Question about JVC MX-KB30 CD Shelf System
JVC MX-KB30 Will not play some CD's, some purchased and some burned. Unit comes on, disc appears to spin then stops and does nothing. Thanks
  • Anonymous Mar 10, 2008
    will not play most of my cd's
    Problem Solver:
  • 8 Answers
Have it first cleaned by a cd disc cleaner or if you are familiar with cleaning the lens manually im sure that will work...or try inserting an original cd's,if it works with that find the solution to the settings of your device...
Posted on Sep 23, 2007
SOURCE:
Jvc home component mx-kb30 protect mode on
First check that the speaker wires are not shorting, if okay! the problem is in the audio output stage of the receiver, the protect mode comes on if a load is detected.
Apr 25, 2012 | JVC MX-KB30 300W Mini Home Audio System...
Have a jvc MX-J500. (purchased as a previously owned unit) When a cd is inserted in any of the three trays it just says "no Disc". Radio works as well as the cassette player. System was dusty but appeared...
You could try a CD lens cleaning disc which will clean any dust off the laser lens. But it is possible the laser power can be low if it is an old player. this will stop the discs being read fence the fault No CD as it cant see the disc. This will mean either a new laser assembly or complete CD deck. Try the cleaning disc first and if that does not work take it to a service centre or just use it as a radio cassette in the garage.
Jul 21, 2010 | JVC MX-J700 3-Disc, Triple-Tray CD Changer...
JVC MX-KB30 will not read CD's. One minute it was working. Then it quit and says no disc even though there were 3 discs in it. I tried changing the discs, turning it off and on.
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Aug 20, 2009 | Audio Players & Recorders
How to unlock the disc tray on my JVC compact component system MX-KB30
If your CD player dose not respond to normal commands, there is a problem with mechanism. Have serviced
May 10, 2008 | Audio Players & Recorders
Error message No Disc
Unit has bad disk t-table motor
May 06, 2008 | JVC MX-J200 CD Shelf System
JVC Stereo won't open cd tray
Maybe something's jamming it, try fixing the drive, so it comes out.
Mar 16, 2008 | JVC MX-KB30 CD Shelf System
CDs won't play
Maybe you should fix the cds or clean them or try to fix the disc reader in the radio.
Nov 09, 2007 | JVC MX-KB30 CD Shelf System
Tray will not open!
press &hold stop then press the eject button.
Nov 04, 2007 | JVC MX-KB30 CD Shelf System
JVC mx-kb30 Stereo comes on then goes right back off.
A desperate longshot but the only i have to offer: It might be a problem with the electricity. if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local JVC dealer. If you're out of warranty I suggest locating a professional repair person. Good luck
Jan 24, 2006 | JVC MX-KB30 CD Shelf System
JVC MX-KB30 CD Shelf System Logo
159 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
