This problem is most likely caused by corrupt data on your SD card. Your best bet is to format the SD card and and reload the backed up data if you have any.
I hope the info listed above has helped in some way. If possible please rate this solution.
The original R4 card only works with Micro-SD cards up to 2GB in size. To use Micro-SD cards up to 32GB, you need to buy the newer R4 SDHC card or a Nintendo DSi comaptible card. Check out R4 Cards / R4 DS Cards from DSCardWorld.com or NDS-Gear.com (NDS-Gear is probably better if you live in Europe or Canada as their shipping's slightly better internationally).
sounds like you're going to have to send it to nintendo for repaire the system files are the ds's operating system if they are damaged than it cant play games
It sounds like you need to figure out exactly what kind of DS card you have. Check out NintendoDSCard.com's DS Card Setup Guide which should sort you out.
Also, I recommend only buying genuine cards since a lot of the fakes tend to break quite easily. Maybe from dscardworld.com or from nds-gear.com if you're in Canada/Europe since their international shipping's a bit cheaper
I use to have similar problems with my DS Card :(. In the end, I end up buying a new one - I personally use http://www.NDS-Gear.com
Apparently, the Sd/tf message occurs when there is a problem with the connection between the micro SD and the DS Card or between the DS card and the DS. You can try giving your micro SD a good clean ( give it a good blow) and see if that makes any difference. Also, I heard that sticking some papers at the back of the DS Card works for some people. If nne of this work, you would robably want to buy a new one or try and get a repalcement from your seller.
to format the card is pretty simple really, all you have to do is:-
make sure your card is plugged in with the p.c same as you drag and drop go to my computer look for where your flash drive is dont click into it, right click it a little list will show go to format then click start (dont use quick format)
no lol
