Question about Garden
I have a craftsman 2-cycle 17 in /.095 dia line string trimmer model:71-79105. The engine fires up and runs but once warmed up it doesn't have power when you accelerate the throttle. It only seems to have an idle adjustment screw, How do you adjust the high speed mixture like the older models ? The manual also says to use synthetic 2 cycle oil with a 50/1 mix.  Is it crucial to use synthetic oil or can you use TC-W3 grade 2 cycle oil using the same 50/1 mix ?  Any help would be greatful.  Thanks !
3 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: My craftsman gas weed trimmer runs but lacks power...
Hi Edward,
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 25, 2010
  • 144 Answers
SOURCE: How do you adjust the high speed mixture screw? I
Hi montex124, I will try to help. In the past few years carb makers have been making changes. Some carbs have no adjustment at all, the ports are all fixed inside the carb. Other carbs have only the idle speed mixture screw that can be adjusted, like yours seems to have. Is this screw you mention at the top and completely outside of the carb to adjust the throttle? If it is it's probably the idle speed screw which can be adjusted to any idle speed you want and has nothing to do with the air fuel mixture but If it is right next to the idle mixture screw, it might be the high speed mixture screw but is capped so it can't be adjusted. The low and high speed mixture screws should be marked next to each screw H and L.
The 1 1/2 turns suggested is sometimes just right but other times has to be adjusted, so you can try adjusting it to get your idle but maybe adjust the idle speed screw first to get a higher RPM so it doesn't stall on you. Like I said earlier it just adjusts the throttle, and is like when you are using it, and giving it gas as they say. I hope this helps just a bit. Regards and good luck. Get back to me if you need more help or just let me know how you did. Denis.
Posted on Feb 28, 2011
Why does my new Craftsman 4 cycle Trimmer's head turn counter clockwise
Curved shaft trimmers turn clockwise.. straight shaft trimmers turn Counter Clockwise. Also the Bump head is reverse threaded because of the engine rotation.
When using this trimmer , Angle the right side of the string line down so the grass gets thrown in front of you not at your legs.
May 30, 2015 | Craftsman Garden
What will cause newish sears 27cc string trimmer only run on full choke?
If the trimmer has been sitting for a long time it is probably the carb needs to be rebuilt. Before doing that check the plug and be sure you are getting fire. Be sure nothing is blocking the fuel filter in the tank. Be sure exhaust or muffler is not plugged, with only 5 hours on the trimmer I wouldn't think that is the problem. Sound more like something in the carb. You can look on you tube to see how to rebuild the carb if you have not done it in the pass it is fairly simple to do.
May 31, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a craftsman line trimmer, I believe it is model #79107, pull string to start and string will not go back in ???
This can be a challenge to repair. The Torx screws holding the casing and machine to it will have to be removed to access the starter/recoil unit. If you have opened one up before, it's not that bad...if not...it's a real learning process, Take your time, you will need Torx head screw removal tools and a little patience. Once you reach the starter unit, you will realize the problem. Go to that point and maybe post again later?
Jul 06, 2010 | Craftsman Convertible 25cc. Gas Line...
32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Sep 10, 2009 | Craftsman 25cc Gas Line Trimmer
Pull String Ripped out, How to Replace?
no its not imposssible.but its not easy unless u have done a few times.you have screws around the plasic casing get them out.and pull
shaft off engine.
Jul 20, 2009 | Craftsman 25cc Gas Line Trimmer
Runs fine when first start. Dosen't want to start after warmed up.
Have you checked or Changed the Fuel Filter.
It will be in the tank hooked to the fuel line. I suggest a small pair of Hemostats for this job.
May 25, 2009 | Craftsman 25cc Gas Line Trimmer
Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Feb 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
