Question about Soyo SY-K7VLM-B Motherboard
The motherboard does not support memory expansion.
It is working with 128mb (2 of 64 ) but I try to add more capacity but it does not work. Also I reset the cmos but nothing change.
Note: I try to add 2modules of 256mb. The operative sistem is windows XP.
  • bienvenidofr Apr 27, 2009
    Yes, I am using the specific ram (133).
  • NitrusInc
    NitrusInc May 11, 2010
    Are you sure that you have the specific RAM that your motherboard supports?
    Your system uses PC100/133 SDRAM
    Please let us know if this is not the issue.
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
I need to know how much ram my motherboard will be able to run without burning up? I have an Emachines t1090 w/ Windows XP, 900MHz Intel Celeron Processor, 128MB SDRAM, CD-ROM 48x Max. CD-Drive, 20GB Hard...
The max for your system is 512MB. You have two memory slots and one has a 128MB chip so if you want 512MB, you need two 256MB chips and throw away the 128MB.
At Newegg, a 256MB chip is $42+ shipping of $1. I'd consider getting a new computer instead.
I don't think memory upgrade will tax your system cooling.
Sep 09, 2010 | E-Machines T1090 PC Desktop
Upgrade RAM in a Latitude D600. one bay seems to fail
The memory bay is a part of the motherboard. Try each stick in each bay to make sure that the problem is the motherboard itself. Sometimes memory is incompatible with a particular laptop. Sometimes there is a maximum allowable memory. The maximum for your PC is 2 GB.
Apr 12, 2010 | Dell Latitude D600 Notebook
Memory expansion
The Lexmark E260dn has 32MB of memory pre-installed and you can add a maximum of 128MB to this. The type of memory is 128MB DDR1-DRAM. The part number is 1022298.
Dec 07, 2009 | Lexmark E260dn Laser Printer
Only 128MB or 256MB detected Compaq 12XL400 laptop; 3 diff sticks
I think the Smallest and slowest Ram stick needs to be in slot 0
Apr 18, 2009 | HP Compaq Presario SR1110NX PC Desktop
Memory capacity
Four RDRAMS slots, that support up to 2gb
http://download.intel.com/design/motherbd/mv/ProductBrief.pdf
Hope this helps,
David
Mar 11, 2009 | Intel Computers & Internet
Adding memory to tx pro mainboard
You do not say what memory you are trying to install.
The ASUS P4S800D motherboard has four memory slots that hold DDR PC2700 or DDR PC3200 with a maximum of 1GB per slot, so the installed maximum is 4GB.
DDR memory is generally available in 128MB, 256MB, 512MB and 1GB modules. If you already have memory installed, it must be at least 128MB so you cannot add modules to 'bring memory to 128'.
Either you have a different motherboard and posted in the wrong section, your memory calculations are wrong, or you have used older PC-133,PC-100 or PC-66 memory instead of DDR. The last is unlikely as older SDRAM has two notches and won't physically fit into a DDR slot that only has one notch.
Please re-post with the specific motherboard model just to confirm and a list of the memory modules you are trying to use.
Jan 01, 2009 | ASUS P4S800D-X Motherboard
Can't find the primary memory for a elitegroup a535 laptop
a manual can be found here along with the software drivers
http://download.ecsusa.com/dlfileecs/manual/desknote/a535/English%20Manual.pdf
On board 128MB DDR RAM ( primary cant be removed from motherboard)
Expansion 1 slot of 200pin DDR SO-DIMM DDR Module, 640MB total memory capacity.
Supports DDR200 / DDR266 module
Dec 18, 2008 | EliteGroup ECS A535 Notebook
I NEED RAM
Hi zouganeli,
You can install one, two or three modules. Each memory module can hold a maximum capacity of 128 MB of standard SDRAM chips, or 256 MB of registered SDRAM chips so maximum memory capacity is 384 MB of standard SDRAM memory or 768 MB registered SDRAM memory.
Hope that helps
Take care,
Michael
Nov 14, 2008 | Computers & Internet
Memory problem
Hi
Compaq Presario 700z notebook PC supports 128MB, 192MB, 256MB, 384MB PC 133 SyncDRAM (SDRAM). The Max Capacity is 384MB.
On this basis, I agree to upgrade the BIOS to support a 133Mhz (PC 133) memory module (DIMM).
At current DIMM capacity and prices, ensure the total memory capacity does no exceed 384MB. On the same note, a 512MB DIMM or two 256MB DIMMs are not supported. The best combination to achieve 384MB will be one 128MB and one 256MB DIMMs.
Compaq Presario 700z notebook PC - Product Specifications - http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00009013&lc=en&cc=us&dlc=en&product=95526&lang=en
Regards
Mike
Mar 27, 2008 | Compaq Presario 700 470024-192 Notebook
Soyo SY-K7VLM-B Motherboard Logo
47 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
