NO TV MY TV WAS WORKING THE NIGHT BEFORE AND WHEN I TRIED TO CUT IT ON IT WOULD NOT WORK.THE POWER TO IT IS GOOD BUT WE ARE TRYING TO FIND A RESET BUTTON TO TRY.SURELY THERE IS A RESET BUTTON ON IT.WE THOUGHT IT MIGHT BE BEHIND THE COVER ON THE BACK.IT WILL NOT LIGHT UP IS THIS A LOSS CASE TO DUMP IT.
  • 1 more comment
  • IDELL Sep 23, 2007
    where is the fuse located in the tv.we did not know it had a fuse in it.
  • Gene Porter Dec 03, 2008
    same as the above,is there a reset switch ?,or is it the power supply, there is a week hum coming from the high votages section, should it be replace ? [email protected] Thanks
  • Big Kountry Dec 31, 2008
    I think I have the same problem but it happends every now and then. I just take of the lower panel and make sure everything is nice and tight. What are you hearing when you turn it on? Do you hear the tv turn on and then you hear it click like it turned off? It does it with mine but the little light by the power switch when start to flash on and off. I am still tring to find out what it could be. Any ideas?
    Problem Solver:
  • 6 Answers
Check for fuse blown, if there are no lights and no sound coming from inside when power is pressed.
Posted on Sep 23, 2007
SOURCE:
Samsung TV
Based on the information you described you may have a tuner
circuit problem or power intermitent faikure fron the power supply module.
Nov 02, 2012 | Samsung Televison & Video
My television just doesn't turn on. It was working fine last night then it stopped working. The outlet works and the red light doesn't come on.
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Now,the tv should be working again,if the tv still getting same result no power LED light indication at all or just flashing power LED light indication.Mean ur tv the power supply board is the causes and the problems.The power supply board,that board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 01, 2011 | Memorex MLT3221 32 in. LCD TV
My Awa lcd tv model LC-32G76 will not power on. It is on at the wall socket, but no lights are on the TV, nor will it turn on. It was working good last night, this morning I have this problem What is...
Check the Socket make sure that it has power plug a cell phone charger into it to check, if that doesn't work check all connections on the TV also try the remote to power it on if that doesn't work try the power button at the TV if that doesn't work try the input channels.
Jan 23, 2011 | Televison & Video
I have a 50 inch LG plasma tv that is less than 2 years old. It use to turn on by itself throughout the night, and now it's completely not working???
Hi there
Try doing a system reset on the TV, by unplugging everything from it, then wait 3 minutes and plug the power lead in only. If it works, then plug everything back in one by one. If the problem persists it may be that the software has been corrupted in an update process, which can be performed at night via the aerial signal (this may be why it was turning on at night). In which case contact the TV manufacturer.
Hope this helps
TV_Doctor
Jan 03, 2011 | LG 50PX4D 50 in. Plasma Television
I have 46 in sanyo I purchased from walmart in late 2007. The tv will come on for just a second and then cuts off again. I don't know what to do I can't get it to come on
Try unplug,replug tv an hour later.Tv should reset it self back to factory setting.Should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP46848 LCD TV
LC320EM8A 32" TV WON'T COME ON NOT BY REMOTE (NEW BATTS) NOT BY TOP POWER SWITCH. WORKED LAST NIGHT NOW NOTHING, TRIED THE ONE SUGGESTION IN MANUAL TO UNPLUG FOR 30 MINS TO RESET(?) ALL POWER CONNS...
Hi Wayne,
I'm glad your getting somewhere with your research. If you arent getting even a standby light, try checking the plug fuse and if this is ok, then the power supply board inside the tv is faulty. Could even be the power pcb fuse or dry capacitors (bulging tops on faulty ones). Hope this helps, and good luck :)
Feb 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
My Ant A Input Not Working
Good Day, babt;
TRY THIS:
MAY ONLY BE ABLE TO SELECT ANTENNA A AND B. WITH THE REMOTE CONTROL PRESS MENU, SELECT "SET UP" AND THEN "AV CONNECTION HOME THEATER" SET "AV NETWORK" TO "OFF" AND "TV LOCKED TO INPUT 1" TO "NO" THEN EXIT THE CUSTOMER''S MENU, TURN THE UNIT OFF UNPLUG IT AND THEN PLUG IT BACK IN, IF THE PROBLEM RETURNS AN E2 RESET IS NEEDED. ACCESS THE OPTION MENU BY PRESSING "MENU 1, 3, 7, 0", USE THE ADJUST BUTTON TO SELECT "E2 RESET" AND PRESS "QV". IF THIS IS NOT RESOLVED BY THE E2 RESET REPLACE THE EEPROM, IC701 PART # 275P163010. THE E2 RESET IS ALSO NECESSARY AFTER REPLACEMENT OF IC701.
Good Luck, big IRISH.
Aug 06, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Toshiba 51H93 won't turn on **HELP**
Good Day, jsilver05;
That's a very good TV, sorry you're having a problem. I have the same TV.
1. The blurring of the pic may be an indication of a convergence problem.
2. The surge protector is not a fail safe device, it will reduce damage to the TV but will not not 100% protect it.
It is possible that by turning the power off may damaged the already weaken convergence circuit, but more then likely some other electronic device failed.Like a voltage regulator, high voltage device,and etc.
At this point I would recommend that you call a factory authorized service dealer and them come out and give you an estimate, or you can e me if want troubleshoot TV if you have digital meter etc.
Good Luck, big IRISH, [email protected]
Jul 15, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Televison & Video Logo
433 people viewed this question
Top Televison & Video Experts
Ekse
