Question about Sony VAIO PCV-RS720G (027242658103) PC Desktop
Lost sound I keep losing my sound on this Sony PC, can anyone help? Seems I have major soundcard issues, and have to completely reboot in order to regain sound for no more than 5 or minutes.
  • Anonymous Apr 22, 2009
    Yes, I have updated my drivers with success, until... I open a IE Window, then the sound is gone again. Once I close IE, I get the sound back.
  • EricS777 May 11, 2010
    is your sound driver up to date
  • 89 Answers
I had a problem like this, all i did was update my Drivers, if not i removed all my sound drivers and redownloaded them. give it a try, might help, might not(:
Posted on Apr 22, 2009
My computer cannot play any tracks and the screen resolution setings is not woking and the color depth84@yahoo.com
I'm assuming by playing tracks you mean music. Check that your volume is up and not muted, check to see if the soundcard works with headphones as it could be a speaker issue (make sure they're powered on). Try re-installing the soundcard drivers... if your color depth is also very low it sounds like either the PC booted into safe mode due to a previous issue (rebooting may resolve, if prompted select normal startup) or worse you've lost some drivers for whatever reason... reinstalling this could get everything back the way it was. If it's just a color issue, right clicking on your desktop and choosing properties to change the resolution and color depth will fix... assuming you're using windows.
Mar 07, 2011 | Computers & Internet
My Gateway NV52 was playing a movie then it went black. no external mouse connected. when I reboot this darn thing all i get is a black screen and none of the red lights will light up. I see that the power...
Since i dont have more details about the issue, i would recommend a complete system recovery.
Power on the laptop and keep tapping Alt+F10.
That will take u in to the recovery mode.
Select complete system recovery.
This process will take around 30 to 45 min and make sure u plug in the AC adapter.
Also note that u will lose all your datas.
Jan 04, 2011 | Gateway NV5216U Notebook
Sound card driver has not found
Firstly just try and reboot your system, sometimes the soundcard become corrupted with shared files. If this fails then go to microsoft support and search for the driver of the soundcard nominated in your device manager. I had this problem for a while and had to keep rebooting the system, then it suddenly fixed itself, probably created by a windows update.
Jan 25, 2010 | Microsoft Windows XP Professional for PC
Soundcard problem acer aspire 5735
Try reinstalling sound driver. if still the same issue try external speaker to check if they have same issue. if external speakers work fine that mean its not driver issue and problem with your notebook speakers replace them.
Good Luck
Feb 04, 2009 | Acer Aspire 5735 Notebook
Configuring two soundcards for parallel functioning
a windows computer can only use one sound card for one function
you can use the internal sound card for output
you can use the usb sound card for input / recording.
you can't use both for both.
Start -> control panel -> sounds and audio devices properties
open up audio page
You can have one device selected on Sound playback
You can have one device selected on Sound recording.
you can change which sound card is used for which function on this page. if you want to use the internal sound card set both settings to the internal if you want to use the external change both settings to the external.
Jan 09, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Windows does not play nicely with 2 sound cards. Perhaps one of these days Microsoft will get out of the stone age and recognize other options, but for now, the general consensus is that it is not feasible.
About the only thing I have seen is to turn off one sound card in the hardware profile, but that is not what you are trying to do.
Jan 09, 2009 | ASUS VIA Apollo Pro Plus Chipset P2V-B...
USB Audio Controller and Interface Won't Install on Dell 600m
This is generally caused by a driver conflict. Uninstall the sound drivers for the built in, then try to install the sound drivers for the RMX. If the hardware wizard finds and tries to install the drivers for both sound cards there may be a conflict, due to the drivers for the built in still being in the drivers cab file, then you will have to completely delete the driver file manually. Once you get the RMX drivers to load, you may have to create a seperate sound profile for the RMX, and switch to it manually when using it, in order to keep from creating a conflict between the two.
Jul 09, 2008 | Dell Inspiron 600M Notebook
Sound card has become inoperable since I loaded on the IKmultimedia software
It seems your system complicates soundcard's driver version and patches. To eliminate problem that causes inoparable one at a time; please consider to uninstall software sound applications and drivers. Remove any secondary or external sound cards and enable the built-in sound card at the BIOS. Now, start the system in Safe Mode try to remove the existing soundcard drivers at control panel sound card properties. Restart the system, well try to prove that the built-in sound card still working by reinstalling it. By then you can disable it again and install your secondary or external sound card. Hope it will work this time, else you'll need to clean up your Operating System astrays dll's using registry cleaners third party software. I met this problem before that my only recouse is by reformatting the system.
Best regards,
Rosener Guyano
Feb 01, 2008 | Focusrite Saffire Pro Sound Card
Lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Jan 31, 2008 | LG 42LC2D 42 in. LCD HDTV
Sony VAIO PCV-RS720G (027242658103) PC Desktop Logo
135 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
