back in and check the picture for any improvement.
2-Unscrew the coaxial cable that attaches your wall cable outlet to either the coaxial cable input on the plasma TV or to any digital cable converters you may use at home. Check the copper needle in the middle of the cable for any bending or damage and screw the cable back on the coaxial input. Again, check the picture for any improvements.
3-Secure the audio/video connection cables that attach the source device you are trying to watch to the plasma TV. This is a particularly important step if you use component cables. Component cables separate a video signal into different colors, so a damaged or loose component cable can lead to noticeable discoloration on the screen. Once the cables are secure, both in the source device and the plasma TV, check the picture again to see if this may have resolved the issue.
4-Scan your channel lineup and check the other TVs in your home to determine the scope of the problem. If you see the discoloration only on one or a few channels, and the same channels are discolored on the other TVs in your home, you may be part of a cable service outage and you will need to report the issue to your cable provider. If all the channels on the one TV have the same discoloration, and the other TVs in the home look normal, the plasma TV likely will need to be serviced for a problem with its picture components.
hope that it helped
Feb 18, 2014 | LG 22" FLATRON LCD Monitor
Top 1/4 of ther screen is distorted
If that is a plasma - and it sounds like it is - it probably needs a new upper buffer board or, better yet, both buffer boards replaced.
Jan 11, 2014 | Sanyo 42 in. LCD TV
My monitor screen has become greenish and with
Hello Devsi, hi, check your VGA cable connection for loose connections, try tighten it first to see if it solves the problem. the greenish thing is cause by a missing red signal, and the distortion is caused by a missing horizontal sync signal, also check out if there are bent pins on your monitor signal cable. just unplug the VGA cable and see if the pins are in order. if bent, carefully straighten it with a slim slotted screw driver.
Dec 17, 2009 | LG Flatron L1750S 17" LCD Monitor
Pioneer Elite Plasma TV 2-yrs old loses color randomly.
Would need model number to search properly. On some sets a capacitor "C2601" of Y-Drive assembly contacts the audio bracket and it is damaged, can cause a abnormal picture.
Sep 08, 2009 | Pioneer PDP-5070HD 50 in. Plasma...
Blue colors appear greenish in middle third of screen...there is a circle of yellowish green in the center of the screen
You have a bad optical block, the block has a 2 year warrnty but you will have to pay labor to have a tech change it
Aug 08, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KV-32FV27 Picture Discoloration
It appears that the greenish discolored area could be cause by the Yoke or it could also be some magnetization on the screen as well.
If it's the yoke that moved slightly out of position, it can be adjusted, but i would suggest to let a repair tech do it due a high voltage around the area.
Try unplugging the TV for some time and plug it back in and hopefully the demagnetizer circuitry might be able to clear the greenish spot.
Let me know if you need further assistance.
Jul 01, 2008 | Sony KV-32FV27 32" TV
Plasmasync 42 (2004)
the screen abnormality is not plasma burn. it sounds like u may have a shorted driver feeding the panel.
its repairable (might not b practicle)
May 01, 2008 | NEC PlasmaSync 42MP1 42 in. Television
Blue color area growing on screen
For any of you experiencing blue dots, lines, growing blobs see the following link:
http://esupport.sony.com/US/perl/news-item.pl?news_id=206
Nov 25, 2007 | Televison & Video
Pioneer PDP-5080HD 50 in. Plasma HDTV Logo
653 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
