Question about Refrigerators
Everything works motor just stop working. lights on,ice maker and water dispen, makes sound but no other sound. help!
The side by side just went dead. lights up in the inside. ice maker and waterr dispenser makes noise. but no sound from motor.
  • 1 more comment
  • robbell4jesu Apr 22, 2009
    whrilpool side by side refigerator model ksrt26dt
    thank you. you nailed it on the first try. i truly thank you very much. i know GOD will bless you in JESUS name. Rev. bell II
  • John Tripp
    John Tripp May 11, 2010
    Make and model number?
  • Refrigerators Master
  • 4,655 Answers
Your refrigerator has a defrost timer and could be stuck in defrost. Go into the fresh food compartment and were the controls are should be small hole to stick a pencil eraser in. Turn clockwise slowly until starts, if not we need to do something different. Sea Breeze
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Posted on Apr 22, 2009
  • John Tripp
    John Tripp Apr 22, 2009
    Thank You for the vote! Have a good day...Sea Breeze
  • John Tripp
    Don't forget to change the defrost timer, because if not you will continue to have these problems.
Ge refrigerator ice maker has stopped making ice
The water valve on the back of the refrigerator is bad, one controls water for the ice maker and one controls water for door water
May 11, 2014 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Freezer light, ice maker, and ice/water dispenser stopped working
did you replace the light . or just tighten it . and is ice cream soft . it sounds like the tempt is above 15 deg . and needs to be colder . this may be a control problem . but ck the little things first . clean the coils / make sure inside fan and under neath fan are going . re ck control settings . .. if problem does't go away . then look at control ..
Jul 29, 2010 | Frigidaire Refrigerators
Ice dispenser will not dispens ice . light dims when pushed. ice maker works fine
It may be a good Idea to remove the ice bin, clean and dry ant the same time with bin removed see if while pushing the door light switch and the dispense ice control if the auger fork in the rear of the ice bin that normally turns the auger will rotate. Sometimes ice or water collects in the bin and locks the motor from turning and sometimes the motors go bad. Tell me your results, Thanks, Sea Breeze
Apr 23, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped working
Just a question... Is the motor that flips the ice down into its tube moving? or spining? your motor in the ice maker may have went out. might have to replace it.... hope this helps....
Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Frigedair refrigator
My GE Side by Side refrigerator is about ten years old. the refrigerator side stopped working and is warm. The ice box side is cool but is not as cold as it usually operates.
Nov 07, 2007 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
