Question about Lexmark X1270 All-In-One InkJet Printer
Paper wont feed propaly
The paper is feeding wonky! the roller is on the right is pulling the paper to the right but there is nothing to pull the paper on the laeft side so it is not feeding and I cannot print anything. Brand new printer has worked last 4 times of printing. Help! Thanks
  • 13 more comments
  • russabs Sep 23, 2007
    No, no paper jam! thanks
  • russabs Oct 10, 2007
    it is a lexmark x1270
  • Anonymous Nov 06, 2007
    I have a canon multipass 730, that won't feed correctly. I've been trying to clean the roller via the maintenance menu, have examine the pathway as best I can, turned it on & off, cleaned & aligned the heads. When people say to clean the roller, there is a roller on the R that seems to be cushiony, not shiny. So it seems that's ok.
    Same feeding pattern wherein the rt side (looking down at it) feeds, but the l side seems not to.
    Annie K
    MA
  • lil_pinky Nov 13, 2007
    my lexmark x1270 wont take the paper correctly i tried everthing like cleaning the rollers new ink holding the paper etc. please help me its only 4 months old only used it like 6 times so far
  • Anonymous Nov 15, 2007
    i have a lexmark p4350 i have been trying to print some stuff but the paper keeps going to the right and getting jamed. i have tride cleaning it all holding the papers taking the back of it so i might make it easer to print but nothing i try is working.
  • Toaker Dec 19, 2007
    My printer feeds the paper all wonky. How do I fix it?
  • marakg11 Feb 29, 2008
    printer is only pulling the paper on the right side.
  • Lothlill Mar 26, 2008
    I have a similiar problem with a HP DeskJet 5740. It takes the paper and feeds it through at an angle...then it jams. Have opened the back and cleared all the jammed paper, turned it on and off and it still does it. It looks like the paper may be catching a the top of the page has nicks in it.
    Any ideas or is it time to invest in a new one?
    Thanks
    Linda
  • Anonymous Jun 08, 2008
    I had the same problem. Turned out it was a paper clip that dropped into the left side of the printer (as you are facing it).
  • Anonymous Sep 06, 2008
    Help! I have a fairly new printer that keeps pulling mainly on the right side....when the left side does ngrob on the paper crumples in the middle and the paper is printed on at strange angles.
    I'd hate to have to replace it for this problem.
    Thanks
  • rbgirl Sep 10, 2008
    OI have a Lexmark X1270. I have the same issue, where the paper pulls on the right side of the printer. Sometimes, even multiple pages are pulled through. I tried shaking it and holding a pencil to the left side (like the suggestions states). Nothing has worked. When I finally called a Lexmark Technical Support person, all they could do was send me a Lexmark coupon to purchase a new one online.
    It is so sad that we have become such a wasteful society, that many times, the solution is to "buy a new one"!!
  • Kreesh Jan 25, 2009
    The roller is only pulling a little on the right side, and I cant print anything. The printer says please load paper because the roller isnt pulling the paper.
  • Anonymous Feb 05, 2009
    I've got this Printer and only used it a few times and then just the other day for no reason at all it started feeding the paper through at a wonky angle. I'm watching the rollers as its doing it and there is no visible reason for it to happen :(. Need to print job application!!! :'(
  • Anonymous Mar 08, 2009
    hi, im having the same printing problem. canon mx300 all in one ive tried everthing(cleaning,etc) except opening it up to look inside. it is little over a year old. any help appreciated. thanks.
  • Anonymous May 23, 2009
    i have the same problem
    Problem Solver:
  • 5 Answers
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Posted on Oct 16, 2009
  • eeener Jan 16, 2011
    I shook mine upside down and out fell a plastic piece. I could of sworn I looked down in there and nothing was there. But read your findings of chips and twa la MY PRINTER WORKS NOW.
    Scholar:
  • 68 Answers
Check to see if the roller has a paper jam. Please contact me back so i can help you further if it is not a jam
Posted on Sep 23, 2007
Toss the canon. Mine last two have died like that... one after 1.5 years, this newest 4300Pix after only a few months. Starts to feed the paper crooked, seems like there is a jam, but never one, no paper jammed. Product control is terrible with most printers now.
