Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
DVD door won't open
Have the same problem as "debbynurse". DVD door is stuck with dvd inside. DVD won't eject, with or without the remote. Help!!
  • 1 more comment
  • exjetmech Sep 27, 2007
    I actually took the cover off the unit and manually spooled the dvd tray out. That however is not the problem. The dvd player won't work. Any suggestions?
  • Anonymous Nov 16, 2007
    dvd player will not go back into the unit. how do i fix it?
  • sbobsbob Jan 05, 2008
    Did the knofe work ?
    Mine is only a DVD recorder. The message reads no dvd, bur the dooe will not open. There is a DVD+r in the unit.
    The unit worked fine with dvd+rw's, but before it locked up it was having some problems reading and recording dvd+r's.
    I have plugged the unit in and out, while pushing boyh eject and stop, and a number of other manual tries with no luck.
    Maganavox wants around $100 to replace it.
  • 91 Answers
Try using a knife without the dvd player plugged in that will get out the cd
Posted on Sep 27, 2007
  • kimberly puddicombe Sep 28, 2007
    maybe it is your laser lens maybe the dvd player lens needs to be cleaned
  • 80 Answers
Pls change the dvd player eject round belt 4 c.m
Posted on Jan 01, 2015
Turn off unit, Unplug it, Plug back in and press power button ON THE UNIT, Press the Eject ON THE UNIT and it should come out
Posted on Nov 24, 2007
I have a ThinkPad T60; and it wouldn't open (drawer)...turns out the system had to be "ON" and the OS loaded and operational; THEN, the drawer opened, IF you satisfied the conditions, AND then held pressure on the silver thinkpad button on the drawer on the left side of the thinkpad machine. (Apparently the ThinkPad is not a mechanical button that triggers the DVD/CD drawer....It's not explained in the PDF user guides from the Lenovo website. (I have no manual since this was a refurbished unit from a private source. Other than that it's worked very well for me so far)
Posted on Jan 20, 2009
I have an LCD/ DVD combo and the DVD won't come out. The tv still reads the DVD but won't eject it. I've tried on the remote and the unit :(
then there is a problem with your cd case .........................................................
ON THE BACK OF DVD THERE IS A WIRE OR SUM PIECE PULLED IT BY USING SOM CLIP THEN THE DVD'S DOOR OPEN EASILY..........
Aug 07, 2011 | Televison & Video
Dvd door won't open for Sanyo DVW 6000
If you are trying to eject a disc, look closely at the front bezel of the drive, there is a small hole near the eject button, push a paper clip into the hole (straightened paperclip) and the tray will be ejected.
If the DVD door is stuck and will not open through ejecting via the icon in My computer, or the eject button on the bezel will not work, you likely have a faulty drive that will need to be replaced
Jul 22, 2011 | Computers & Internet
Aver DVD Veriton 5800 dvd door will not open. do not see a pinhole. tried opening from computer start did not work either
sir the pin hole is the best solution but since u r unable to find it then the only solution remains to unscrew the DVD and check the door opening belt is not broken\stuck... just move it a little bit and the hatch may open... but before going through it please try to strike ur DVD with your hands a little bit while pressing the eject button repeatedly... this might help in moving the stuck belt inside... rate this solution if you watch awesome movies on your newly repaired DVD
regards....
May 06, 2011 | Acer Veriton 5800 PC Desktop
My pioneer dvdrw dvr 107d door wont open when i press button /have cd stuck inside (worked 5 mins ago) can still view dvd content/ will driver update fix ? please help
The drive may have come loose in your pc and is stopping the door to open.Hold open the front flap and press the eject button. If it wont eject your disk straighten out a paperclip and holding the front flap open look at the front of your drive and you will see a small hole.Push the paperclip through the hole and it will release the catch and eject your disk, You may have to push hard .Hope this helps you.
Regards Bill
May 04, 2010 | Pioneer DVR-107D DVD±RW Burner
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
Help ejecting dvd
I had the same problem and tried for ages (even tried forcing the door open thinking I could just tape it shut) without luck.
Then my very clever wonderful husband had a go (I know i'm crawling and yes my knees hurt).
Any way to the relevant bit. If you hold the eject button down and at the same time slide a knife or similar object round the edge of the door where the screw is near where it says photo/select you'll find that the door opens as this is an override mechanism.
Feb 22, 2008 | Hitachi DZ-GX3200A DVD Camcorder
DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Dec 03, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
4,624 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
