Question about Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV
Anything that is suppose to be white is green.
There is a green cast over everything and it is more on the right side
  • lisa1993 May 10, 2009
    Same problem - similar TV. Started out with the right side of the screen turning green, and has spread to the full screen now. Have adjusted colors, tried a new lamp, still the same problem. This TV is not that old, bummer.
  • 41 Answers
Check all of your connections, if they check out then the most likely cause would be a failure of the Optical Block.
Posted on Apr 22, 2009
Magenta cast on left side and green cast on right
We are OEM foundry adopting of advanced sol-wide (colloidal silica)investment casting process,produce castings of various kinds of carbon steel,alloy tool steel,wear-resistant alloy steel,heat-resistant alloy steel and all kinds of stainless steel &it's develped products,with an annual output of 600tons of investment castings production capacity,80% of them were exported to the United States,Germany,Janpan,Spain and other countries.
hot sale pneumatic fittings Pneumatic valve stainless steel casting...
May 26, 2016 | Canon LV-7265 Projector
I need to know where the green wire is supposed to connect to the ignition or if it doesnt connect to anything
I this is a older EMC Rascal with the cast aluminium housing, green goes to the bat Terminal. There should be only one wire on it(bat) connection. Scooter Doctor App
Mar 30, 2016 | Health & Beauty
Four wires coming from needle to cable, two are shield and two are left and right channels. Which color goes where
Actually it's not to hard to connect them. All you need is a stereo record where you know a sound of something is on the right or left channels. I use to have a Goodies LP where a one of them would say "bounce to the left" and the other said "bounce to the right" these coming on the respective channels.
To set it up just stick the red (right) on one of the cartridge pins and white - left on the opposite side - not underneath it. Then connect the other two to the pins below them. Play your test record. And if the sound which is supposed to be on the right channel come on the left - swap the two red and white wires around.
If the sound sounds (tinny spaced) out then swap the same side wires around.
So if you have say Red Green, Make it Green Red. If it is tinny only on one channel, don't switch the other channel around.
For example the right is tinny - do the above - but leave the other White Blue.
By the way some cartridges do have L and R marked on them and + and - for the channel types. " -" being for the green or blue wires.
Feb 08, 2014 | JVC Audio Players & Recorders
Green pictures
Assuming the camera is not faulty the most frequent reason for a green tint is the selection of the wrong white balance in the camera menu. The menu will contain "AWB", "daylight", sometimes represented by a stylised sun logo and indoor. If you use "daylight" for indoor photos the pictures will have a green cast. Select "AWB" for generally acceptable results. If the pictures have a green cast on outdoor pictures you have a problem
Dec 14, 2013 | Kodak EasyShare CX6200 Digital Camera
Pink cast to all images now
It sounds like your white-balance is off on the magenta side of things. This could be caused by a number of factors, though I would explore your camera's white balance setting to make sure it's set for the right lighting situation. If changing your white balance setting fails, it may be a more serious issue with your sensor or other camera hardware, requiring a professional to repair it.
Jul 08, 2013 | Fuji FinePix S7000 Digital Camera
Installing stero in car wiring diagram front soeakers 1999 mercury mountainer
your right front speaker neg side is Green with a orange stripe your right front pos side is Light tan with a green stripe your left front neg side is a light blue with a white stripe and the left front pos is orange with a green stripe,, a typical new radio will have a gray with a black stripe for the neg side and solid gray for the positive, on the right side and the left will have a white with a black stripe for the neg, and solid white for the positive, if you need anything else just reply to this feed and I'll help you
Oct 07, 2011 | 1999 Mercury Mountaineer
Everything has a yellow tint to it. if its supposed to be blue it looks green. I have tried changing the settings several times. on rare occassions it will go back to normal but goes back to green when I...
I doubt that the monitor is on its way out, the yellow cast is indicative that either the vdu cable is damaged, or more likely, the inner circuits are failing, you may need to replace the monitor
Jan 03, 2011 | Komodo Computers & Internet
I HAVE A GR2 DIGITAL CAMERA. I usually shoot in manual mode and and set white balance manually using a digital callabration target. Yesterday afternoon, after shooting most of theday without problems, my...
I doubt that formatting the card will do anything but, if you choose to do that, download any pics first since formatting will completely erase the card. Have you tried going back to "Auto WB" to see if your camera works properly that way? How about going into the menu and finding "reset" to get back to factory default settings?
Nov 23, 2010 | Ricoh GR Digital Camera
Green cast on all channels
Hey Sandjk, I have a 3 yr old sony 60a2000. It has been turning green for the last 3 months. I thought it was the bulb needing replacement, so I just changed it. $250 down the drain. Its no better at all. I have to go to settings-picture-custom- advanced settings-white balance- and take the g-gain and g-balance to minimum values. do it for the cool and warm 1 settings. then when you cycle thru the cool neutral warm settings you will see a big difference. Not great but watchable. let me know what you think or if you found a better solution.
SandyP.
Apr 23, 2009 | Sony Televison & Video
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV Logo
106 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
