Slow water into machine
I have a Kenmore 80 series washer. The water pressure is fine from the wall, and I think we need to replace the water inlet valve. How do we replace the water inlet valve?
    Genius:
  • 1,122 Answers
First try the washer on cold only,then hot only,if one is slow and the other is not replace the valve,you must remove the 2 head screws one on each side(you might have to pop the plastic covers on each side to get to the screws,after removeing the screws flip up the head,you will see 2 spring clips one on each side,take a screw driver and pop them out,unplug the wire jack on the middle of the washer(that is the lid switch jack,now you can pull the back out just enough to get to the valve,the valve has 1 or 2 screws holding it on,you remove then on the outside,there are 4 wires on the inside to remove plus the fill hose,you can get a valve from your local appliance part store for around$10,or one on line at sears.com-parts,or repair clinic .com,the model number for your washer is inside the washer lid,let me know how you do-mike
Posted on Apr 22, 2009
Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Mar 26, 2010 | Kenmore Washing Machines
Kenmore series washer- losing water pressure
it does sound like you have a inlet valve going bad.
i assume this happens on both the hot and cold water sides. if not try and switch hose and see what happens if the water pressure drops then replace the water valve.
Feb 06, 2010 | Washing Machines
Kenmore HD Series 80 - hot water trickles in.
Pull the two screws at the bottom corners of the control panel. Pivot the panel up. Lever the two metal keepers underneath forward and up to remove them. Tilt the housing forward and pull it toward you to remove it. Make sure you unhook the lid switch wiring plug before you remove the housing.
Water inlet valve should all be one piece for hot and cold.
Nov 15, 2009 | Kenmore 26882 Top Load Washer
80 Series Top Load\ Water Feed
There may be a screen in the inlet pipe where it joins the back of the machine. Also check that the inlet pipe is clear and running water correctly before connecting it back on the machine. If this is OK you may have an issue with the inlet valve not opening fully. This is quite a common issue and will need the inlet valve repalcing.
Sep 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 heavy duty has a water flow problem
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are clear of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad solenoid and the water inlet valve assy will need replaced. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 06, 2009 | Washing Machines
My Kenmore series 80 washer's cold outlet doesn't work
Hi, It does sound like the inlet valve is bad. If the screen inside the inlet vavle is not plugged, you will most likely need to change the valve. If you will send me a model #. I can tell you how to get to the valve for replacement.
Thanks
Vic
Jul 26, 2009 | Washing Machines
Sporatically slow cold water fill (Kenmore Series 80)
Could be you have trapped the hose at the rear of the m/c.
If this is not the case, then I suspect you will need a new cold inlet valve fitting..
Please leave feedback.
Ta.
Dec 09, 2008 | Washing Machines
Kenmore Series 80 also won't fill
the pressure switch is inside the console with the timer on top of washer, it is the round thing with a rubber hose stuck onto it ,,, if you have a know that you can set for water level that is it, some models dont have the knob but all has the pressure switch ,,, take the 2 screws out of the console and pull forward at bottom and swing up to get to all the controls, be sure to have your washer unplugged when doing this / larry
Nov 29, 2008 | Washing Machines
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
