Question about Mitsubishi WS-55859 55" Rear Projection Television
I have a Mitsubishi WS55859 and had the convergence IC go out recently.. I got a replacement STK393-110 from electronic repair kits and got it installed, however, now it's just making me mad. Upon powering the set up the convergence is way out, let it sit for about 10-15 minutes and convergence comes in. I've gone into the setup menu and adjusted things more times than I can count but can not seem to get this to stop. Does anyone have any ideas?
  • Mitsubishi Master
  • 8,617 Answers
Most likely a solder issue if it works intermittent. I would double check the solder on the IC pins
Posted on Apr 22, 2009
How do u replace a IC convergence on a mitsubishi 65 tv
if you guys don't have experience or the right tools to fix board you will mess up your board.
so go to ebay and search for repair service listing #230735864835 and sen your board to this guy for convergence repair.
let a professional do the job for you and for cheap,why buying repair kits when you can buy the repair service?
Jun 18, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Power comes on and the back off.... Code is two flashes then paus then two flashes.... Where do I check to find fuses to the convergence?
This is a short protect error code. The affected parts is not only the pico fuses but also the convergence IC(STK393-110) that is mounted on the large aluminum heat sink. I have a link where you can buy the repair kit that includes steps-by-steps instructions that will guide you in the whole process of repair. Click the link below.
Mitsubishi V21 chassis(WS-65511) convergence repair kit ($42).
Scroll down to V21 chassis convergence repair kit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 13, 2011 | Mitsubishi WS-65511 65" Rear Projection...
I have had a Mitsubishi DLP 52525 for 6+ years now and recently the green timer light started to rapidly blink when the unit was turned on and it continued to blink without the picture coming on. After...
I don't know about nettiser's credentials, but I've found plenty of people who would disagree with his/her assessment.
The flashing green timer light after a lightning storm seems to be a very common problem with old Mistubishi rear projection TV's. A friend and I had the exact same problem.
Using this and other sites, I spent $36 bucks and a little time with a soldering iron to replace the capacitors on the DM board and got mine up and running (WS55859). I've never really worked on electronic circuit boards before, but the helpful advice at these sites got me up and running. Definitely check it out before you hire someone or replace your TV:
Repair Kit with instructional CD available at:
http://www.tvrepairworld.com/mitsubishi_repair_kits
for under $40 plus shipping.
Discussion of process in detail at:
http://www.hometheaterspot.com/showtopic.php?tid/137881/
for the WS55859 model, which may be a little different.
Jul 31, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Red ghost in my ws48517
U can solders wright?Buy a convergence kit at Tv Repair World.com.To repair it ur self.Try U Tube.com for some sample for replacing some DLP tv IC convergence problems.
Feb 15, 2010 | Mitsubishi WS48511 48" Rear Projection...
HD 1080 Series (WD-55809) - Color convergence issue
I don't know of illustrated instructions but I can provide you with the service manual for your TV. It does have illustrations of disassembly and components as well as schematics. Your set very likely needs new convergence IC chips. This is a common problem with all projection TVs. The repair is not expensive ($60-75 in parts)  but does involve unsoldering and removing the old chips and soldering in new ones. Some times there are some fuses that need to be replaced as well. If you want the manual provide me with an email address.
Dec 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS55859 turns on for 3 sec. then turns off
Ic's went out again. Did you check all the bias resistors? Must always look the board over for cold solder joints also.
Oct 22, 2009 | Televison & Video
Mitsubishi WS55859, was getting 2 and 2 blink, replaced the pico fuses and convergence chip - 3 times, each fix worked better than the next but evenually failed - now have it working, trying to adjust...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Our TV (Mitsubishi WS65711) is 6 years old, and has recently started showing a blue ghost image on everything. It stopped for a while for a week or two, but started back up, and has continued ever since. I...
You have convergence problem in your tv as your local repair shop told you. You need to replace convergence IC . YOu can get from the link below .
Convergence IC can be obtained from the link
You need to replace both convergence ICs .It will cost you around $30
If you can replace it by yourself . If you take to repair shop they will charge you around $200 for this job. .
The IC number is STK393-110 .
You can get some idea on how to replace convergence IC from the link below
http://www.fixya.com/support/r704766-convergence_solutions
Hope this helps .
Feb 19, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Help, Help, Help! Mitsubishi 73" red convergence fiasco
Thats the time you need to replaced the convergence IC.
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry and fuzzy images .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and cannot be adjusted this is the symptom for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Mitsubishi WS-73907 TV
Mitsubishi WS-55859 55" Rear Projection Television Logo
247 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
