Question about NEC MultiSync MT830 Multimedia Projector
NEC MT800 Projector with Vertical Lines in picture
Hi, My GF's NEC Multisync MT800 yesterday has started to show vertical lines across the whole picture. Now they change colour depending on the content of the picture but mainly appear to be red and green. I am wondering if it is something to do with the colour "panels" starting to fail. Any adivice on what it might be and a possible way forward would be great. Thanks.
  • 4 more comments
  • adamcundiff1 Nov 10, 2007
    I have had my NEC mt830+ projector for about a month. Got it on Ebay. it was fine for the first few weeks. Now when I run it over an hour (sometimes it will go longer) it starts to get very annoying vertical lines. It really distorts the picture. If anyone can help that would be great.
  • Anonymous Jan 28, 2008
    bought this off of ebay a few weeks ago and just the last few days I have had a problem of 3-4 yellow, blue, purple lines on the right side of the screen. Is this a problem with the lamp? I only have 700 hours on the lamp
  • Anonymous Mar 29, 2008
    WE ARE ALL SUCKERS. I BOUGHT THIS PROJECTOR OF EBAY AND GUESS WHAT, SAME LINES. I BELIVE THE MORAL OF THE STORY IS DON'T BUT EXPENSIVE ELECTONICS ON EBAY.
  • REDNECK-76 Mar 29, 2008
    I GOT MINE ON EBAY TOO, AND GOT THE SAME LINES. I HAVE NOTICED IT ALSO DOES IT DURING START-UP AND FADES AFTER ABOUT 40sec. MY BULB USAGE SHOWS 40 HRS WHICH IS B.S. THE BULB HAS A BURN MARK ON IT SO I THINK MAYBE THE PROBLEM IS RELATED TO THE BULB. ALSO THE PROBLEM SEEMS TO BE GONE FOR THE FIRST HOUR OR SO EVERY MORNING. THE ONLY VARIABLE I CAN THINK OF IS TEMP. MY FILTER IS CLEAN AND SO IS THE INSIDE OF THE PROJECTOR. ANYWAY I DON'T HAVE THE BALLS TO THROW ANOTHER COUPLE HUNDRED BUCKS DOWN ON A BULB SO TO HELL WITH THIS P.O.S. I THINK THE MORAL OF THE STORY IS DO NOT BUY EXPENSIVE ELECTRONICS ON EBAY.
  • elvis3 Jun 11, 2008
    i am after a spares or repairs nec mt800
    any one got one
    just bought on off ebay and they said it just needed a new bulb so bought one
    and its just showing yellow when turned on
    thanks
  • Anonymous Oct 09, 2008
    the lines are horizontal and cause distorted picture
    Scholar:
  • 52 Answers
The ghosting problem is a combination of both the lcds and driver boards in which case neither need to be truely replaced.. They use a specific voltage to transmit data to the lcds.. Each lcd is different and the driver board is programmed by the factory for the EE v.com setting. Unfortunatly with nec, they do not offer a service mode to go in and adjust the ee settings to correct the electrical convergance. So the only way to fix the problem is to replace the lcd with a newer one who wasnt worn out from long term heat.
Posted on Feb 24, 2009
  • 32 Answers
Try cleaning the filter on the bottom of the unit, might be overheating issue
Posted on Mar 16, 2008
The problem is the LCD driver board. It is not something that can be fixed without a replacement board.
Posted on Jan 21, 2009
SOURCE:
Hi, NEC P221 W multisync has increasinly been displaying fine vertical cyan and magenta lines, most evident on white areas and grey areas respectively.
Your monitor is no longer in production but there might be some support for it. Go here to see what's available: Product Support You might need to upgrade.
Jul 28, 2017 | NEC MultiSync FE950 (White) 19" CRT...
Panasonic vertical color lines
It seems that the lcd panels are failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jan 07, 2014 | NEC Office Equipment & Supplies
The projector is an NEC model VT590 and is connected to my computer for use with a SMARTBoard. In the bottom left hand corner a pink colour is starting to grow inwards. In the upper left hand corner, there...
It is not the smartboard, lamp or the computer as well know, it's the projector itself. This may not work but you at least need to try press the auto adjust button on the projector and then adjust the clock/phase in the menu. If not you will need to send in to NEC it could by the color wheel. Usually they have a warranty for a couple of years.
Jun 05, 2010 | NEC MultiSync VT590 LCD Projector
Multiple reddish pink vertical lines going from
Hi
We can check if the problem is on the hardware(projector) itself or if from source(device connected to projector) try to turn on projector without connecting any other devices to it. If you can still see the pink line- try to remove bulb and reinstall it. If all fails and pink line still visible, there is a problem with projector. If no line is present- check settings and change input signals.
Hope this helps
Mar 26, 2010 | ASK Proxima DP6860 Plus Multimedia...
NEC px-42vp4g/s 42in.plasma monitor PDP:np42b3mf01...
I have the same problem with vertical coloured lines on my NEC PX-42VP4G/S. The photo only shows a black background just so it's easier to see the lines in the photo but normally the picture is OK except for the vertical lines which aren't always in the same place.
If anyone can advise on exactly what I need to replace then I would be very grateful.
Regards, Simon.
Apr 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
NEC MultiSync MT830 Multimedia Projector Logo
3,551 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
