Question about Microwave Ovens
Turntable ring assembly seems to be nonexistant!
I'm looking for the roller ring assembly that turns under the glass tray in my Thermodore microwave - model num MBBS/01 My microwave and any parts seem to not even exist! help me find them!
  • neecieap Apr 22, 2009
    OMG - if its there I will find you and hug you!!
    IT WAS "OUT OF STOCK" OF COURSE BUT AT LEAST I KNOW WHAT TO LOOK FOR!
  • 10,865 Answers
Http://www.thermador.com/SupportCenter/Parts.aspx
click on this link to obtain your part
Posted on Apr 22, 2009
Is there a replacement microwave for the Thermador MBBS/01
The MBBS sereis was replaced by the MBES series.
Specs are here.
Nov 27, 2012 | Thermador MBBS Microwave Oven
I need to replace the waveguide in my Thermador MBBS / 01 microwave.
Waveguide "cover"I presume? The waveguide is part of the chassis and cannot be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 26, 2011 | Thermador MBBS Microwave Oven
Metal propeller still turns but plastic three arm proellers is broken therefore Glass tray does not revolve
you can order a new turn stub from thermador at there web site they cost around $ 15 and just pull out and push back in
Feb 15, 2011 | Thermador MBBS Microwave Oven
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Internal turntable will not rotate
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is about $35 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. If you need assistance identifying the correct part number, please post back with your complete MODEL NUMBER and I can assist you. I hope you find this information helpful.
NOTE: Even though the carousel may not be turning, you can still use the microwave while awaiting parts. You will need to physically rotate whatever you are heating about midway through the cook time to ensure even heating. Early model microwave ovens were not equipped with a rotating carousel and this was the common routine.
Dec 16, 2010 | Thermador MBBS Microwave Oven
Plastic peice that fits under plate inside micowave that makes it rotate
If the model number you have this question listed under is correct, there are two possible parts based on your question. There is the carousel ring, that turns the glass tray, and there is the small plastic coupler that the center of the glass tray is supported by. The part numbers are as follows:
Carousel ring - WB06X10513
Coupler - WB06X10564
You can view and excellent exploded view diagram of this microwave at pcappliancerepair.com. The parts I mention are listed under Diagram 1151005 as items 84 and 101 respectively.
To replace the coupler, you simply remove the glass tray and gently pry straight up. The coupler will pull off of the turn table motor shaft. Insert the new coupler and press on to the shaft.
If this is not the correct model number, please post back with your correct information so that I may be able to provide you with better assistance. I hope this helps you.
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
TURNTABLE INOP on mbbs/01 thermador microwave
easy...first thought it was a program glitch. turntable could be turned off manually. nope ...just a bad motor needed replacement
Sep 14, 2009 | Thermador MBBS Microwave Oven
My turntable quit turning, I looked in and found a what appears to be a piece of what looks like glass that acts as a shaft between the motor and the turntable was broken. I cant find the part or any...
If you are talking about the little piece that the center of the tray sits on (not the carousel ring), its called the coupler. Its actually made of plastic on all the microwave ovens I've ever worked on. I've never seen one made of glass. It connects to the turn table motor shaft. If you post back with a complete model number, I may be able to assist you in locating a part number.
If the coupler is not physically broken, you may be identifying the wrong part as your problem. The turntable is driven by a small motor which is mounted under the bottom panel of the oven. The coupler is mounted to the shaft of the motor and the glass tray sits on the coupler.
Post back and let me know if you need a coupler, or if your motor isn't turning. You can tell by removing the glass tray and pulling straight up on the coupler. It should come off the motor shaft in one piece. If its not broken, your motor probably needs replaced.
Sep 09, 2009 | Microwave Ovens
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Microwave Ovens Logo
151 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