Posted on Oct 22, 2007
  • 97 Answers
Re-install the driver make sure that it is set for tractor feed not A4
Posted on Feb 16, 2008
Have same problem with x1270. Fixed it by using glue on a pencil to the opposite side of the paper tray from the roller. This acts as a guide that prevents the paper from rotating while being pulled.
Posted on Nov 20, 2007
  • InLexHell Nov 20, 2007
    Have same issue on x1270. Fixed with pencil. Glue pencil to left side (opposite of roller) of in-bound paper tray. This acts as a guide to prevent paper from rotating.
  • iSingHoly Sep 03, 2010
    where do I glue the pencil? through the top, or down under on the tray- I really love this printer- I've had it for about 4-5 years, and would like to keep it, especially since I just bought new ink cartridges! Any help you can give...
  • 64 Answers
What make/model of printer is it? certain printers only have one roller some have as many as 4 and are suseptable to breaking very easily
Cops
Pete@wedotoners.com
Posted on Oct 10, 2007
Hi, I'm having exactly the same problem with my lexmark x1270. I've checked and i cant't find any jammed paper in the printer! The roller appears to be moving fine so i'm very confused! Can anyone help further?
Posted on Oct 08, 2007
    Guru:
  • 558 Answers
  • Paper is jammed in the paper path of the printer or Automatic Document Feeder (ADF).
  • Multiple sheets of paper are being fed through the printer at one time.
What to do
Is the jam in the
paper support?
  1. Press  to turn the printer off.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press  to turn the printer back on.
Is the jam in the Automatic
Document Feeder (ADF)?
  1. Flip open the ADF by grasping the notch in the left side of the ADF and pulling up.
  3. Close the ADF.
  4. Press .
Is the jam in
the printer? To automatically eject the paper:
  1. Press and hold .
  2. Remove the paper from the paper exit tray.
Posted on Oct 29, 2008
I have a Canon PRIXMA 190, it's a couple months old and I hardly use it and when I do it's fine... until now. It too has formed this habit of pulling the papers in to the right corner. Why they don't have this magic paper pulling roller in the center so it grabs the whole page I don't know. The more I have this problem I begin to believe it's designed so we have to, as someone else mentioned, "get a new one."
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
Paper rollers wont feed paper from paper tray
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Sep 03, 2010 | Samsung ML 1710 Laser Printer
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
It sounds like the motor on the left side went out. If it's a brand new printer your best bet would probably be exchange it at the store or see if the manufaturer has a warrenty. If it's an older printer I probably wouldn't try to get it repaired, printers are getting cheaper these days and it probably wouldn't be much more to get a new one.
May 26, 2009 | Canon PIXMA MP520 InkJet Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Riso tr1510
Take one of those flat plastic rulers and push it through all over.. so that any forein ripped paper whatever, clears the way.. The paper is supposed to buckle on entry.. That's how it's designed. It could be a timing issue.. when the paper is fed in it buckles against the timing roller.. the roller turns only when its supposed to. Each sheet stays buckled against the timing roller until it turns, that's how the machine draws only one piece at a time. It's could be the feed clutch.. There's a little magnetic clutch that actuates the feed roller to pull the paper in. when this feed clutch gets weak it barely works or it slips and doesn't pull the paper in at the right time. I've replaced these often on my equipment.. but I've also found that static electricity plays a big role. If your area is too dry, the paper sticks together increasing the resistance, pulling either multiple pages or just too much resistance for the feed rollers.. screwing up the time.. Make all adjustments to the feed rollers first to ensure it's not a huge problem before you start looking for a clutch. Essentially if the paper doesnt make it into the feed roller on time it is a timing issue.. but it's starting from the feed rollers.
Feb 03, 2009 | Sweet Beginnings Cabana Stripes Crib
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Paper won't feed
Pull out the paper tray and push the paper feed roller towards the machine. Try to turnaround the paper feed roller by hand. Reinsert the paper tray.
Nov 02, 2007 | Brother MFC 420CN All-In-One InkJet...
Lexmark X1270 All-In-One InkJet Printer Logo
3,233 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
