Question about Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
My mini chopper will not get gas to the carb.
I have a mini chopper 50cc and will not get gas to the carb. if u can help me please call me at 228-447-3101 or 228-875-9798 my name is Dustin!!! THANK's.
call time 10am to 10pm
please no emails.
I need to know the size of the center hole on a 19 tooth transmission sprocket for an apc mini chopper Thanks
Why do you need to know the size of the centre hole. That one look in great condition. The size is the size of the shaft it fits on, so you measure the narrower distance, which is between the sprocket tooth that is under the middle of your thumb nail, to the second tooth past your index finger. All this links have info.
  • mini chopper sprockets ' eBay www.ebay.com > Search > mini chopper sprockets Refine your search for mini chopper sprockets. ... Mini Chopper Pocket Bike Parts 19 Tooth Front ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ...
  • mini chopper sprocket in Parts & Accessories ' eBay www.ebay.com > Search > mini chopper sprocket Find mini chopper sprocket from a vast selection of ... Mini Chopper Pocket Bike Parts 19 Tooth Front Chain Sprocket ... APC MINI CHOPPER 48" THROTTLE CABLE ...
  • I need to know the size of the center hole on a 19 tooth ... www.fixya.com > Forum > Motorcycles > APC ... a 19 tooth transmission sprocket for an apc mini ... on a 19 tooth transmission sprocket for an apc ... rear 28 tooth sprocket for an apc mini chopper.I ...
  • Mini Chopper Sprocket and Clutch - DIY Go Karts www.diygokarts.com/chopper-plans/drive-assembly.html ... a torque converter can be used which effectively gives the project an automatic transmission. ... mini-chopper's clutch ... tooth #35 pitch. This size sprocket ...
  • mini chopper parts ' eBay www.ebay.ca > Search > mini chopper parts mini chopper parts 352 listings. ... 28 Teeth Rear Driven Sprocket L for #410 Chain APC Mini Chopper ... #428 Chain 17 Tooth 14mm Pitch Sprocket Part Gear Go Kart ...
  • Sprockets - PartsForScooters www.partsforscooters.com/Pocket-Bikes-Parts/Pocket-Bikes-Sprocket Mini-Chopper Parts; ... 127-19 . Stock 6 Tooth Front Sprocket with M10x1.00 thread size for 47 and 49cc 2-stroke cag style pocket bikes and mini-quads.
  • Mini Chopper Parts ' Mini Bike Parts ' We Ship https://www.gokartsupply.com/chopper.htm Home >> Parts Catalog> Mini-Chopper Parts. Parts For Mini Choppers Seats - Hand Controls - Fenders. ... SPROCKET 60T #35. 7-1/4" 28.50. 04-470. SPROCKET 72T ...
  • Electra / APC Mini Chopper w 49cc PS engine - Pocket Bike ... www.pocketbikeplanet.com/showthread.php?t=84442
    • 20 POSTS
    • FIRST POST: 2014-06-29
    2014-07-26 ยท Electra / APC Mini Chopper w 49cc PS engine Mini Choppers. ... Sounds like you got a transmission with slag on the internal gears ... do a search as mini chopper parts.
  • mini chopper bike ' eBay www.ebay.ca > Search > mini chopper bike Find great deals on eBay for mini chopper bike and ... 43CC 49CC APC MINI CHOPPER MINI BIKE MONKEY ... 17 tooth sprocket gear Pocket Bike Mini Chopper ...
  • Rawge's Mini Chopper Information Site - Gearing and Sprockets www.rawge.bravepages.com/minichoppers/speedo.htm Rawge's Mini Choppers ... The Simple Mini Chopper Drive ... you can expect from your mini chopper, given the size of the sprocket on your ...
  • Pagination
  • Apr 08, 2016 | APC Motorcycles
    Hi, anyone know what the factory carb settings are for an aeon mini kolt 50cc. Having problems with getting it started, changed spark plug and battery
    Two-Stroke Scooter / ATV Carburetor Settings And ...
