Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer is not draing the water out
Washer is not draining water out
  • Bosch Master
  • 19,396 Answers
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Posted on May 21, 2009
    Sergeant:
  • 197 Answers
Check your drain on the washer. It is most likely clogged with debris.
Posted on Apr 30, 2009
SOURCE: water does not drain out from my washer
I have determined one of the reasons ( I feel this is the primary reason) why many BOSCH washing machines will not drain the water, Bosch uses the same drain pump in many of their 500-800 series washing machines, part number 436440. The drain pump is a electrical controlled magnetic driven pump. Simply a electrical current produces an electrical field which a magnet rotates, spinning the pump blades. I have determined that the internal seal on the pump part is allowing water to leak into the magnet area of the pump. This is causing corrosion, and water build up around the magnet, interfering with the magnetic field. How I came to this conclusion. After removing the end of the pump, and allowing the water to drain out, drying out the pump, the pump will work as advertised. But of course the pump cannot be used in this condition. A new pump is required. To determine this yourself, if the machine is not under warranty (good luck getting service). Unplug machine, remove back panel, unplug the drain pump, remove drain pump (separating the drain pump from the large plastic holder, there are three screws holding it to the housing). You can shake the pump, and if water comes out of it this is most likely the problem. Now hook the pump back up to its electrical feed, and place it on a rubber sheet. Set the machine to drain, if the pump attempts to spin then stops, or hums this is the problem.
Posted on Nov 10, 2008
  • 641 Answers
SOURCE: washer water not draining
Your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley you should remove the pump from the washer and try to rotate its pulley manually. If it doesn't turn freely (frozen or stiff) it should be replaced. In case of a broken pump's belt or belt looks quite worn, replace it. In any case, check the pump's pulley before you replacing the belt. Let me know if you need for further assistance. Good luck
Posted on Sep 10, 2007
  • 4 Answers
SOURCE: My washer won't drain the water
Can you check the motor pump with supply or with ohms meter if it is good the timer not giving signal during the washing cycle.
Posted on Mar 10, 2008
SOURCE: WASHER WILL NOT DRAIN WATER KENMORE WASHER APPROX 9 YRS OLD
Does the tub spin without draining?
This JUST happened to me last night. Opened washer after a load and still full of water. Fifteen spins later, still about an inch of water in tub...
RepairClinic.com suggests checking the hoses from the washer tub to the drain pump for anything clogged in it. (WARNING!!! As soon as you remove one end of the hose ANY water remaining in the tub will come RUSHING out if not clogged. I was prepared for water, but not a rush of water.)
If there is no clog in that hose, remove the drain pump and check for something in it.
(My pump was burning up because some how a plastic stick got into it. I am waiting on the new pump now.)
If there is nothing in the first hose or the pump, see if anything is in the hose leading to the drain.
If not, they suggested something either purchasing a new pump as it may have quit working or something may have gotten stuck in between the tubs. This requires tearing apart and sometimes special tools.
Posted on Jul 15, 2009
  • 6 Answers
SOURCE: water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Posted on Jul 19, 2009
Machine won't run on wash and rinse but motor will start and drain the water out
What you hear is the drain pump, remove back panel to see the problem
Mar 31, 2013 | Haier XQJ50-31 Top Load Washer
Kenmore series 90 bypassing water. doesn't fill instead water flows out the drain tube once it reaches a level just below small load.
raise the drain hose up till the arch is about level with the back control panel. Once you here the water stop draing restart your machine and it should return to normal operation
Jun 03, 2010 | Kenmore 15864/15862 Top Load Washer
Not spining
1st,check if you have lay down the drain hose to the ground,2nd if the drain hose is blocked.3rd,if the drain pump has problem
Mar 07, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer stopped draing the water
The pump may have stopped running, or a hose is pinched or blocked. Check the hose port at the outer tub bottom to see if a stray sock or something is blocking water drain.
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Standing waterin the door opening seal after each load.
Sometimes small pieces of clothing get into drain system and plug off draing. Check before pump for clog.
Oct 02, 2009 | LG WM-2277HW Front Load Washer
Will not fill with water
Hi, First thing to check is the drain. Make sure your drain hose is higher then the water level and make sure, if you have it draing into a sump that the end of the hose is not laying in the water. I hope this helps. Please let me know,
Thanks
Vic
May 20, 2009 | Kenmore 24032\24036 Top Load Washer
My washing machine fills to the correct level initially, then keeps draing and refilling. It used to work if I put the selector on one notch less than full, but now it does it on every size setting.
Make sure the drain pipe the washer drain hose goes into is at least 34 inches above the bottom of the washer. The drain hose must not be sealed to the drain pipe, or you may experience siphoning of water out of the washer.
May 12, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Kenmore washer not draining/also getting stuck doing nothing
i had my kenmore washer doing the same,looked at water pump but nothing was stuck inside ,i tried the lid switch and stuck a screwdriver in it to see if this would do the trick,nothing..but when i took it out, i could see where it had come apart...took it out and decided to use gorilla glue and clamp it back till the glue dries,before the glueing process ,i test the draining outside with a buckett..and bingo,it started draining the water,i only had the switch crimped with my fingers and at the same time pushed the switch down ,it worked..draing started..hopes this helps
Mar 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Got a new washer that has button to drain water but its not draing water or doing spin cycle and keeps coming up with error its an indesit wib101 washer it wont finish any cycle at all
check out the DRAIN MOTOR PUMP ,it could be clogged , take it out , inspect it , clean it , and try again , hope this helps AJ
May 13, 2008 | Washing Machines
My washer won't stop draing as it fills
Does the washer makes a full cycle properly and only problem is water's constinously draining ? If this is the phenomena, verify that the pipe discharged to the drain hose (the pipe that water going out from the machine)is at washer height up to one foot higher. Goog luck !
May 25, 2006 | GE WBB4500EWW Top Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
265 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
