Question about Samsung TXH2556 TV
I have a Samsung TXH2556 TV. This TV will not recognize a DVD player. A VCR machine and combo VCR/DVD player will work but only sound when I connect my DVD player, no picture. Any suggestions?
  • 308 Answers
SOURCE: Samsung TXJ2754 (27") DVD issues (Sound but no Picture)
Assuming you have picture on the TV when hooked up to cable, antenna or satellite I would take the DVD player to a friends house to see if it worked on their set (using your cables of course). If you can't get a picture on your TV no matter what, then it could be either the Jungle IC or EEPROM IC inside the set. Since it displays "No Video Signal" on the screen, that leaves out the High Voltage section of the TV. My main suspicion would be the video cable or settings on the DVD or TV.
Posted on Jan 03, 2007
Merkader
  • 21 Answers
SOURCE: no colour when dvd player connected to tv
I would try a different set of cables to hook up the dvd player, sounds like you either have bad wires or bad ports on either the tv or dvd player. Test each and see which one it is, hopefully it's only a set of cables.
Posted on May 05, 2008
ginko
  • 19396 Answers
SOURCE: VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Posted on Jul 26, 2008
SOURCE: Samsung dvd/vcr combo, dvd says "no signal," was working, vcr wor
On the remote, clicked a botton on the bottom. Don't have it with me so can't remember which one. Will look and post answer. Thanks
Posted on Dec 08, 2008
MNfisherman
  • 11896 Answers
SOURCE: Problems setting up DvD Play and Wii
TRY DIFFERENT CABLES OR USE DIFFERENT INPUTS. AND BY THE WAY, YOU CAN PLAY DVD'S IN YOUR WII
Posted on Apr 05, 2009
Using your DVD-V4600, how do you play a vhs tape on TV? Need step by step instructions.
In order to watch either DVD or VHS on your TV ,you need to make the following connections ..
  • You need to connect "DVD Player / VCR Combo" to" TV " as (Audio/video output of DVD Player / VCR Combo -TO- Audio/Video input of TV) ..
  • use either "RCA analog (red/white +yellow ) " or "SCART "or "Optic " cable.(any standard optical cable )...if exist ,optic is the best way to connect it..Remember your DVD Player / VCR Combo 's "OUT" goes into" IN "of the TV ..
  • pls also remember,wherever you connect your DVD Player / VCR Combo on your TV ,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Samsung DVD-V4600 DVD Player/VCR
Need wiring diagram to connect to Philips HD TV
On the back of combo, use the side that says DVD and VCR out. Connect red, white and yellow cables from the output on the combo to the input on the tv. Use the tv remote and switch input of tv to where you plugged it in.
Aug 10, 2010 | Samsung DVD-V4600 DVD Player/VCR
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
I have connected my DVD/VCR to my Samsung 32 inc television but I get no sound
I had a strange issue yesterday too.
Our Samsung DVD/VCr all in one combo did a similar thing.
I used the HDMI cable for the DVD into the TV input labeled HDMI/DVD. That worked okay.
But the VCR part didn't work.
At one point I got sound but no picture. Using the RCA cables in the back on another input "Component 1"
I was trying to squeeze the best picture out of the player using the S-VHS cable.
I thought it did picture only, but the Plasma seems to be more picky about input sources.
I got everything to work keeping the DVD as a separate HDMI to Plasma TV feed.
The VCR was 3 RCA's Yellow (picture) red and white for stereo sound.
I then reset (toggled through the inputs to "reset" the TV.
It finally worked but I was two days mulling it over.
See if this works for you.
My TV was a Panasonic Plasma, but shouldn't matter.
Skip the S-VHS line and connect the inoputs with the TV off.
You MAy need to go into the input of set up menu on the TV (ours had a wrench as an icon) and set the Component 1 or 2 to "VCR".
Aug 04, 2008 | Samsung Televison & Video
Dvd connection to cable
Connect cable on combo player cable in post to time warner cable box cable out post. and connect the combo player to TV with audio and video patch cords.
Jan 16, 2008 | Samsung DVD-V3500 DVD Player/VCR
Can I connect a dvd player to a dvd\vcr combo
I am not sure I understand why you would hook a dvd player to your combo.You should just hook your magnavox directly to your tv.
Sep 24, 2007 | Televison & Video
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Televison & Video Logo
57 people viewed this question
Henry  Thomas
Henry Thomas
