Question about Frigidaire StandardDepth Top Mount Refrigerator Model FRT18IS6C - Q / B / W FRT18IS6C Appliances/Re...
FRIGIDAIRE TOP MOUNT REFRIGERATOR
THE FREEZER IS WORKING FINE BUT THE LOWER REFRIGERATOR IS NOT COOLING AND IT IS WARM.
  • mrhadnott Apr 22, 2009
    I WOULD LIKE TO KNOW HOW TO MAKE THE LOWER COMPARTMENT GET COOLER.
    Scholar:
  • 126 Answers
Ther is a passage for air to travel from freezer to refrigerator this passage can freeze,etc. in the rear of freezer in the middle behind coil cover is the point for air to circulate from freezer to refrigerator < can be blocked with ice here > at the same location in refrigerator if it has thermal door that opens and closes it can stick and malfunction causing this.
Posted on Apr 22, 2009
  • Frigidaire Master
  • 4,654 Answers
If the model FRT18IS6CQG is correct your refrigerator has a defrost thermostat inside the fresh food section where the controls are. Need you to turn it clockwise until the refrigerator stops running. This puts the fridge in manual defrost. About 20 minutes later it should come back on without your help. If not we need to replace the timer. Let me know Sea Breeze
  • John Tripp
    John Tripp Apr 27, 2009
    If this was a defrost problem as I mentioned vents get frozen shut and after the refrigerator is defrosting properly you can pull open some of the vents to loosen the up some are electrically assisted. most are not. Give that a try and let me know. I did not get a notice you replied so here is my email if you need further assistance. seabreezehvac@yahoo.com
  • John Tripp
    I can also send you the user and parts manual if you like.
My frigidaire refrigerator does not seem to cool no freeze
If you have a sxs refrigerator then you have an issue with the damper door/switch not letting cool air from the freezer section to the refrigerator section. If you have a top mount freezer refrigerator unit, then you have a problem with the top venting system from the cabinet's ceiling.
Jul 27, 2012 | Refrigerators
Frigidaire White 16.5 cu. ft. Top Freezer Refrigerator (FRT17HB3)- The freezer works, the refridge portion is warm, it started last week ans seemed intermitten, we turned the cooling higher and it was fine...
All of your cooling coils on this model are located in the freezer. If you are cold enough in the freezer your problem is air flow to the fresh food section.
- There is fan behind the back wall of the freezer, be sure that is running.
- Look for frost build up on the back wall of the freezer, if present we have a defrost problem
- look for the duct or channels between the floor and freezer and top of the refrigerator they could be blocked with ice, if so we have a drain problem.
Let me know what you find and I will help you from there.
Apr 18, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
Mar 13, 2010 | Frigidaire FRT17B3A Top Freezer...
The sides of my freezer are very hot while the top, front and back are cool to the touch. The freezer still is freezing items fine.
In the newer freezers and refrigerators they are mounting the condenser coil in the side panels of the freezer or refrigerator eliminating the large usually black frame work of tubing that used to be mounted on the back. This saves room but causes the sides to be warm as the heat is now dissipated by the side panels. You should have about an inch of clearance on both sides to let air flow over the side panels to cool them. I have a newer side by side and it also is feels quite warm when you put your hand on the side.
Oct 07, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Nov 09, 2008 | Refrigerators
Bottom is too warm
Make sure your fan is working ,its in the freezer behind panel .If not the fan your passage area is probably covered with ice and the air cant get in freezer
Jun 14, 2008 | Frigidaire FRT15G5CS Top Freezer...
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Refrigerators Logo
148 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