    ? 4:37
    https://www.youtube.com/watch?v=A1vRMERs4RQ
    Jun 2, 2012 - Uploaded by 90GTVert
    Part 2 of a 4 part video detailing all of the basic settings and ... Two-Stroke Scooter / ATV Carburetor Settings ...
    Fix your Mini bike Carb - bogging, cutting out etc - YouTube
    ? 4:51
    https://www.youtube.com/watch?v=lbtDMFUiD0k
    Aug 15, 2011 - Uploaded by Cpt MishMash VonRandom
    If you are having trouble with your mini bike/quad whereby its difficult to ... Two-Stroke Scooter / ATV ...
    quad 50cc carb Questions & Answers - Fixya
    www.fixya.com > Forum > Tags
    50cc carb wondering what the factory setting is for a 2002 50cc Kawasaki kid's ...aeon mini kolt 50cc quad will rev a little then cuts out no power Likely a lean ...
    Aeon mini kolt 50cc quad will rev a little then cuts out no ...
    Jan 05, 2016 | Factory Motorcycles
    What are the manufacturers recommended tyre pressures for a 2005 Pagsta 50cc mini chopper motorcycle
    Hi John, tire pressures are stamped on the sidewall. Good luck and have a nice day.
    Nov 14, 2015 | Pagsta Motorcycles
    Locin Mini Chopper 50 wiring diagram
    Hi, Mark for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Locin, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
    Loncin Mini Chopper 50 wiring diagram Google Search
    http://www.miniriders.com/tech-talk/33869-loncin-50-cc-4-cycle-mini-chopper-wire-diagram-needed.html
    http://pdfstream.manualsonline.com/2/21974fa7-afaf-4639-b031-f2b17eea61e4.pdf
    HOT Chinese Parts for Loncin Engine Powered ATVs and Dirt Bikes...
    http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
    Oct 24, 2013 | Loncin Motorcycles
    What would stop my 49cc mini chopper motor from starting?
    Put the choke halfway in the middle and try pulling while twisting the accelerater
    Oct 16, 2013 | Garden
    What could be causing my 49cc mini chopper motor from starting?
    If its a brand new carb and you have compression and spark most likely the problem is the idle mixture screw is turned in too far or turned out too far I think the proper setting is 1and a half turns out from being lightly seated .if that doesn't work check your spark plug for proper gap or clean it
    Oct 12, 2013 | Garden
    50cc mini atv wont start
    do a compression check if its under 100 psi could be piston rings are bad or leaking gaskets.
    Mar 26, 2012 | Cycling
    Mini gas scooter dont start
    Does it have gas? just kidding. Even experienced mechanics forget that one. It may not be getting gas into the engine though. I use an old trick, disconnect the air box boot from the carb, cup the carb inlet with my hand, which is called a hand choke, and turn the engine over while hand choking. Your hand should get wet with gas. Remove your hand after a couple of seconds or so, it may start, or try. If not hit, pull the plug and lay it on a good ground on the engine, do not touch while cranking over the engine to check for spark. These are two of the basic requirements of an engine.
    Nov 22, 2009 | RTO 50cc Classic Gas Moped Scooter
    My 50cc mini bike starts then dies 5 secs after starting. why?
    It sounds like you may have 2 problems
    • Bad gas
    • dpossible loose spark plug( bad compression)
    Solution
    dump out the gas put new in
    Remove the spar plug and examine the plug if it is wet and black it is fouled
    if it is white ad dry it is not getting gas
    If you can replace the spark plug if not just clean it with a wire brush put back in and tighten
    Finally make sure the spark plug wire is not lose
    Best of luck to you
    Jan 01, 2009 | Mini Motorized Bike
    Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
    80 people viewed this question
    Top Makita Garden Experts
    JOHN LAPIER
    Paul Sikkema
    Paul Sikkema
    Are you a Makita Garden Expert? Answer questions, earn points and help others
