Question about Dell Inspiron 1501 Laptop
Dell inspiron1501 touch pad sensitivity problem
When i bought my dell inspiron 1501, I set the touch pad up so it only clicked when using the buttons not the actual pad, today with no warning, the pad had again enabled itself so i find myself clicking on stuff accidently
when moving the pointer, and i have just noticed the task bar's touchpad icon is no longer there? and come to think of it, i dont remember seeing it for some time.. what is causing the first problem and how do i get the icon back so i can change the settings back?
    Sergeant:
  • 180 Answers
You are going to have to go into the control panel and to the mouse properties. in there you will be able to put the icon back in the taskbar. i dont know why it changed itself though. on my dell a couple times i had to reinstall the mouse drivers for some reason. i just went to dell.com and got them there. hope this helps
Posted on Apr 22, 2009
Can't right or left click on inspirion 1501, touchpad is fine.
It would appear that the left/right touch pad buttons have failed. You will have 3 options at this point in time.
1) Use an external wireless mouse such as a Logitech Wireless Mouse M505 for roughly $39.99
2) Use alternative features on the laptop. Left click is typically simulated by tapping or double tapping the touch pad itself and right click can be simulated, in most cases, by single tapping the icon and pressing the pop-up menu button, typically located between the right alt and ctrl buttons.
3) Search for a replacement component online and replace the component. Touch pad replacement will require you to remove all casing screws from the laptop and then remove the case. You will then expose the screws and cabling for the touch pad. I can not give more detailed instructions as this varies per laptop model.
Sep 21, 2011 | Dell Inspiron 1501 Notebook
I have to hit touch pad 3-4 times to work when doing anything Dell Inspiron 1501
Make sure you have the latest touchpad driver from support.dell.com, then in the touchpad settings (Control panel, Mouse, touchpad tab) adjust the sensitivity.
If adjusting the sensitivity has no effect then it may just be wearing out, which would mean a palmrest replacement. Those are around $20
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=inspiron+1501+palmrest&_sacat=See-All-Categories
Jul 18, 2011 | Dell Inspiron 1501 Notebook
I want to disable my mouse pad on my inspiron1501
You should find a check box if you go to your Control Panel --> Mouse applet, under the touchpad settings. There should be a checkbox to disable the touch pad.
If not...check your system tray for a DELL touchpad utility or mouse utility running and look for the setting in there.
Mar 16, 2011 | Dell Inspiron 1501 Notebook
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
Can't change mouse buttons on dell 1501
the control settings for a mouse is the same for all mouses. 1 lot of settings for all mouses, there must be a 3rd party DELL program for your mouse that needs ether changing or removing
Aug 23, 2009 | Dell Inspiron 1501 Notebook
I am having major problems with my touch pad. it
did you fiddled on the sensitivity settings? look for the mouse icon in the control panel
Aug 12, 2009 | Dell Inspiron 1501 Notebook
Touch Pad Will not Open or close applications. Scroll & two buttons still work?
unplug the computer and remove the battery. this will reset it.
Apr 20, 2009 | Dell Inspiron 1501 Notebook
DIsable touch pad on Inspiron 1501 laptop with XP
You should see a touch pad icon in the task bar. Right click it and disable device in the device select tab. Good luck. Let me know how you made out, and please rate my answer.
Jan 20, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1526
your touchpad is just one case to sensitive. deactivate it by hitting "fn+ the tuchpad deaktivation key on your keyboard" and get yourself a mouse
Jun 22, 2008 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 touchpad
the problem that you are having is that you need a touch pad driver to communicate right. you can find that on your dell website. search the model that is on your dell laptop.
hope that solves your question.
thanks.
Dec 27, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 1501 Laptop Logo
479 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
