Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Water is filling up in drain pain
I have a Amana an Pth123A35AC, MFG# P1233719R' serial no. 0012145382. Water is filling up a very small pan area and I can hear water dripping. Is there a drainage pipe somewhere that is stopped up? Any suggestions on how to approach this problem?
  • 1 more comment
  • cole3 Sep 25, 2007
    Thank you for your help. I will follow your advice, but am trying to find a repairman in my area to service this kind of unit. I need to know more about how this unit operates.
  • Wija Jun 09, 2008
    I have WICKES spilt airconditioner (SKU156416 & SKU156435) at one of our room, since jesterday (after one year of use) water dropping from internal unit. I have checked drain pipe and air filter. Also water dripping through drain pipe (outlet) when the uinit in use as normal. Please advice me to stop water leak.
  • popsj Apr 17, 2009
    same problem but is also dripping outside onto concrete patio, and is etching the surface of patio. pulled unit out and can not locate where water is coming from, help ?
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 5 Answers
These are mostly correct but most have a small drain line that feeds int a drip tray to disperse water over condenser coil and they can sometimes become clogged with algae. remove and clean with simple green
Posted on Aug 29, 2012
    Problem Solver:
  • 8 Answers
Hello All, this is by design. There's a drain pan in the bottom of your unit. When it's humid outside moisture condenses on the cooling coil, drying out the air inside your space. This moisture hangs in the drain pan and gets "slung" back on to the condenser coil by the fan. This improves cooling efficiency. On extremely hot days the drain pan may overflow (by design) out through the back grille. Hotels use drain kits (DK900D) to redirect this water so it doesn't drip down the exterior wall. The water has to go somewhere and it's much better to send it outdoors than indoors! You can find a manual for the Amana PTAC PTH123E35AXXX right here which describes "normal" operating sounds: http://www.h-mac.com/brands/cooling-brands/amana.html
Posted on Aug 27, 2012
My suggestion is to NOT pull the plug on the drain that should be covered with a sign that says...do not remove plug. Water is supposed to be kept in the pan. The interior wheel then helps the water keep the condenser cool....Ron
Posted on Sep 23, 2007
SOURCE:
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
I found water under my amana refrigerator Model Number ABB2222FEW does this model of refrigerator have a drip pan to catch water I can not find any reference to a drip pan in the book I received when I...
Hi
Look on the ceiling in the back by the compressor do you see a small hose on the ceiling. There's an access panel at the lower right corner. That's where it is ,there's a drain pan just under the hose remove that panel its right there.
Also check this link to have a detailed idea:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itleaks
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Amana Refrigerators
How do you remove the water collection pan
There is very little collected and it usually evaporates by the warm air movinf in that area .If there is alot of water there may be a problem. I've never needed to get rid of the waterin the 40 yrs in California and have never hsd to contend with overflowing.Keep the area under the fridge free of cobwebs and the dirt they trap using a vacuum cleaner about once a year. The drippings with drippings will evaporate quiker with free air movement.
Nov 07, 2009 | Amana SXD524VW Side by Side Refrigerator
Drip pan over filling
The fan which cools the condensor coils and compressor usually evaporates the defrost water in the drip pan . Adding a water filter should have no no affect on the amount of water in the pan .
Jul 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Air Conditioner in wall not window like hotel unit, leaks inside
Open the cover. In the bottom drip pan, there is a hole that is clogged. Just unplug it and it will drain.
Jul 07, 2009 | Amana AC053R Thru-Wall/Window Air...
Do I need to empty the water from my drip pan
the pan is there to catch condensation from the compressor during the refridgeration cycle. the water build up to me indicates one of two things. Either the refrigerant level is low and it is freezing up then thawing, or if you have ice or water dispencer it could have a leak in the line. the only thing other than that is a leak in the magnetic door seal or other insulation causing condensation. hope this helps
Jun 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Side by side dripping
There are several reasons why the dispener would dip. Do you have a filter on the unit and have recently replaced it. Then run a large pitcher or water through the dispenser to make sure all the air is out of the line. Anorther thing that could be happening it the water valve is not sealing properly and causing the dispenser to drip, In which case the valve should be replaced. One other odd problem is if the water tank somehow is not even and you have a little air bubble in it. Just some thinks for you to look for, hope one solves it.
Aug 31, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
2,013 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
WatsHVAC
Level 1 Expert
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
