Question about Briggs & Stratton Garden
Snapper starts with starter fluid
I'm trying to help a friend, have not seen the mower.
He says that it must be started with starter fluid, after that it runs. model .28b702 ,type 1154-e1, code 010911210 . He does not have a manual. Does it have an up draft carb or down draft.
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
  • 138 Answers
SOURCE: I have an 80's model 10HP rear engine Snapper
Sounds like you have problems inside your gear box, The easiest way to check this is to stand the mower up on it's backend and try to turn one wheel and hold the other. You should be able to do this if you get any bucking or the rear end locking up your problem is going to be in the gearbox. FYI make sure you lock your clutch pedal down so the drive disk does not contact the friction disc
Posted on Aug 11, 2009
  • 143 Answers
SOURCE: Must keep pushing primer bulb to keep mower running, need manual
The main suction jet in your carb. is blocked.Remove the bowl and push a thin needle up the centre jet in the carb and blow the jet out with compressed air. Stephen.
Posted on Sep 22, 2009
mowerman1857
  • 389 Answers
SOURCE: I have a Snapper rear engine riding mower. Mod#28085S
If one goes to the starter, the other has to come from a 12 volt source, either ignition switch or battery
Posted on Oct 04, 2009
SOURCE: how do i tighten the clutch for a Model 28b702
how do i replace cluths on snapper riding mower
Posted on Oct 22, 2009
How to start it
      Stand behind the lawn mower. Use one hand to hold the engine stop lever in the operating position. Use the other hand to hold the recoil starter handle. Slowly pull the recoil starter handle until resistance is felt, then pull quickly to start the push mower engine.
      How to Start a Lawn Mower ' Starting Snapper Mowers FAQ
      www.snapper.com/us/en/support/.../how-do-i-start-my-snapper-lawn-mowe...
    Feedback
    How to start the lawnmower - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=QsRwZZwO4oc
    May 25, 2012 - Uploaded by iScaper1
    Tips on how to start a lawnmower. I asked my wife and boys today if they could start the lawnmower. One son ...
    How to Start a Push Lawn Mower: 7 Steps (with Pictures ...
    www.wikihow.com > ... > Lawn Care
    wikiHow... there's more to it than that, especially if you want it to keep running. Of course, how to start your individual lawn mower may vary according to what brand and...
Jan 12, 2016 | Garden
Starter on snapper re110 not always working
does it crank no start/hard to restart
or
no crank
BIG difference
Oct 20, 2014 | Snapper RE110 28 inch 11.5 HP Rear Engine...
Brand new snapper mower will not start, will start if I spray starter fluid in it?
Replace that odd factory spark plug
with the old J19LM used on the 187cc
& gap at .030
Not .020 as with the useless new plug, that
even the dealers never heard of, or have an
answer for,no factory support
The new plug works barely, for about six cuttings,
then won't start as you found out
Jul 23, 2014 | Snapper 7800841 Push 217020B 190cc HI-VAC...
Snapper 16 horse won't crank
I believe the red light just shows that your ignition switch is on, your problem is voltage going to the starter which is the next step. Your switch is not doing the normal ON/START as it should . If you test that voltage is going through to the starter then your starter will need service.GOOD LUCK FRIEND.
Apr 06, 2014 | Snapper Garden
I have a snapper lawn mower that keeps blowing fuse when I try to start it.
Check all your wiring, I believe you have a shorted wire. GOOD LUCK FRIEND.
Apr 03, 2014 | Snapper Garden
Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
Jun 30, 2012 | Omega Rear Drive Wheel Snapper Mowers
I have a snapper sr928 riding mower it will crank but not start up and the neg battery cable will get hot and smoke
Check battery cable connections to make sure they are all tight. It may be getting hot from trying to start for to long. Also try starting with starting fluid. If it starts with starting fluid you probably need some work done to carburetor.
Mar 15, 2012 | Snapper Garden
Snapper Hi-Vac riding mower that won't start with starter
You may need a 300cca battery, an ignition switch or a solenoid to get things going again. I also would check to make sure the starter gear has not locked in the flywheel teeth; it will burn up the starter. You should be able to go to the snapper website and put your model of mower in and find the parts and diagrams you need.
Good Day.
Oct 26, 2009 | Garden
Snapper sr 1028 wont start with new battery
Make sure your battery is at proper volts. If it is then check the starter with a volt meter and make sure that it is getting or not getting power. It does sound like a Starter problem. But I have seen it happen on some models where someone buys a bigger battery and in return short out the stater.
Apr 08, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
131 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
