Question about RCA RS2663 Shelf System
5 disk cd player skips or wont play cds - RCA RS2663 Shelf System
  • Anonymous Apr 23, 2009
    I think something else is wrong. I cleaned the lens several times, and the CDs are brand-new. Any other ideas from anyone?
    New Friend:
My cd still won't play and I just cleaned my CD player what do I do now??
Posted on Jun 15, 2013
    Genius:
  • 1,550 Answers
Check if you are using a good quality cd's and still you have the problem check if the cd's r clean and out of scratch and in good condition
after this still you have the problem then its the player fault
the lens inside the player must be cleaned
so, use a lens cleaner and clean it and then check it
thank you
Posted on Apr 22, 2009
Cds won't play
OK, your discription of your problem is rather vague.
Do they try to play but skip or make god awful noises? Or do you have no audio at all?
If they are skipping check to make sure there are no smudges on the underside of the CD. If so clean them with a soft cloth,
Sometimes severe scratches can cas the same problem. You can buff out some scratched using tooth paste or you can by a scratch remover that they sell in stores (it is a gadget that will clean and buff out some scratches available in many stores).
If you have any of the label missing then this is a worse issue. It is actually the top of a CD that you need to be most careful about scratching because if you remove the laquer that protects the silver layer of the CD it will remove part of the silver with it along with any audio or data that is on it. There is no repair for this.
If you have ruled out a damaged or dirty CD then be sure you are not trying to play a CD that has data files intended for computers on a player that cannot open them. The best way to do this is to check the CD on a computer and open the drive folder and view the contents of the disk. Files such as MP3, WAV, WMA and others will not play on a standard CD player. If the files are CDA that is a standard audio CD formatting. So next see if the disk plays on the computer.
If the CD plays on a computer then return to the CD player and attemp playing again. Make sure that the player recognizes the CD being in the tray. Also, verify, if you can that the CD is spinning within the player when you play. If the CD is not spinning or the player does not recognize rge disk try a disk you know to be undamaged.
If you still have problems then you will have to have your player repaired or replace it.
Sep 12, 2012 | Audio Players & Recorders
I have a 2006 Mazda 3 and the cd keeps skipping to the point that Im not able to listen to my cds
Sounds like your cd player is dirty or the disk you are trying to play is scratched and not useable?
You can purchase a cd disk cleaner at any department store or office supply. All you do is play the disk and follow the instructions. Some come with a mix of alcohol & water and have small brushed on the disk itself to place the liquid and this helps clean out your equipment. Others clean without liquid.
Check the disk itself for scratches and try wiping it off with a lint free towel. After cleaning your cd player, try playing it again and if it still skips - replace the cd. If a brand new disck skips in your disk player after cleaning it then your lazer might need repair and I would recommend taking it in to a local stereo installation and/or repair shop.
Jun 07, 2011 | Car Audio & Video
I bought a Radio Shack cd cleaner (cd w/little brush on it) to clean the lens of the cd player however the machine won't recognize the disc when inserted so I cannot figure out how to "play" it. Many of...
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
Jul 16, 2010 | Sony CDP-CE575 5-Disc CD Changer
My jensen wont play cds wen it dose it skips
use a common cd/dvd optic cleaner .... they are cheap .. what is going on is your cd player cant find a track so it shuts off ..
Feb 10, 2010 | Jensen Car Audio & Video
Car cd player won't read cds
I have a Dual xdvd8180 dvds multimedia reciever 7" digital touchscreen in my car and it worked fine for the longest time but now it wont read any of my cds.. burnt or original discs.. nor will it read dvds.. i tried cleaning it with a disk cleaning kit and it wouldn't even play that without skipping..idk whats wrong.. any help??
Jan 04, 2010 | JVC AM FM CD DET FACE CAR STEREO
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Skipping all CDs
Laser is duff uses the old sony kss family i believe,easy to change and get on ebay..
Jan 02, 2009 | Yamaha CDX-393 CD Player
Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
In-Dash car cd player
It sounds as if you've covered about as much as you can do without pulling it out and taking to the repair shop. Something you should definitely do if all this skipping is taking place whilst the car is stationary. A lot of earlier car CD players wouldn't accept the burn it yourself type disks and perhaps the factory CD was damaged. Try a few more factory CDs before you do anything else. Just because a disk plays on the Computer or cd Player in the house doesn't mean it will behave itself in the car. If you've has the unit for a while you could have the smear of grease they put on the worm drive gummed up with dust and this is stopping the disk carriage from moving freely. Or perhaps the heads are out of alignment due to constant vibration from rough roads. Either of these problems would mean a removal and either a clean or the repair shop. BMW
May 31, 2006 | Durabrand WD810
RCA RS2663 Shelf System Logo
342 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
